How to: Paint interior trim on a budget
Old February 11th, 2009, 01:38 AM   #1
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
So, you want to paint the interior trim pieces of your car but dont want to pay big bucks for a spray job? Well, here ya go;
This guide was made as I was doing my own interior. The process requires no prep work, and gives you a nice color without a ton of time or cost.
Materials:
  • (insert color) Dupli-Color Vinyl Paint
  • Masking Tape
  • Cloth rag
  • Flat Head Screwdriver
  • Philip Head Scewdriver
  • Rubbing Alcohol swabs
Total Cost: $20 - $40
(I only had to buy paint, was $20.84 for 3 cans at Autozone)
Always buy extra, incase you run out. One can did the Center Console, One can for the Door Panel trim on both doors, Cluster trim used about 1/4th of a can.
Painting Techniques
These steps can be applied to every trim piece you paint. The basic steps are as follows:
  1. Remove trim (refer to specific guide below per piece)
  2. Clean throughly with Rubbing Alcohol
  3. Allow to air dry for atleast 5-10 minutes
  4. Spray a very light even coat across the surface. Be sure not to overspray, this layer is to set the stage for the main paint
  5. Allow to air dry for 5-10
  6. Apply 2nd coat. Be sure to evenly coat the surface while avoding running. ALWAYS paint in the same direction. I usally go Left > Right > Left > Right back and forth
  7. Allow to air dry for 5-10
  8. Apply 3rd coat, allow to dry for 10-15 and repeat these steps until you have a good color, with all surface area covered
  9. Allow entire piece to Air dry for atleast 1 1/2 hours
  10. Reinstall
NOTE: You can have more than 3 coats, this is just to get you going. I usally dont worry about coats. I simply keep painting until I am satisfied with the color and/or coverage of the paint.
Door Trim Removal
note: Passenger and Driver doors are the same, minus the Power Mirror control.
First, you need to grab your Flat Head Screwdriver and your cloth rag. Wrap your screwdriver head in the rag as to not cut any trim pieces when prying them out.
Next, you want to use the Screwdriver and Rag to pop out the trim panel like so:
After that, you will need to grab your Philip Head Screwdriver. This will be used to remove the Window and Lock operation buttons, and you will need to disconnect the wire harness for the Power Mirrors. You will want to unscrew the two screws pictured below, as well as the Clips on the harness:
After this you simply move the buttons out of the way like so;
This next part is tricky. The Power Mirror controller needs to be taken out. It has clips on all sides that hold it in place. You will need your Flat Head Screwdriver and your hands to pry this out and remove it. Pictured below is the button still attached with some of the clips highlighted:
NOW YOUR READY TO PAINT !!! Refer to the above painting techniques. Here is the trim panel after about 3-4 good coats drying:
Old February 11th, 2009, 01:39 AM   #2
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Cluster Trim Removal
To start, you will need to unscrew two screws at the top of the trim. These screws are star bits, T15 if I remember correctly. They are located here:
After this, you will need to grab your Flat Head Screwdriver. You will now be removing the Headlight switch knob. This guy puts up a fight. There is a small slit on the bottom with a Metel tab. Depress it with some force, and pull it out. Here is what the slit looks like;
After this, you will be removing the trim. Simply grab your Flat Head and Rag. Start to work out the trim. Once you get it lose, slide it bottom first out and upward. Also, be sure to remove the rubber peice that is attached to the Trim. It is rubber, and just slides right off.
Here is mine drying:
Center Console Removal
This part is very easy. No tools are required to get this out.
Step one will be to get the bottom half out.
  1. Simply grab the bottom portion of the bottom half (lower green circle) and pull to you, with a little force, and it will pop out.
  2. After this, you will need to disconnect the 12v Power Plug from the back. It simply has a tab you depress and pull out.
  3. Now you will need to Grab the top of the left over trim and pull outwards as well (top green circles).
  4. After this, you will need to disconnect the three buttons from the back. Like the others, simply depress a tab and pull out.
The next big step is taping off the bottom portion of the Center Console. Grab your Masking Tape and tape off the black vinyal area of the bottom portion. This will allow you to paint will keeping the trim around it clean.
