Discussing a few interior upgrades in the Visual Forum. popped for an mgw shifter and ford racing shift knob...im really satisfied with both ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
popped for an mgw shifter and ford racing shift knob...im really satisfied with both items...
forgive the dirty shifter area ![]() the knob cleans it up nicely
2002 Mustang GT, BBK LTs, X-pipe, Bassani BX, MGW Shifter, FRPP 4.10s, Moser 31s, Cobra diff, SCT Xcal2, JLT CAI, Accufab 75mm TB/Plenum, eibach sportlines, strange adj struts, tubular control arms, and One Heavy Foot.... |
did you paint the trim yourself? or did you buy it like that?
If you aren't first.....your last! http://i148.photobucket.com/albums/s...7_19/Bsig2.jpg |
a friend and i painted it. i did all the prep work which was lengthy and tedious but definately worth it. he sprayed the base and clear on it.
well it looks nice man..wish mine woulda turned out that nice!!! what kinda prep work did you do??
what i done with these parts was i sanded down the areas with 180 grit. you may think its sorta of aggressive but it will be fine. i thought it was also. scuff it up to get the grain out of the plastic. after thats done spray regular automotive grey primer on it.....no rattle cans. u will need an air spray gun to get the best results. once its primed and dry, take some dry guide coat and spread the powder all over the primed areas. next, take some 400 grit "wet" sanding paper. wet sand the parts until all the guide coat is gone. if ur not familiar with guide coat its basicly made to help u see high and low spots. so sanding it till all the guide coat is gone in theory makes for a smooth surface. after u do all of that...rinse it off real good and use a clean paper towel to wipe the water and sanding dust off. when u are priming you may wanna give it a couple of coats of primer so u have more leeway when u sand it. u dont wanna sand through the primer. after all that time eating work is done ur ready for paint. if ur not comfortable with painting just bring it to a body shop already prepped and taped off so all they have to do is shoot paint on it. shouldnt be expensive since ur doin all the prep work.....everything i mentioned here can be purchased at a decent auto parts place.
hope that helps
haha wow thats crazy. All i did use rubbing alcohol to clean int..and spray painted it silver...then a clear coat..and it dont look too bad for how long it took
i have the same shifter in my ride. gotta love mgw!!
http://img.photobucket.com/albums/v2.../matrixsig.jpg |
Just like TheManInBlack said is the best way to go....I used to paint cars and you either pay attention in school or learn from your mistakes...just don't forget to blow off all the dust from sanding and clean the parts with First klean (it removes grease from you just touching the parts) then after you primer the parts and it's ready for painting you will need final klean to remove all the crap that may have gotten onto your work....dust or any crap on a paint job will make your job look like shit.....so when you spray keep the area as clean as possible.....oh and if you spray, they have a special primers for plastics.....
good luck |
Threads Similar to: a few interior upgrades
| Upgrades For My 94 | Redrider | 94-95 | 15 | April 12th, 2007 11:19 AM |
| v6 upgrades | mmvi | V6 Mustangs | 4 | March 17th, 2007 03:45 PM |
| $1 upgrades | myeleanor | V6 Mustangs | 52 | March 1st, 2007 01:40 AM |
| What Upgrades Should I Do? | SlowStang | V6 Mustangs | 6 | November 9th, 2006 09:03 PM |
| Upgrades? | venomm | 94-95 | 6 | October 30th, 2006 12:39 PM |
