Discussing Adding Fog Lights to a v6 in the Visual Forum. I noticed that they v6 front ends DO have the fog light holes.. except they ...
Old May 25th, 2007, 07:34 PM   #1
I noticed that they v6 front ends DO have the fog light holes.. except they have plastic bars that run across the holes hindering the placement of fog lights..
Is there anyway to have these cut and installed? If So how much would the manual labor cost to be done professional and if this could be done personally without having to pay to install it, would the install be hard to?
Old May 25th, 2007, 09:00 PM   #2
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
the install requires 3 bolts per fog light and a razor blade to cut off the plastic bars.
the v6 bumper and the GT bumper are the same exact thing besides those little plastic lines
install them yourself man.
Old May 26th, 2007, 02:52 PM   #3
just cut the bars, and put them in urself ...i think u can just get the wiring harness off of ebay ?
Old May 29th, 2007, 10:41 PM   #4
JASonic's Avatar
Or you can put the fogs in the center. I think it looks better on mine. I have blue holos just to the inside of the outer hole. It looks coooool and I didnt have to cut anything. Plus, the ones I bought are long rectangles which would probably look silly in that curved outer hole.
Installation is easy. I did mine by myself and I hate electrical anything. Just follow the instructions to a T. Dont cheap on anything either... make sure your using the right guage wire and everything. Make sure you ground it well by sanding the area a little bit.
K&N FIPK
Dual Flowmasters
Xcal III
Christmas Gifts! http://www.moddedmustangs.com/forums...s-candles.html
PROFESSOR JA
candlestick maker millenium
Old June 13th, 2007, 02:37 PM   #5
Captain Of Team Leg Hump
06RedfireGT's Avatar
2006 Mustang GT
In the 13's
you could always just buy the whole take off GT bumper. there was an ad in MM&FF from saleen. they had the GT bumper with fog lights for less that $100. all you would need is the wiring hareness.
Old June 17th, 2007, 03:47 PM   #6
Victoria's Avatar
Not true. Both bumpers might look the same on first glance but they're actually different.
V6
GT
Old June 17th, 2007, 03:49 PM   #7
HMUSN's Avatar
19.83 @ 12mph
^ i am refering to the 99-04 bumpers Victoria :wink
Old June 18th, 2007, 10:52 PM   #8
Victoria's Avatar
Whoops... my bad!
*buries head in sand*
Old June 18th, 2007, 10:53 PM   #9
HMUSN's Avatar
19.83 @ 12mph
take your head out of the sand..
it's all good
Old June 20th, 2007, 06:29 AM   #10
ROUSHME661's Avatar
they sell a whole kit with the whole wiring harness the fog light switch and the foglights....if you look at ur bumper closely they even have the mounting brackets on there ...they should be direct bolt on ...
Threads Similar to: Adding Fog Lights to a v6
smoked tail lights and head lights 02MiNeRaLgRaYGT 99-04 3 August 29th, 2007 03:24 PM
Adding speakers Hourofpain Electronics 5 July 24th, 2007 01:01 AM
HELP WITH ADDING HP!! BOSS490 V6 Mustangs 9 June 17th, 2007 01:39 AM
Where to buy saleen grill lights and turn lights 2005 madden 2005+ 0 May 30th, 2007 11:54 PM
Wipers, instrument lights, interior lights insnedrmr 5.0 Mustangs 6 February 22nd, 2007 05:40 PM
