Painting Calipers - Page 2
Old March 2nd, 2010, 02:23 AM   #21
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
I kind of doubt he did. There's really no point to it since nobody aside from anyone helping you work on the car will ever see the back side of the calipers.
Backsides are painted as well
Originally Posted by 06RedfireGT View Post
Hell, I'd suck his dick on TV for 52 cents lol
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old March 2nd, 2010, 03:05 AM   #22
3.9L V6
lol..who wouldn't pait both sides...
and no you don't have to bleed the lines...just turn the calipers around....it's not hard and you won't destroy anything...and if you do i'm revoking your mustang ownership card
[SIGPIC][/SIGPIC]
6k HIDs - Rear Sway Bar - Mac Prochamber - Goodridge Gstop SS Lines - Lots of Visual Fun - Go Fast Mods (no point in buying...it's a v6)
Want to see your car as art...ask me how
Old March 2nd, 2010, 09:57 AM   #23
MM's Official Lucifer
goren813's Avatar
'00 3.8L
I took mine off to paint. So much easier to work with off the car. Seriously it takes all of 30 seconds to remove the brake line. Just have a catch pan underneath it, it will leak somewhat, the first more so then any others. Bleeding the brakes is simple with a buddy, takes a few minutes. Really is not hard at all, you'll spend more time taping and prepping the wheel well and then trying to clean off any overspray then you will removing the caliper.
Old March 2nd, 2010, 10:09 AM   #24
Admanistrator
v606er's Avatar
v606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to beholdv606er is a splendid one to behold
Last time I drove my car I was actually thinking I needed to bleed the brakes. They felt a little squishy.
Can someone give a quick run through on how to correctly bleed them?
MAD Stangs #8
Old March 2nd, 2010, 10:26 AM   #25
Admanistrator
v606er's Avatar
This kinda explains it, but they are a little vague on things, and only one useless picture
http://www.corral.net/tech/maintenance/brakebleed.html
MAD Stangs #8
Old March 2nd, 2010, 11:03 AM   #26
goren813's Avatar
'00 3.8L
Bleeding with a helper on the link you gave is how I would describe it as well. One person pumps the brakes, then holds, then the other opens the bleeder valve slightly, then tightens it, all as the pedal is held down. You basically want to do this until no more bubbles are coming out into the tube connected to the bleeder valve, and when the pedal feel firms up. Also keep an eye on the brake master cylinder fluid level, you'll probably have to top it off as you do this.
Old March 2nd, 2010, 05:52 PM   #27
BadBlackGT's Avatar
13.82@100.26
BadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the rough
Nice, ima do this... i think. I just wanted to do all four at the same time, can i use four channel locks to come about doing this instead of bleeding all of my fluid out? Then open the bleeder screw when they're back on and release the channel locks until the bubbles come out one at a time starting with the furthest away? Then i don't think you would need a buddy.
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
Old March 2nd, 2010, 10:09 PM   #28
Admanistrator
v606er's Avatar
Where is the 'break master cylinder'?
In the engine compartment somewhere? Or is it by the front driverside wheel?
MAD Stangs #8
Old March 2nd, 2010, 10:34 PM   #29
00BlueMustang's Avatar
2000 Mustang
00BlueMustang is a jewel in the rough00BlueMustang is a jewel in the rough00BlueMustang is a jewel in the rough
I know in the NewEdges you can easily spot it on the drivers side but not to sure with the S197s
Detailing Crew Member
North Carolina Modded Mustangs #5
Old March 3rd, 2010, 10:46 AM   #30
goren813's Avatar
'00 3.8L
Thanks Blue, just now got back to this... that's it up there ^. Bad Black I've never done it on any car other than how I described it to you, so I can't really answer that question.
Old March 3rd, 2010, 06:50 PM   #31
rugame2c's Avatar
2001 Mustang GT
rugame2c is on a distinguished road
I used the duplicolor on mine from American Muscle. It came with the kit (brush, masking tape, stirrer). I used a small foam paint brush that worked alot better than the regular brush. I removed my calipers from the rotors and taped off the parts that I didn't want to paint. Took about three coats.
I will be installing my new Cross drilled / slotted rotors this weekend. Should look very nice.
2001 Mustang GT convertible
Bassani X-pipe and catback exhaust, Steeda pullies, C&L plenum w/inlet tube, BBK 75mm TB, C&L 80mm mass air, UPR CC plates, AM Bama SCT tune, B&M shifter, Transgo shift kit, Autometer gauges and "Steeda" trim.
Threads Similar to: Painting Calipers
Painting Calipers WhtStang00 Visual 17 December 20th, 2009 04:25 PM
Painting Calipers trueballerisme 2005 - 2010 30 January 3rd, 2008 12:55 AM
painting calipers trueballerisme 2005 - 2010 17 October 31st, 2007 12:03 AM
Painting Calipers WeCircleTheProblem Visual 14 April 14th, 2007 12:49 AM
Painting The Calipers... B0mb3r645 Visual 20 October 9th, 2006 11:28 AM
