COLORED FORD EMBLEMS (Not Decals)
Old March 4th, 2007, 03:08 PM   #1
ZOOTOXIN's Avatar
ZOOTOXIN will become famous soon enough
This might be old news to this forum but I wanted to know why no one talks about matching the Ford emblem on rear trunk to the color of the car. Its a great alternative instead of completely removing the embem.
I have step by step directions if anybdy is interested. Its a great cheap do it yourselfer that adds a small touch of customization. IM me for step by step intructions and detailed pics.
Red Ford emblems on a black mustang would be sweet!
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
Old March 4th, 2007, 03:09 PM   #2
ZOOTOXIN's Avatar
another pic
Old March 4th, 2007, 07:03 PM   #3
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
how about doing a write up on it and posting it?
Old March 4th, 2007, 07:07 PM   #4
Mod of the Year '11
2021 Mustang V12
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
+1.. sounds pretty cool.. im sure more than 1 person would be interested and you probably dont want your inbox flooded with people asking how lol
Cars and mod list in garage
I prefer a girl with a cafina
That's Spanish for vaheena
Which is Italian for clam
Old March 4th, 2007, 07:18 PM   #5
RLY SRS
ChrisJ's Avatar
ChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud ofChrisJ has much to be proud of
iTrader: 9 reviews
Yeah if you could make one with red and post it up so people can see it...
Facebook
Google+
Old March 4th, 2007, 07:46 PM   #6
ZOOTOXIN's Avatar
How To Make Your Own Custom Ford Emblem
Article by Javi Guerra (a.k.a. Buzz4x4 in the forums)
The following information contains instructions on how to paint your Ford Oval Emblems and as far as I know and researched they work with almost any year Ford Emblem. The way to make sure is feel the plastic coating on it with a knife and check to see if it’s a bit rubbery if it is then it should work.
TOOLS NEEDED:
1. 3M double sided mounting tape (at least 2mm thick)app. $2.47
2. 1 can of Dupli-Color Truck, Van & SUV spray paint.(color of your choice)app. $3.48
3. 1 box of Envirotex a pour on high gloss finish (available at a large craft store)app. $8.99
4. 10mm socket and ratchet
5. Chap stick or a crayon
6. Acetone (not a requirement)
7. Masking tape
(Please note: I highly recommend you purchasing an extra set of logos at a junk yard or dealership in case of any mistakes you might make.)
CONTINUED
Old March 4th, 2007, 07:52 PM   #7
ZOOTOXIN's Avatar
PROCEDURES:
1.) First you’ll need to remove the rear emblem on the tailgate. This is done by heating up the emblem with a hair dryer and using fishing line as a saw and/or just peeling it off. (The hotter it is the easier it will be.) Take off any excess glue from both the emblem and tailgate.
There are three pins behind the emblem that won’t let you saw all the way through you’ll have to pry it off…be careful not to scratch the paint.
After removing the two emblems you’ll need to remove the rubbery plastic coating on them. This can be achieved using a hair dryer or placing the emblems in boiling water. I chose to heat them up with a hair dryer since I had no idea how long they needed to be boiled and it was much easier. Once it is hot enough you’ll notice the plastic coating is soft. Use a knife and dig out the plastic carefully…Don’t worry if you scratch the metal surface underneath. It should come out in big pieces and the blue color will come with it.. If any blue color remains on the emblem scratch it off or use acetone to remove it. most of the blue paint will come out with the plastic.
CONTINUED
Old March 4th, 2007, 07:54 PM   #8
ZOOTOXIN's Avatar
The next step was one of the most time consuming. Tape off the chrome all around the edge. And either using the chap stick or crayon carefully cover the areas that you want to keep chrome. I toyed with the idea of leaving everything chrome and only painting the word FORD black but I decided not to. I used a crayon on the rear emblem and I used chapstick on the font one so I could see which was better. I’d have to say the one with the chapstick was the easiest to remove. Carefully coat the word ford with chapstick making sure you get every part.
Once you have emblem carefully coated with Chap Stick. Take the Dupli color of your choice apply several thin coats of the spray paint. Let it dry completely before working with it.
