Weather Stripping Making Noise
Old May 4th, 2006, 01:30 AM   #1
Stan27 is on a distinguished road
Whenever I go over 80MPH, the wind starts whistling between the windows and weather stripping. Anybody else have this problem?
Old May 4th, 2006, 10:11 AM   #2
JRuckas is on a distinguished road
on the doors right?
Old May 4th, 2006, 10:12 AM   #3
if it is, either your window isn't going all the way up or your weather stripping is going bad.
Old May 4th, 2006, 12:21 PM   #4
A door adjustment may take care of it as long as the weatherstrip itself isn't torn or messed up. Try moving the door latch striker in about 1/16" or so and see if it helps.
88 Mustang Coupe
www.rickscarcare.net
Old May 5th, 2006, 04:59 PM   #5
173speed is on a distinguished road
most of the time is the Weather Stripping leaking take a piece of
paper or a thin piece of car board run it between the door and the body and see if u have gaps
olsa do a visual inspection of the weather striping and see if u have flat spots or rips in it also a way to it is with a smoke gun u have some one on the out side look while u run the smoke on the inside along the whether striping if smoke comes out the other side then the w/s is
SEEYAAAAAAAAAAAAAAAAAAAAA MOTHER @#$%
Threads Similar to: Weather Stripping Making Noise
Weather stripping plove71387 V6 Mustangs 5 October 23rd, 2007 11:07 PM
clutch pedal making noise AndrewA. 99-04 14 September 5th, 2007 01:48 AM
Why is it making this noise damnit!!!! Ole Yeller V6 Mustangs 10 August 2nd, 2007 07:37 AM
Removal of Door Panels/Weather Stripping OcOnnor220 99-04 8 July 14th, 2007 04:45 PM
69 Coupe Weather Stripping Dilema! hotmustang351 Classic Mustangs 0 October 24th, 2006 11:12 AM