The last step is to paint, let dry, and reinstall. Remember, the top portion installs FIRST, then the bottom. Be sure to reconnect all buttons and 12v adapters.
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old February 11th, 2009, 01:41 AM   #3
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
adding a clear will make that a good shiny piece.
SCT Mass Air Flow Sensor $200
Old February 11th, 2009, 01:42 AM   #4
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Ya, forgot to add the clear in the guide. Mainly because I personally did not use the clear. It came out shiney enough. That pic does not do it justice. Sun + red color + my camera = fail.
Old February 11th, 2009, 01:45 AM   #5
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
haha thas good.
Old February 11th, 2009, 01:49 AM   #6
Whatever it originally would be
Seabee's Avatar
05 Saleen #824
Fast as fuck
Seabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to behold
Send a message via AIM to Seabee
Nice, no primer for you? I will probobly be doing silver or something light, like that. Maybe next check
MILITARY CREW
ANTI ILLEGALS CREW FOUNDER
Old February 11th, 2009, 01:52 AM   #7
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
No Primer, was doing this project as a "How can you do it with minimal cost" It acually comes out decently smooth and shiny. Now, granted your not sanding and primer... so its not car paint.
Old February 11th, 2009, 01:54 AM   #8
Seabee's Avatar
05 Saleen #824
Fast as fuck
when did you do this?
MILITARY CREW
Old February 11th, 2009, 01:55 AM   #9
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Did the Cluster trim today, door panels the day before, center console the day before. So Sunday, Monday, Tuesday.
Old February 11th, 2009, 02:03 AM   #10
Seabee's Avatar
05 Saleen #824
Fast as fuck
ah, im just wondering on the wear, if it will fade or chip easily
MILITARY CREW
Old February 11th, 2009, 02:08 AM   #11
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Granted its not fail proof, no paint is. The great thing is the fact that if you have to redo it, its not expensive at all.
I had painted my center console a different color about 2 years ago. It took about that much time (2 years) to noticeablly fade.
Old February 11th, 2009, 02:11 AM   #12
Seabee's Avatar
05 Saleen #824
Fast as fuck
Yea i remember seein it in another thread, and i didnt even noticed the date was on the pictures lol, shows how much i pay attention. Well i think its a good write up, sticky worth. Ill be doing it and checkin your thread out just to make sure i dont jack shit up, which i shouldnt......hopefully
MILITARY CREW
Old February 11th, 2009, 02:15 AM   #13
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
Thanks bro, I appreciate it. I just wanted to share the info because I know its a popular topic. Im going to be follow WLJohnson's footsteps soon and repainting my dash and everything black.
Also gonna be doing my V6 Value Covers red this (hopefully) weekend. Plan to do a write up on that as well.
It is not hard to do. The removal is just basic tech skills. The paint is almost fail proof as long as you take your time plus pay attention to detail.
Old February 11th, 2009, 04:13 PM   #14
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
I learned today that the Dupli-Color Vinyl and Fabric paint has an adhesion promotor already in the paint. This seems to be why it sticks so easy to these pieces.
Im gonna be doin my whole interior black by Spring, gonna use a lite promotor for that however.
Old February 11th, 2009, 07:08 PM   #15
Rebel Of The Sacred Heart
travis_afx's Avatar
'02 GT
travis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of light
Nice write up.
So I was just wondering what made you get fabric & vinyl paint for plastic in the first place
Travis Billings
May 6, 1982 - July 5, 2011
Rest In Peace brother, you will be missed.
Old February 11th, 2009, 07:56 PM   #16
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
iTrader: 15 reviews
It acually works very well on the hard pieces, Atleast this brand does. I have used it before in other cars and the results were very nice so I did it again
Threads Similar to: How to: Paint interior trim on a budget
Source for interior trim pieces? Timber 99-04 21 November 1st, 2009 09:26 AM
Interior Paint Murderjetz Visual 8 May 2nd, 2007 02:22 PM
interior paint 00vabchgt Visual 2 January 28th, 2007 01:09 AM
interior paint??? missmichelle V6 Mustangs 16 August 3rd, 2006 10:11 PM
Interior trim questions effectivesols General Tech 1 March 20th, 2006 01:33 PM
