wiring in interior neon....question
Old January 8th, 2012, 08:38 PM   #1
94v6blkndred's Avatar
02 Turboed Saleen Clone
faster than my v6
94v6blkndred will become famous soon enough
Send a message via Skype™ to 94v6blkndred
im going to wire in the green neons for my trunk for the saleen seat delete....i want the lights to come on with the headlights...was gonna do them into the lic plate lights but saw the PATS system has some shit on that circuit so i didnt know if that would be smart ....so...whats the best route to take?
http://www.dewayneamiller.com/uploads/94v6blkndred_sig.jpg
94v6.CAI,Exhaust,3:73s-needs rear end rebuild
02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake
Old January 8th, 2012, 08:41 PM   #2
2000 Mustang GT 5spd
35.9@16.99
Cabikejumper is a jewel in the roughCabikejumper is a jewel in the roughCabikejumper is a jewel in the rough
iTrader: 17 reviews
Tap into the cig lighter and run it to a switch.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs
Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html
Originally Posted by RZNCAIN View Post
Thats not a Mustang, thats a V6!
Old January 8th, 2012, 08:48 PM   #3
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
Big gray wire in the center of your headlight knob harness is a switched +12V that comes on with the parking lights and headlights in your 2002. That's probably the easiest way to go about it without having to run wires from the tail lights.
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Nitrous Switch Panel for sale!
Old January 8th, 2012, 09:23 PM   #4
13.91 @ 102.04
02'TrueBlue will become famous soon enough
Do you have an aftermarket radio with a harness? If I could do mine again, insteda of a switch, I'd tap it right into the illumination wire on my aftermarket radio harness...That way you're not tapping into any stock wires
TRUE BLUE CREW MEMBER #6
Old January 8th, 2012, 09:27 PM   #5
codycat91's Avatar
2003 MUSTANG GT
codycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the roughcodycat91 is a jewel in the rough
iTrader: 10 reviews
Ever consider LED's instead of neons? Brighter, more durable, and you can bend them anround anything you want. Here are mine:
Also, you can disable PATS in a tune if you are concerned about it
4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton
4v MMR Stroker 1000 / Posi Race Ported Eaton Build
How To: 2v to 4v COP Swap
Old January 8th, 2012, 09:29 PM   #6
faster than my v6
well thats whats i have is LEDs my bad. but yea the wires are only like 15in long or so off of them thats why i figured id have to stay in the trunk with the wiring unless i bought more wire then ran it all thru the panels and such.
Old January 8th, 2012, 09:32 PM   #7
faster than my v6
i see a tan/wht and a brown comin out..on my diagram..so theres another main wire in there that i just have to tap into? can i ground it thru a wire in there as well?
Old January 8th, 2012, 09:49 PM   #8
Shelby's Minion
RZNCAIN's Avatar
2007 Mustang Shelby GT
(Mach1) Sept. '10 ROTM
RZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud ofRZNCAIN has much to be proud of
People will call neons gay, but what is the difference between that and ambient lighting and this?
Sponsored by Specialty Coatings
Car Salesman Club- Founder
2007 Shelby GT- Hardparked
2003 Mach 1- Hardparked
1988 LX 5.0- Umm...Driver?
Old January 9th, 2012, 10:54 AM   #9
faster than my v6
im just used to calling anything with color neons. i've never had a problem with tasteful lighting "mods". theres a thin line of over doing it though haha. mine is just for the rear seat delete only. just trying to figure the best way of doing it without messing anything up and having it look shitty. that was just mocked up with the little "try me" switch with the LED lights.
Old February 15th, 2012, 11:46 AM   #10
faster than my v6
i know this thread ended up dead from the beginning then when it got moved to visual it was set on fire while dead but...me and buddy wired in my lights last night..you cant even tell anything was done he did such a good job...T tapped into the lic plate wires above the LR wheel well in the trunk..secured it to the vehicle for a ground with a relay..ran a power wire to the battery with a fuse inline and then zip tied the lights to the mach 460 wiring on top so you cant see them at all unless you take out the rear seat delete...it was dark or i woulda took pictures.
Threads Similar to: wiring in interior neon....question
Interior Floorboard Neon Lighting? Ken Myers Visual 14 July 15th, 2011 01:11 AM
Neon Interior soccerboy08 Visual 3 May 19th, 2008 11:48 AM
interior neon help D-Brow V6 Mustangs 18 January 24th, 2008 09:47 PM
Interior Wiring D-Brow V6 Mustangs 6 January 24th, 2008 12:45 AM
Interior Neon Lighting? D-Brow Visual 47 December 14th, 2007 03:22 PM
