Originally Posted by Maverick530
AHHHH DAMN ITTTTT.....
i this kryon clear sucks it made it dull too. just not as bad and white....
left is clear coated (1 coat) right is not
the krylon fusion clear coat is terrible for plastic lenses.... i found this out the hard way... Like stated before, it comes out dull, a bit milky, and just overall shitty... DO NOT USE IT!
Krylon Crystal Clear Gloss Clear Coat on the other hand is a great product for lenses and has not failed me once.
Originally Posted by jdde2219
So my headlights got clearer from wet sanding and buffing but you can still see all the little scratches and cracks ill go get a picture real quick to explain better. Would the clear coat fix these little problems? I bought it but havnt used it at all yet.
you sanded with way too low of a grit... 2000 grit should be your finishing grit... You should also be sanding in one direction. Not in the swirling motion you did. Also, did you try to hand buff these out? because it looks like no type of compund/polish was used to try and get any of the scratches out
