Discussing Fog Light Install in the Visual Forum. Ok so im gonna get some fog lights for my new front bumper and i ...
Old March 29th, 2007, 12:00 AM   #1
Ticket-Me-Yellow's Avatar
Fog Light Install
Ok so im gonna get some fog lights for my new front bumper and i was just wondering what do i do to install them? like i no how to install the light part but everything else idk what to do from there. Like where do i run the wires? how do i install the switch? can someone please help me?
Old March 29th, 2007, 12:02 AM   #2
MM Phantom
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
don't the new edges have the wiring installed already?
Back for brotherly love. My thoughts are with you Bubba!! [9-23-08]
Originally Posted by omz
Old March 29th, 2007, 12:09 AM   #3
idk theres like these kit u have to buy and u run it like into ur dash and it goes in as a button. But i want it as a button and also as when i turn on my head lights the fog lights go on with it. If thats possible
Old March 29th, 2007, 12:20 AM   #4
Resident MM Ricer
GreenFaleen's Avatar
2006 Scion tC
13.9@103/8.9@81
01 should have the wireing kit already. But I'm not sure how to wire it to your headlight switch
Scion Tc-strup racing header, CAI, Ground Kit, NOS 100shot, Custom suspension, Doc. I 50% STS
Thanks To My Sponsors:
Strup Performance
Old March 29th, 2007, 12:30 AM   #5
jabrennan's Avatar
I'm not sure what your wiring looks like from the fog lights, but if there is just a positive wire and negative wire you can attach the positive to the positive wire in the cluster that is connected to your headlight knob and then ground the negative. Then they will turn on when you pull out your headlight knob. The positive wire would be the thick grey one in the middle.
I don't know if this would work. I would check around before messing with it. That's just how I wired my led cluster to turn on with the headlight knob.
This doesn't really show how to wire it to your headlight knob, but it might be helpful anyhow.
http://www.americanmuscle.com/indepe...ht-wiring.html
Old March 29th, 2007, 01:22 AM   #6
hmm then i must of ran into a problem no one can answer. Thats a first for me on here. lol anyone else?
Old March 29th, 2007, 02:07 AM   #7
well what kind of bumepr did you get would help me answer.. you can get the GT fog lights from VMPtuning.com i put them on my car recently and they went on in about 45mins time (and iam electronically impared haha)
I don't drive fast. I fly slow.
http://i16.tinypic.com/4355weg.jpg
Old March 29th, 2007, 10:33 AM   #8
Re: Fog Light Install
I can't help you with how to turn them on when you pull the light knob out...But, I can help with installing:
you can pretty much run the wires up the engine bay (wrap them in an insulated wiring tube), and run them through the firewall. From there, run them under the carpert, under your driver seat and up to the center concel. Now, open the concel and you will see 2 or three rubber "stoppers". Pull the stoppers off and unscrew the screws underneath them. Now you can pull the plastic the runs from the concel to the shifter off. From there you want to pop the coin holder out and run the wiring under the concel to hide it and out the hole for the switch now. If your confused, PM me, i will send you pictures.
Old March 29th, 2007, 09:50 PM   #9
i have an 01 so i dont think it is right after the fire wall. Idk though. But i got the same stock bumper but with fog light wholes now. but basicly how do i put in the button?
Old March 30th, 2007, 12:38 AM   #10
Look Ma! My First Post!
Fog Light Install on 2001
I did this install on my 2001. When I started I wanted it to meet 3 criteria, 1) it had to appear stock, 2) the lights turned off/on with the headlights, 3) the fogs did not turn off with the high beams. The good news is that all the wiring inside the car is there, tear open the center console, install the Ford OEM switch and zowie! The bad news is that the wiring stops at the firewall. You have to scrounge the connectors to the fogs from the salvage yard, you can buy a kit on e-bay now, but I did my mod, including the take off fogs, for about $100. Other items needed is a 30 amp relay, treminal connectors, heavy duty 20 amp fuse holder with 20 amp fuse, flexible 1/4" dia. split tube covering. And, of course the wiring diagram. I ran all this stuff to the engine compartment fuse box. I wrote a full article, with pictures, a couple of years ago. I could email it to you if you would like. Good luck!
Old March 30th, 2007, 01:31 AM   #11
Re: Fog Light Install on 2001
way to make an appearance! id like to see your article because i want my fogs to come on with the headlights.. right now mine are just stock gts =[ where you have to press it everytime
Old April 2nd, 2007, 03:01 AM   #12
ya dude could u email me that article plz?
Old April 2nd, 2007, 10:31 AM   #13
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
if i remember correctly...
when i had my v6 and i was installing a speedcal i saw the wiring already in place behind the shift boot.
pull off your shift boot and if it is there all you should need to do is buy a fog light switch
Threads Similar to: Fog Light Install
Head Light and Tail Light Opinion Needed Laser Visual 8 January 2nd, 2008 03:16 AM
Check engine light after steeda udp install clmozesc 2005+ 4 October 18th, 2007 06:30 PM
Mustang Light Bar Install fhinesley 99-04 4 May 11th, 2007 07:16 PM
How you can change your dome light color. (light on roof) SonicStang Visual 25 March 23rd, 2007 01:39 PM
new gauge cluster install problems plz help theft light bigpopaz99 V6 Mustangs 22 December 15th, 2006 03:29 AM
