2000 mustang v6
14.6@99.68
tinit question/problem
So when I got my car 6months ago both of the windows were tinted....poorly in retrospect...
So its starting to peel and again in retrospect in stupidity I decided to just peel it off...and now it apears like a glue like substance(dried) was left behind on my window and my window has a hell of a time going up or down (passenger side window) and I don't wanna burn out my motor for the window...is there a quick fix besides getting it retinted of have an auto detailer/shop remove the""glue""?
Ported heads, comp cams cam, AM CAI, posi'd rear with 3.73 gears, flowmaster exhaust Fixed clutch!!!!! "My mustang likes a good ol' fashion bowl of rice....especially fried" |
Dancing Naked In The Rain
Get a razor blade and a heat gun/hair drier/steamer. Heat up small areas of the adhesive and scrape them off with the razor blade. It's going to take some time, but it will get the job done. It would have saved you a lot of time to use a heat source on the tint so that the adhesive came off with it
2001 Mustang GT Vert
Average
if you cant get a heat gun, look under your moms sink for some goo gone
![]() iTrader: 1 reviews
+1 on goo gone or goof off. Get plenty of rags and keep flipping to a clean side when the rag gets cloged. If you don't do the razor blade right it will leave scratces.
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit. |
It makes my wife horny
16.3@84@5kft
since you peeled of the tint already, just use a razor and water. keep it wet, and go at it.
2003 Mustang - 3.8, 5spd., bbk, eibach no isos, duals, hids, 72k 1968 RS/SS Camaro - 350, .090 over, .500" lift, flows, M21 2004 Nissan Armada - HIDs, LEDs, sippy and DVDs 2002 F150 - Screw, 5.4l, GOTTS w/ K&N, flow super 44
16.3@84@5kft
16.3@84@5kft
stupid double post.
goo gone yes....goof off no....that shits nasty on paint if you let any drip and don't notice lol
Threads Similar to: tinit question/problem
| a problem and question | polemonkey | V6 Mustangs | 12 | June 24th, 2011 07:18 PM |
| Odd fuel problem/question | MustangSR330 | 99-04 | 3 | February 1st, 2010 10:44 PM |
| Transmission problem/question | Seabee | 2005 - 2010 | 23 | June 2nd, 2009 11:22 PM |
| Question On Idle Problem | blue03mach1 | 99-04 | 2 | November 18th, 2007 07:38 PM |