I don’t have any pictures of the next step but it’s pretty much self explanatory. This was the most time consuming of the steps because I was very careful and wanted to make it perfect. Once the paint is completely dried you’ll need to either use the end of a Popsicle stick or a small knife or even your fingernail and scratch off
CONTINUED
Old March 4th, 2007, 07:55 PM   #9
ZOOTOXIN's Avatar
all of the areas where you placed the chap stick or crayon. If you coated the letters correctly you should just be able to take it right off exposing the chrome. As careful as I tried to be I did scratch off a little bit around the letters but I just covered up any mistakes with a black marker. Then buff it up real nice with a soft cloth.
.) Eighth and final step after making sure you have everything scratched off and it looks good follow the instructions on the Envirotex box. Inside the box there are two plastic tubes with a hardener and resin. Mix an equal amount of the two together very well in a cup or small bowl.
Make sure your emblems are on a flat surface face up. Pour the mixture on the emblems very slowly and let it fill the entire surface. Also make sure you get the grove around the edges. Be very careful during this step and take your time make sure you don’t pour to much right away in fact pour a little first and move the emblem around to get the mixture to coat the entire area. Then pour some more and fill it. I believe the rear emblem takes approximately 20ccs of the mixture although I did not measure the amount I put in.
CONTINUED
Old March 4th, 2007, 07:56 PM   #10
ZOOTOXIN's Avatar
Now place the emblems in a safe place and away from dust. You’re going to need to leave them on a flat surface face up for a quite some time. My Emblems took almost 24 hours to completely dry causing me to drive around without them . That is another reason why I suggest buying an extra set to work on. Once they’re completely dried buff it up real nice and replace the front emblem, secure the fasteners. Since the fasteners are of very cheap quality you may just have to use the double-sided tape on the Front emblem as well as the back. Don’t forget to replace the radiator cowl. To insure a good clean surface for the tape to stick on you may want to clean the back of the back of the emblem and truck with rubbing alcohol. On the rear emblem make sure you cover the back entirely with the double sided tape, stick it on and press firmly.
That’s it your done!. You’ve just saved at least 80 dollars by making your own custom ford logos! Take a look at the finished product! Good luck and happy motoring. PICS TO FOLLOW
Old March 4th, 2007, 07:58 PM   #11
ZOOTOXIN's Avatar
heres a pic
Old March 4th, 2007, 07:59 PM   #12
Mod of the Year '11
2021 Mustang V12
thanks man.. good read
Old March 4th, 2007, 07:59 PM   #13
ZOOTOXIN's Avatar
another pic
Old March 4th, 2007, 08:19 PM   #14
ZOOTOXIN's Avatar
red on my car... I didnt do it to my Cobra yet...this red one was done in photoshop
Old March 4th, 2007, 08:20 PM   #15
ZOOTOXIN's Avatar
red close-up
Old March 4th, 2007, 08:34 PM   #16
ZOOTOXIN's Avatar
here on black...looks fantastic from this distance-LOL
Old March 4th, 2007, 08:36 PM   #17
Mod of the Year '11
2021 Mustang V12
ZOOTOXIN - did you get my PM? i was just wondering cause i sent it a while ago and you never responded.. just wondering if you checked it
Old July 28th, 2007, 12:55 PM   #18
SickSixer04's Avatar
SickSixer04 is on a distinguished road
I have a black Mustang with red stripes... I think I'm going to try this in either black or red... I hate the blue... Thats great!
Real cars don't power the front wheels... They RAISE them!
Drive fast... attract cops... Drive faster... attract sponsors.
Old July 29th, 2007, 08:21 AM   #19
The George Forman of Keepers
JASonic's Avatar
JASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to allJASonic is a name known to all
iTrader: 20 reviews
Send a message via AIM to JASonic
what a cool project. The whole process inspires for other things besides the name plate.
Its too bad my car is blue and the plate is blue. Id give this one a try. Easy to understand instructions and cheap.
Threads Similar to: COLORED FORD EMBLEMS (Not Decals)
Colored wax? Archy88 Visual 1 October 7th, 2007 08:04 AM
Black Ford Oval Emblems danzaman Visual 7 September 5th, 2007 03:14 PM
Removing decals Bies08 Visual 13 June 1st, 2007 10:31 PM
Decals scxc15 Visual 14 March 22nd, 2007 06:04 PM
Colored Bulbs Aeroz V6 Mustangs 4 September 4th, 2006 12:21 AM
