Discussing Removing Antenna Base? in the Visual Forum. I know this may be a stupid question, but how is this done. My antenna ...
Old May 5th, 2007, 06:58 PM   #1
Vision.Pro's Avatar
1999 Ford Mustang GT
I know this may be a stupid question, but how is this done. My antenna base has come loose and i want to tighten it and reseal it, but i can't figure out how to take it apart. Do i have to open up the fender well (under the hood) or can i just unscrew it from the top?
Old May 6th, 2007, 12:23 AM   #2
1REASUN's Avatar
99 stang
go straight from the top and unscrew it or screw it back in. im sure you can find a manual online if your really scared about "f-ing" anything up. just try googling your search for instructions. I say, while your at it, just buy a new antenna (shortie 8inch or 6 inch) cuz i've seen them around. I dont know why the antenna's are so cot damn long on the stangs...really
check out 50resto.com real good site for parts and such.
- 1REASUN
Old May 6th, 2007, 02:03 AM   #3
Murderjetz's Avatar
I think he means the rubber thing that you screw the antenna into, not the antenna itself...
I don't know about a 2000 but I know for a 94, if you open the passenger door, you can reach under there and loosen/tighten it from under like that.
Listen to my music | Visit my garage
Old May 6th, 2007, 02:22 AM   #4
Vision.Pro's Avatar
yeah that's what i meant. i'll try that out in the morning
Old May 6th, 2007, 01:06 PM   #5
Vision.Pro's Avatar
problem solved. going through the door was too tight, so i just popped the bezel off with a screwdriver, which revealed 4 screws underneath. thanks for the help though.
Threads Similar to: Removing Antenna Base?
Cloning A GT 500 From A V6 Base v6hornet 2005+ 17 December 5th, 2007 12:42 PM
holly system max base intake & 3.73s for a 8.8 rear 87foxbodylx For Sale 5 November 12th, 2007 03:28 PM
Base Line V6 dyno check finished 05MUSTANG4.0 V6 Mustangs 48 July 3rd, 2007 04:30 AM
shaker base assembly musman Classic Mustangs 0 March 11th, 2007 12:53 PM
Possible to install a 04 Cobra engine in a 99 base? HypeTelecon Modular Mustangs 3 December 19th, 2006 09:11 PM
