Retinted my tails, Reclears Heads
Old February 10th, 2012, 02:58 PM   #1
MustangLouver's Avatar
2003 Mustang GT
MustangLouver will become famous soon enough
Had the day of today, and happened to have a class cancelled so I thought I would take care of a few things that needed to be done. Finally recleared my headlights and retinted my tails. Some of you may remember my tails were originally blacked out, then I took that off and bought some smoked tint, and it stayed bubbled. Well, I finally smoked my tails with spray.
wet-Scuffed with 1500 grit
Spray 2 light coats of VHT
wet-Scuffed with 1500 grit again
Sprayed 5 coats of clear
Wetsanded with 2000 grit
Buffed to a mirror
Heads were wetsanded with 1500 grit
Sprayed with 5 coats of clear
Buffed
Pictures: What do you think? (And Yes I know I have a bulb with 1 filament burnt out
tails:
headlight:
My 2003 GT Project
Old February 10th, 2012, 03:39 PM   #2
vi3t's Avatar
vi3t is on a distinguished road
Looks good, did you just hand buff them out and what kind of compound did you use.
Beauty is only a light switch away.
Old February 10th, 2012, 07:53 PM   #3
2003 Mustang GT
I used a rotary with a polishing pad and meguiars ultimate polishing compound. Then I used meguiars finishing polish with a finishing pad. I didn't want the tails to be too dark, just wanted the smoked look and they are pretty gOod now.
My 2003 GT Project
Old February 10th, 2012, 08:33 PM   #4
SilverGhostGT's Avatar
2007 Mustang GT
12.89@112
SilverGhostGT is on a distinguished road
what kind of clear did you use on your headlights
2007 Tungsten Gray Mustang GT
Old February 11th, 2012, 12:06 AM   #5
2003 Mustang GT
I used Dupli-Color color match clear, worked pretty good. I tried Kyrlon (sp?) before and it turned white when it dried.
My 2003 GT Project
Old February 11th, 2012, 03:49 AM   #6
DoCtA.FlAkE's Avatar
1999 Mustang V6
DoCtA.FlAkE is on a distinguished road
Send a message via AIM to DoCtA.FlAkE Send a message via MSN to DoCtA.FlAkE
Nice, they turned out great
Old February 12th, 2012, 12:09 AM   #7
2003 Mustang GT
Thanks. I see you left the backup lights clear on yours, I started too but I wasn't sure how it would turn out. But I guess it's not bad since my tails aren't that dark.
My 2003 GT Project
Old February 12th, 2012, 12:21 AM   #8
Gunmetal
2001 mustang gt
n/a
mosthated is on a distinguished road
nice work i need to get mine cleared out
Old February 12th, 2012, 12:23 AM   #9
2003 Mustang GT
DO IT! Took me around 4 hours for the tails and the heads. Would have taken less time if it was a little warmer, it being 40 degrees it took a while for the clear to fully dry.
My 2003 GT Project
Old February 13th, 2012, 09:43 PM   #10
04steedaGT's Avatar
04steedaGT is on a distinguished road
Wow loooks awesome! Nice job man.... now do mine
JLT|Steeda|Eibach|Tokico|Ford Racing|Polyurethane|Flowmaster
Old February 14th, 2012, 12:23 AM   #11
2003 Mustang GT
I would if you were close-by! It's not hard at all a long as you have the patience to wetsand and buff and spray thin coats.
My 2003 GT Project
Threads Similar to: Retinted my tails, Reclears Heads
DIY tinting heads and tails w/vht nightshades cleangtvert 5.0 Mustangs 21 March 17th, 2011 07:12 AM
03/04 cobra tails vs GT tails vita Visual 8 January 20th, 2010 08:46 AM
Tails DRock 2005 - 2010 6 June 15th, 2009 02:25 PM
tails bullitt ak Visual 5 May 26th, 2009 09:08 PM
