LinkBack (4) | Thread Tools |
#21 |
Yea i have no idea how these headlights work cause they change the setup to two halogen bulbs from the one dual funtion 9007. I wonder if they add a relay to keep the lows on while the highs are activated or if they just switch... Either way i will have to add a relay/diode to keep the hid lit and maintain the highbeam functionality.
Honestly, the more time i spend on HIDPlanet forum this week, the more i think i will just do a retro fit with a bixenon setup. |
#22 |
ok, your 9007 bulbs have 3 wires. on my 02 the middle is black this is ground. there is a white wire for low beam and green wire fro high beam. what your new housings are gonna do is plug into that plug and then it will split the ground into two wires so it can run to both bulbs, and then it runs the colored wire respectively to the high or low bulb as needed.
now here is how I wired my HID.... low beam wire from the factory plug goes to a relay. 12V comes from the battery to the relay and then goes out to the positive of both my HID balasts. ground as appropriate.... and I left teh high beam hooked up at the plug so the halogen bulbs still work. so now once I turn on my low beams the relay activates and feed 12 (or actually 14.4 once my car is running...) volts straight to the HID's rather than running a weaker signal through the cars harness. High beams are still run like normal. gives me more power to the HIDS. and with my 55W kit, I really dont need my high beam and I do a LOT of driving at night. I still would recommend to NOT have both high and low beams on at the same time.... after running for a while you will most definitely have heat issues... melting, distorting, and discoloring of the plastic lens.... I did this a long time ago with a different car and it did NOT turn out well...
![]() 02GT - Blown motor 86LX 3.8TBI auto replacement daily driver How to retrofit HID's |
#23 |
and if you want to go bi-xenon..... I have the 9007 6500K setup here with the controller and everything... you just need to get ballasts... but look at the pics I put on the first page of this post.... it shows the in a halogen reflector housing. scatters light everywhere, hard to aim, blinds everyone... I actually found the light output (usable) was better with halogen bulbs over the HID in the halogen housings....
but if BI-xenon is how you want to go I will sell you what I got and you can pick up your own ballasts. just a thought....
#24 |
Thanks man for all the info. I'm gonna start with the housing and then look at retrofitting options versus just switching the halogen projectors from an Ebay housing to HID projectors.
#25 |
Got a question, will HID bulbs fit in aftermarket projector headlight assemblies like the ones that AmericanMuscle and CruizinConcepts sells?
#26 |
some sn95 light testing... I make my own lights
#27 |
if all you want is projectors why dont you just mold them into your stock lenses?
#28 |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/visual/173892-projector-headlights-hids.html
| Headlight opinions | This thread | Refback | November 18th, 2011 03:58 AM | |
| Headlight opinions | This thread | Refback | November 18th, 2011 12:37 AM | |
| Which projectors for 95 GT Mustang? | This thread | Refback | April 27th, 2011 01:32 PM | |
| Which projectors for 95 GT Mustang? | This thread | Refback | July 13th, 2010 02:04 AM | |
Threads Similar to: projector headlights for HID's
| Projector Headlights? | 06z28eaTer | 2005 - 2010 | 27 | January 18th, 2010 01:44 AM |
| Led projector headlights | RX Bandit | 2005 - 2010 | 2 | September 6th, 2009 08:46 PM |
| projector headlights vs regular headlights | BossOfDaRich | V6 Mustangs | 7 | June 22nd, 2009 09:57 PM |
| Anyone have projector headlights like this? | 86ttops | 5.0 Mustangs | 9 | January 11th, 2008 05:49 PM |
| Projector Headlights | graystang01 | V6 Mustangs | 24 | November 29th, 2007 02:43 PM |
