Is this something I can do?
So today I went and picked up the passenger side door from the junk yard..already painted red
![]() so I was thinking about just putting the door on myself instead of paying to put it on..Is this a easy process?..something I can walk myself through?
myspace.com/garrettstarnes 2004 4.6 engine. Cold air intake. Stage2 clutch. Spec Flywheel. Intake spacer. Throtle Body spacer. More to come! |
Resident DJ
'01 Cobra Vert.
Unbolt. Bolt back up. No problem.
niice. It will be on first thing tomorrow.
Resident DJ
'01 Cobra Vert.
Good luck bro!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Its as simple as lefty said. When you pull the bolts out youll see rings on the hinge that the bolt heads left. When you tighten the bolts back up make sure the heads of the bolts are back in the same spot based on those rings. This will put the door back in the same position so you shouldnt have to adjust anything.
Resident DJ
'01 Cobra Vert.
^ I was assuming he'd figure that part out
lol u never know about some people
Resident DJ
'01 Cobra Vert.
+1, I guess it didn't hurt to mention it. Thanks!
#9 | |
Resident DJ
'01 Cobra Vert.
If you can use a wrench and have eyes you'll be fine
lol, I didnt know if there was any wiring I would have to figure out..Seeing I saw some lose wires on the door I just got...I'm sure I'll do just fine tho
Also if youre doing it yourself vs 2 people it might not hurt to throw a few layers of masking tape on the edge of the fender so that way if you wiggle the door or something trying to stick it on there yourself it wont scratch it somtimes they can be a bitch to hold while putting the bolts in
Good idea dude, Cuz I want have any help at all.
Resident DJ
'01 Cobra Vert.
Nice ajm!
As far as wiring goes youll be fine. The only "hard" part with these cars vs an explorer or expedition for example is they stick the plugs for the door wiring up in the kick panel area behind/along with a bunch of other wiring so its kind of a hassle to get to but nothing too serious just one of those pain in the ass kinda things.
Resident DJ
'01 Cobra Vert.
^ yeah, just take your time with it Garrett. I have a feeling you'll be fine homie
Yeah I belive I should be able to handle it as well. again thanks y'all.
Resident DJ
'01 Cobra Vert.
No prob.
np
