I'm doing it wrong
04 Grand Cherokee
How you guys get your smoked tail lights so shiny?
I can't seem to do it. I am using that Rustoleum lens tint, and I am doing everything that should give me a nice shiny finish but for some reason it's not happening.
I wetsanded with 2000 grit Applied 2 coats of tint Wetsanded with 2000 grit again (very very lightly) Put on 4 coats of gloss clear Wetsanded again Used Meguiars rubbing compound and polished them. This is what I got, they aren't shiny at all. ![]() What did I do wrong?
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
Senor Tini
I bought mine shiny
I'm doing it wrong
04 Grand Cherokee
Bout to redo mine, want to make sure they come out nice and shiny lol. Just finished taking the tint off (yet again).
1996 Mustang GT 5spd
Mine were done with clear/black and they nice and shiny. I never had any luck with VHT crap.
So after you spray them and let them dry, wetsand just as you did and then polish them with Maguiers ultimate compound and finally polish them once more with Zymol car wax. I did this and they came out super glossy. Hope that helps man.
#6 | |
I'm doing it wrong
04 Grand Cherokee
Just finished wet sanding them with 2000 grit again and sprayed one coat on each. Going to let them sit for 20-30 minutes before I hit them with the second coat. Then I am probably going to hit them with 4 coats of clear each let them sit for a little over an hour before wet sanding with 2000 grit again then ultimate compound and waxing time comes. Will post pics, hopefully I get the finish I WANT. This is the 3rd time I have done this to my lights (other 2 times were for different reasons)
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
Did you make sure to clean the sanding crap before spraying tint and then clear? When I tinted mine w/ VHT I did the following:
Sand 1000 grit Clean and dry Apply desired number of VHT coats and allow to dry Light sanding w/ 1500 or 2000 grit to remove imperfections Clean and dry Apply coats of clear and allow to dry Sand with 2000 grit clean and dry buff They turned out just like paint. Before applying wax you should let them cure for a few days.
#8 | |
I'm doing it wrong
04 Grand Cherokee
Cleaned old tint off Washed lenses Wet sand with 2000 grit wiped down with rubbing alcohol and cleaned dried them and sprayed 2 coats of tint I heard the wet sanding after the tint isn't needed if it dries smooth, if I don't wetsand after only tint I will hit it with a few coats of clear then wet sand and buff with rubbing compound. I will also wait a couple days to use wax. Thanks
Jailbait till 2013
2001 V6 / 94 Z28-gone
0-60 in -10.3
![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
![]() He did his with VHT, and they came out really nice. |
2000 sixxer, 1988 Fox
i did mine with VHT, the first time i did it they looked just like yours, the second time i did it i put down a real light first coat and a heavy second coat and it came out a lot smoother, a couple days curing a little wax and they turned out glossy. Hope that helps ya a bit
I'm doing it wrong
04 Grand Cherokee
Well I am about to go spray the clear so I will find out soon enough.
Jailbait till 2013
0-60 in -10.3
Goodluck.
May the force be with you
Moderator
2003 Grand Cherokee
Yeah, it's not necessary and shouldn't effect how shiny they are. But since it was coming from a spray can, I noticed some orange peel that I wanted to get rid of and that's why I sanded.
I'm doing it wrong
04 Grand Cherokee
Yea I went to go spray the clear a little bit ago so I gave them a real good inspection first and everything looked good so I started spraying, on my second coat now. Might just wetsand after that one is dry.
2001 Mustang
It might be the Rustoleum... I tried that stuff when i first started tinting lights and never had great success with it... VHT on the other hand has yet to fail me.
The process i use to get excellent results is -Wet sand lights with 800 -clean -spray tint (however many coats desired) -let dry -wetsand lightly with 2000 -spray clear (like 4+ coats) -let dry -wetsand with 1500 -wetsand with 2000 -buff with scratch remover -buff with plastX -wax
![]() All Bark, No Bite
I'm doing it wrong
04 Grand Cherokee
Yea man, I just finished mine and they look the same thats in the pic and I did everything right. I have to grab some VHT for sure. Closest store that has it is about 30 min away lol.
Jailbait till 2013
0-60 in -10.3
weren't your tails blacked out before? Wtf happened to them?
I'm doing it wrong
04 Grand Cherokee
I untinted them because I started liking the stock look but that went away after about 2 weeks.
Jailbait till 2013
0-60 in -10.3
Once you go black you never go back
#20 | |
2001 Mustang
one stock one tinted ![]() Mmmmm shiny
Threads Similar to: How you guys get your smoked tail lights so shiny?
| Smoked tail lights? | wheelsjz | 96-98 | 26 | April 27th, 2011 01:05 PM |
| Smoked Tail Lights | backDRAFT13 | 99-04 | 29 | July 7th, 2010 01:31 AM |
| Installed Smoked head lights and tail lights | Ethan79 | 96-98 | 29 | January 1st, 2010 07:59 PM |
| smoked tail lights and head lights | 02MiNeRaLgRaYGT | 99-04 | 13 | October 13th, 2009 07:49 AM |
| Smoked Tail Lights | quickstang281 | 96-98 | 79 | January 14th, 2008 06:05 PM |
