1999 Mustang GT
DIY black headlight housings
Been sitting on this for a few months, but figured i'd spread the wealth. When I bought my 99 GT it had brand new OEM replacement headlights. Unfortunately they were the chrome housings. So rather than buying a whole new set, I decided to make a little project of it. Now this is all going from memory so I may forget a couple small things
What I started with ![]() First things first, remove the headlight along with the bulbs. Next you'll want to remove the metal clips on the headlight holding the lense to the housing. There's also a small phillips screw at the end of the headlight housing (by the reflector) that needs to be removed as well I went ahead and popped them in the oven for about for about 5 minutes (give or take) at 300*. then slowly but surely peeled the lense away from the housing. Then you'll want to pull the chrome portion away from the housing. I can't remember if there's a screw holding it in place or not, so you may want to check around for one. once it's out of the housing, go ahead and remove the reflector as well. It's held in by a small bit glue so be careful pulling it off. After which, it should look something like this ![]() Next I sanded the plastic using 600, then 800, then 1000. Then comes the paint, what I used was Rustoleum semigloss paint that I picked up from Autozone. But any black should work. ![]() Let it dry overnight then repeated steps in reverse to put the housing back together. I skipped this step, but you may want to pick up some sealant to reseal the headlight. I did mine one at a time to show a before and after, but here's the final product ![]()
Steeda UDP's, Accufab plenum/70mm tb, FRPP 3.73's, Pypes xpipe, Flowtech mufflers, BBK CAI, and a few other random goodness ![]() |
very nicely done..repped for the write up for the people it could help
Dancing Naked In The Rain
That's fantastic! Good write up and you might save some people some money
2001 Mustang GT Vert
Average
i hear sticking your headlights in the oven is bad
1999 Mustang GT
It's really one of those things where you do it at your own risk. As long as you're not foolish and keep an eye on them than you'll be fine.
i need to put my spare set in the oven to take them apart so once i start my retrofit for projectors they'll be ready...i can go ahead and spray them black and take out the reflectors along with cutting down the back lol
1999 Mustang GT
That's my next thing. Been wanting to retrofit projectors for years and figure I should really get on it. Fairly simple process given the right tools and a little patience
Threads Similar to: DIY black headlight housings
| Need some headlight housings... | saber63 | V6 Mustangs | 13 | July 25th, 2010 11:13 PM |
| Black Headlight Housing | 94blakonblak | 94-95 | 25 | November 10th, 2009 12:06 AM |
