How do i get rid of small scatches on my car safely?
Well, I just got my car a couple months back and it had a few scratches on it that look like a tree or something brushed on it a bit. They are very light and when you touch it you can't feel it...so it isn't deep. It is very noticeable though.
How do you think I can get get of them....I would rather not spend a lot of money for such a small thing. http://www.5pdcoatings.com/special4a...FQlaPgodODWMkQ that looks like it might work but I don't trust it completely. |
i use this stuff called Scratch Out it comes in a yellow bottle and its from wal-mart... it works really well plus its only like 4 bucks.. its easy too use and not too messy.. you can try that..
![]() 8t6 + Red = Cooler than you! Official MM Zeppelineers - Founding Member Proud Member of Los Latinos Unidos de Modded Mustangs MM Hottie Club Member |
get some of the meguires scratch x & use that... then wax your whole car using their cleaner, glaze & wax... if you got the cash i would get a small buffer as well... it will make the waxing process quicker & it will most likely get those scratches out... if they dont come out after that, take it to a body shop & see what they can do.. they will probably just sand the scratches & then buff em out.
http://www.cardomain.com/ride/2461223 1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon! |
#4 | |
Sounds like it just scratched the clear coat. I have a black car that had scratches and swirl marks when I got it. I used black colored wax to get mine out. The wax fills the holes and once you go over it a few times with the buffer it will not be noticeable. The more times you wax and buff your car the less noticeable it beomes until it completely fades out. Really any wax will work if you buff your car often enough.
3000 Grit Polish
I have used a liquid 3000 grit polish on clear coats and clear plastic. I actually use it on my watch crystal. It is very gentle and takes a few applications to work on deeper scratches. It doesn't cut the finish and really works great. I got mine from Steego. You'll only find something that fine at an autobody supply. Good luck.
2003 Mustang GT
Wait..ok this might sound stupid but cmon im 16..dont know that much..but..for the wax..does it have 2 be the color of your car? you know how you said you used black turtle wax? or did i just misunderstand..i have like small swirls on my hood and i want to get it nice and buffed
#7 | |
![]() If you can find it in a paste instead of a liquid that may work even better. Doesn't have to be this brand. There are other color waxes out there. You may also want to seriously look into this stuff. I'm ordering it for spring and I've heard nothing but good things about it. I heard it is what Chip Foose's team uses on thier show cars, but I don't know if it is true, http://www.properautocare.com/menklasconki.html
i might have to look into that stuff as well! sounds like a pretty good deal!
So i used the meguires scratch x a few times after i washed my car...it seemed to slowly start making the scratches less noticable after every application.
#10 | |
hmm somebody dinged the back of my car and it got pretty scratched up. how can i tell if the scratches are deep or not? and if the things you guys are talking about will work.
#12 | |
well im gonna try to explain this the best i can. i will also post some pics Monday on this thread or i will create a new one. but if by other color you mean like a silver grey ish color then yes
. and also (again im trying to explain this as best i can) there is also like a few white lines that almost look like they were pressed on. lol probably hard to know what im saying but i will post some pics on monday.
#14 | |
The white lines sound like pressure marks. I don't know how to get rid of them. I have them on my door like someone leaned something really heavy against the car. Maybe someone else will know, but I think the pressure marks have to be removed professionally because they occur under the clear coat.
first off i wanted to thank you for you help neckbonekat
also i do have touch up paint that i got from the dealership when i got the car but its like a nail polish bottle almost. it is in a bottle and you twist off the top, then there is a stem and a nailpolish like tip. you know what i mean? this is also my first car and iam quite young and ignorant when it comes to cars, so the best bet might be for me to take it to a professional. i will still post pics on monday so that hopefully you can help me make a more precise decision. although im not exactly sure what a pro would do but if they repaint that section or something and blend it would it bubble in a few years? |
#16 | |
thanks alot for you help man, its greatly appreciated. i will most likely take it to a pro (hopefully it wont hurt the wallet too much because i was hoping to mod my ride performance wise this spring/summer).
#18 | |
here is a rule of thumb i use. If i can feel the scratches with my fingernail. then waxing isnt gonna fix it.
That will require a high speed buffer ( some call it a "wheel") and some cutting compound. but PROFESSIONALS ONLY. you will burn your paint if you have never done this before. Local PROS here will .....Wheel, Polish, and Wax a car for around $100. its an allday job. but worth it.
1986 Mustang GT t-top time piece! |
so i just want to make sure i understand what you are saying. well first off i can feel the scratches. so if i take it to a shop and get them to "wheel", polish and wax it, you think that would solve the problem?
Threads Similar to: How do i get rid of small scatches on my car safely?
| small paint bubbles? | Breakout | Visual | 0 | October 12th, 2007 02:38 AM |
| small accident | 232stang | The Clubhouse | 9 | September 12th, 2007 03:13 AM |
| Where To Get Some Small Things For 00 GT | MSTGGT00 | Visual | 4 | November 15th, 2006 08:43 PM |
| Need A Small Part | acmillr | 99-04 | 3 | October 11th, 2006 12:29 PM |
| Small Problem... | Green_Monkey23 | Feedback Forum | 5 | October 11th, 2006 01:30 AM |
