96 v6 foglight install..... help!
Old April 16th, 2009, 02:47 PM   #1
1996 ford mustang
theyanks904 is on a distinguished road
Exclamation
ok guys got a small problem
i just got this foglight kit from restro 5.0 94-98 FOG LIGHT KIT, BASE, RELAY, SWITCH AND 2 FOG LIGHTS MUSTANG
the problem is i went to go put them in and the holes that go from the fog light bracket that go into the car have no treads ....... has anyone had this problem ............the question is how do i mount the foglight brackets to the car ?? is there special bolts ? ive never saw a GT setup
thanks
Old April 17th, 2009, 07:35 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
are you talking about "the bracket that goes onto the car have no threads"? can you elaborate more or even take pictures?
BUILD 2 IN PROGRESS
Old April 22nd, 2009, 08:05 PM   #3
Look Ma! My First Post!
Dan B's Avatar
1995 V6
Dan B is on a distinguished road
fog light kit and U-Nuts
You need to purchase some U-Nuts and bolts to mount your fog lights. I just mounted some on my '95 Mustang and the kits supplied NO hardware in order to mount the lights. I used 3 on each side, 2 on the back side of the frame/bumper and one on the bottom. The square holes allow you to slide the U-Nut into place so the bolt can go through the round holes.
I don't have a picture, but if you have stuck you head under there, you should see the holes.
#1 - '69 Mach 1 - 4-speed
#2 - '69 Mach 1 - auto
#3 - '70 coupe - auto
#4 - '95 V6 - ouch!
Threads Similar to: 96 v6 foglight install..... help!
VVME HID Foglight Install moneygreenstang 99-04 18 March 7th, 2009 12:01 PM
Foglight troubles...help! Abe02GT 99-04 5 June 27th, 2008 10:24 PM
foglight help (v6) stanged out V6 Mustangs 8 September 27th, 2007 02:03 AM
Foglight problem Cricket Audio/Video 2 February 13th, 2007 10:44 AM
Foglight Wiring '97 GT Rodan1 V6 Mustangs 1 January 1st, 2007 09:14 PM
