projection headlights
Old February 25th, 2007, 10:35 PM   #1
lissy is on a distinguished road
Send a message via AIM to lissy
Hey does anyone know if HIDs work with the Projection headlights because I was reading somewhere that they dont.....So anyone please advise
Old February 25th, 2007, 10:39 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
no they are to hot.
NCMM #9
Old February 25th, 2007, 10:42 PM   #3
Bies08 is on a distinguished road
Send a message via MSN to Bies08 Send a message via Yahoo to Bies08
would you guys rather get HID or projector headlights?
If you aren't first.....your last!
Old February 25th, 2007, 10:44 PM   #4
MM's Resident Ricer
2006 Scion tC
13.001@113
HID you have to get a kit for real expensive I like projectors better
NCMM #9
Old February 25th, 2007, 10:44 PM   #5
GotBoost232 is on a distinguished road
Send a message via AIM to GotBoost232
i prefer hids at 5000k ...cost ya around 125 bucks 8-10k is the blueish color u see on bmws ect they dont have the brightness factor or the ditance factor as good as the 5000k spectrum does....the 3000k is em-azing for foggy and rainy conditions but are bright yellow.....if u go with the hids for like 125 bucks u wont have high beams but ulle have brighter lights then ur stock high beams but be street legal
if u go witht expensive kits they give ya a high beam option
stock 04 blue mach 1
Old February 25th, 2007, 10:47 PM   #6
what exactly do you call expensive kits. And you dont have a high beam if you go with the 125 dollar one!? can you still see anyting? i dont understand how the low beam on HID will show better than Hi beams for regualr cars
Old February 25th, 2007, 10:55 PM   #7
its all about lumens...candle power ec....the hids are " high intesity discharger" they put out more light then the stock high beams...they cheap kits are plug and play but are great we installed on on my friends cobalt ss its brighter than his high beams the reason the cheap ktis dont have high beams is it runs off ur switch for just turning ur lights off and on...the high beams add more power to the bulb and or angle it up high so it goes farther but when u look at an hid its not as blinding as the brights on ur stock bulbs but goes farther...
Old February 25th, 2007, 11:07 PM   #8
scubasteve041186's Avatar
2004 mustang 40th annv.
scubasteve041186 is on a distinguished road
Send a message via MSN to scubasteve041186
haha the HIDs are not hotter green faleen.. they just run a different bulb in the projectors then they do in the stock housing. but i'm definately gona try to get them to work together haha i want halos and HIDs
Old February 25th, 2007, 11:09 PM   #9
MM's Resident Ricer
2006 Scion tC
13.001@113
no they run much hotter that is the warning on the projectors that HID bulbs are to hot I have the projectors.
NCMM #9
Old February 25th, 2007, 11:49 PM   #10
DaemonJ is on a distinguished road
HIDs do run hotter than usual because they are pushing more voltage than usual to create a higher output.
Old February 26th, 2007, 12:07 AM   #11
uhm actually hids dont runner hotter and it has nothing to do with voltage....it happens to do with wattage....hids run about 30-35 watts....halegens run at about 50-55 watts...they run hotter....they thing with halos is the hids wont fit correctly and halos dont neccesarly cooperate with hid bulbs very well....
Old February 26th, 2007, 03:44 AM   #12
thank you boost haha ^^^ thats what i was talking about the hid use less power ( watts) meaning energy = less heat go figure eh brighter but less energy lol but its the bulbs that don't fit correctly
Old February 26th, 2007, 07:49 AM   #13
02ponypackage's Avatar
02ponypackage is on a distinguished road
yeah HIDs run cooler...you just gota make sure you get a True HID kit...because you might buy some stuff that does run hot....but my Projectors Ive seen with HIDs and they are really good...I like the stock headlight look better but I do have Halo Projectors since I needed to replace the stock ones....for 90$ i couldnt pass up and its the one that cost 399 on AmericanMuscle.com (mustangtuning.com)......if you like the projector look HIDs will work better with it....but you'll just be spending slightly more money getting the new headlights.....just make sure you set the projector aligned and level so the light becomes evenly spread
just a V6 with a bad belt slip under the hood
Old February 26th, 2007, 01:56 PM   #14
MM's Resident Ricer
2006 Scion tC
13.001@113
No guys I will take a pic of the warning they run to hot for the halos the bulbs fit fine the place for the bulb is no smaller than stock.
NCMM #9
Old February 26th, 2007, 02:30 PM   #15
silver stang's Avatar
silver stang is on a distinguished road
Yea, they are right GreenFaleen HIDS use less energy produce less heat and are alot brighter then hologen oh they also last about 4x longer.
Old February 26th, 2007, 02:55 PM   #16
MM's Resident Ricer
2006 Scion tC
13.001@113
well all the warnings on my lights say they will melt the housing. So I beleve that is more heat. It might mean without the converter but just slapping a halogen bulb on there will be hotter.
NCMM #9
Old February 26th, 2007, 03:57 PM   #17
yea they probably did mean with out the conversion kit or maby they don't fit right and touch the housing. I do know for a fact that they use less energy and produce less heat.
Old February 26th, 2007, 04:02 PM   #18
MM's Resident Ricer
2006 Scion tC
13.001@113
IDK but to go back to the question HID bulbs will melt the housing and halo on the projector headlights.
NCMM #9
Old February 26th, 2007, 04:07 PM   #19
I think it depends more on what model of projector head lights, because I found this (k2motor(DOT)com/lhpmst99jmtm.html)
EDIT: Found the awser you where looking for here it is remove "(dot)" to "."
reviews.ebay(dot)com/HID-Guide-to-Aftermarket-Projector-Headlights_W0QQugidZ10000000001638316
Old February 26th, 2007, 04:09 PM   #20
MM's Resident Ricer
2006 Scion tC
13.001@113
they are bound to make them that can handle the bulbs. Just check the warnings.
NCMM #9
Threads Similar to: projection headlights
94-98 headlights Nick_Rapitis General Tech 3 August 13th, 2007 10:42 AM
headlights DragonFreak 96-98 16 August 6th, 2007 02:25 PM
new headlights on the way 91foxhatch5.0 Visual 2 June 10th, 2007 11:33 AM
headlights are on!!!!! droppedbass87 96-98 5 April 4th, 2007 10:28 AM
