03 GT
![]() ![]() iTrader: 4 reviews
Fixed my tinted tails!
I tinted my tails with VHT today, some parts of it look good, and others are dull and blotchy. Here's how I did them:
Clean with soap/water Wet sand with 400 grit 3 light coats of adhesion promoter 3 light coats of VHT 4 coats clear Wet sand with 2000 Buff( by hand) with Meguiers Ultimate Compound I can post up a pic if needed but what did I do wrong to get the blotchy spots?
![]() Vortech v2 si-TiAl Q- CXRacing- still need MAF
MM's Database Error
Did you do any sanding in between coats?
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
03 GT
no, I was thinking that could be a reason
12.9 @ 111.44
Uneven layers? If its that noticeable remove and try again
03 GT
I already did. This time I started with 800, then skipped the adhesion promoter and it looks waay better. I'm waiting for the clear to dry now, Im not sure how its going to turn out, I think the clear is screwing it up too. Should I spray the clear while the VHT is still wet?
how do you remove the vht once its on there?
Jailbait till 2013
2001 V6 / 94 Z28-gone
0-60 in -10.3
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
i use goof off to get the VHT off
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
Sanding.
I initially sanded mine with 1000. I would say the initial 400 grit might be a little rough. You should be good with 800. I also let the VHT dry for about 3 hours and did a light wetsanding w/ 1500 grit (then wash) before clear.
i never use adhesion promoter when i tint heads or tails...could be a factor along with a heavy finger on the nozzle...do you press the spray nozzle before even over the tails or when you're aiming at them?
2001 Mustang V6
i wetsanded wit 2000 grit before and between coats. just 7 very light vht coats and 2 clear coats. pleased wit the result
03 GT
So Round 2 went very well. I skipped the adhesion promoter, sanded from 400,600,800,2000, the sprayed wet coats this time, then cleared and buffed. Turned out pretty good I think.
Heres the end result that I got the first time. The opicture doesnt do it justice, it looked horrible. ![]() Heres the second try, before sanding and buffing. ![]() And end result. ![]() Im still going to polish and wax later, so it should get a little glossier I think. I think Im going to remove the spoiler tomorrow and see how that looks.
Dancing Naked In The Rain
Your second attempt looks pretty good. Polish them up really well, let them sit for a few days, then give them a few coats of wax.
I sanded mine twice already but now there white almost instead clear do I just need to sand more?
What grit are you sanding with and are you wet sanding? Dry sanding will leave scuffs. Get enough scuffs and things tend to look white. You need to wet sand with a very high grit sandpaper (I like 2000grit+ for final wet sanding), keeping the sandpaper and object well lubricated.
03 GT
Even wet snading with 2000 grit, mine were still a tad hazy and scratched. I just sprayed the clear and buffed with the compound after it dryed and it looks good. (I sanded with 2000 before spraying vht so it already had a smooth surface)
When you wet sand with a high grit sandpaper, sand lightly. You're trying to smooth the surface, not scuff it.
It was 1500, but it wasn't wet sanding so thats probably the problem. What do you use for the clear coat your talking about? And after the clear is on what is the best thing to use for buffing, would something like a microfiber towel work?
2001 Mustang GT Vert
Average
mine look like your first ones, im just in the phase of finding time to take them off and i have some goo gone, i hope that takes vht off
#19 | |
03 GT
I sanded the VHT off with 400 grit in like 10 minutes per light, then resprayed.
2003 Mustang GT
They look good the second time! I wish mine were that light now. I'm gonna re-do them Wednesday. Hope they turn out as good as yours.
Threads Similar to: Tinted my tails, didnt go so well :(
| Keep the tinted tails or ? | mk1993 | Visual | 14 | May 30th, 2011 06:58 PM |
| Tinted Tails | jordon | Pictures | 8 | March 9th, 2011 11:27 PM |
| Tinted my tails | TaintedStang | Visual | 8 | June 12th, 2010 01:14 AM |
| Tinted my Tails | 03SonicBoom | Visual | 21 | November 29th, 2008 07:19 PM |
| tinted tails | Mustang RacR94 | 4V / SVT | 42 | June 4th, 2008 09:10 PM |
