whats the best wash soap to wash car??
hey just wondering whats the best wash stuff to either get at advanced or walmart...???and i use rainex was cuz it rains everyonce in awhile down here...what you guys recomend??
I really like, turtle wax ICE, it smells good.
1998 GT FRPP: 4.10s, Alluminum d/s STEEDA:upper/lowers, springs, cc plates, tri-ax TOKICO: Adjustable shocks SPEC: alluminum flywheel K&N: Intake Screamin Demon ignition ram: clutch ----------------------- BUCK OFAMA |
Proud American
Thats a wax bud! Just any carwash mix from advanced auto will work!
RLY SRS
depends on what you are doing...
I use Dawn Dishwashing detergent once a year before I clay bar it and such... My usual soap is maguiars soap... |
Proud American
Dawn Dishwashing soap takes the clear coat slowly off!
RLY SRS
Dawn dishwashing liquid takes the old wax off...That is why I use it before I clay bar...
You dont do a 50/50 mix...I do less than a cap full of dawn to a bucket of water...Its very dilluted... If you use it all the time then yes it will slowly make your paint unhappy...But if you use a very dilluted slution and do it before you claybar it is fine... I have been doing it this way for a long time... The key though is making sure it is dilluted avery well and make sure you dont do it any other time other then when you want to strip the wax to claybar and such...It makes claybarring alot easier... |
96 GT
good job chris ive been doing details for years now and thats what ive always done too. expecially if wetsanding is required. but for regular wash i prefer griots garage supplies... doesnt really make a difference
BBK cold air intake, flomaster 40 series, steeda tri ax short throw, bbk x pipe w/cats, black magic fan, 3.73 gears, bbk pulleys, 18/10 18/9 black bullitts black with chrome lip....
what is claybar and where to0 get it??
RLY SRS
Click Here For Zaino Clay Bar and Info
I prefer over everything Zaino...I used to only use Zaino but I lost the dealer I had and have not had time to order some new supply... |
96 GT
dont use clay bar if u have never done it... easy to fuck shit up
#11 | |
my favorite has always been Meguiar's Gold Class. it's high, but it works. and its just about as thick as leak sealer.
#13 | |
RLY SRS
You are thinking of wet sanding/color sanding... |
IBEATU
06 GT, 98 GT, & 93 Notch
I used to use Zymol car wash, but cant find it anywhere, just the wax which is great stuff. Now I use Megiuars Gold Class car wash
![]() 98 GT: some stuff 06 GT: more stuff 93 Notch: 4 cyl at birth, now 5.0 drivetrain and stock exterior and interior= True Sleeper Paxton/Vortech Crew Member #3 FRPP's #1 Dealer Injected Engineering BMR Suspension |
96 GT
no im not thinking of wet sanding ive seen customers bring their car in a tell stories of claybar and ive seen the shit that can happen... its ugly they try to get swirls out from their shitty wax job and its terrible
hey stanglifemike are both of those mustangs urs buddy>?>>
#17 | |
RLY SRS
Clay bar just gets the impurities in your paint out (the pieces of dirt we cant see that stick to the paint)...You are sadly mistaken...They dont take swirls away...The only way for the person to even start to ahve this issue is by not properly cleaning the car prior to the claybar... You wet sand/color sand or use compunds and a buffing wheel to get the swirls out of your paint...That is soemthing that should only be attempted by those with experience... |
96 GT
clay bar cuts can fuck all the way to the clear coat, ive seen it... and claybars do help swirls and fine scrates that cut compounds cant thin..
#19 | |
RLY SRS
Rail dust - Tiny, sharp bare metal shavings that can adhere and imbed into the paint finish and cause serious damage when left untreated. Over 70% of new vehicles are transported from the factory using the rail system. In many cases, new cars are stored near a railroad and becomes infected with rail dust. Brake Dust - Similar to rail dust, brake dust is also in the form of tiny, sharp metal shavings. In recent years, asbestos brake pads were replaced with metallic brake pads, which are actually brake pads made from tiny metal or metallic shavings. Anytime a vehicle is braking; brake dust is disbursed into the air and onto the paint finish. Since the brake dust is now actually tiny particles of bare metal, this form of brake dust can seriously damage the paint finish when left untreated. Industrial Fallout - A general term used for pollution and can be found in many forms. Eventually, pollution settles onto the paint finish of all vehicles and can cause serious damage when left untreated. Tree Sap, Road Tar, Bug Residue, Paint Overspray, and Acid Rain Deposits -- These contaminants adhere to or imbed into the paint finish. Left untreated, they will cause permanent damage to your car's paint work by staining and weakening the protective properties. The clay bar does not scratch paint...Its idiots who dont wash their car properly before hand that try and blame the clay bar for their problems... |
96 GT
no one asked for a novel bud
Threads Similar to: whats the best wash soap to wash car??
| wash and wax? | xSxTxAxNxGx | V6 Mustangs | 3 | November 11th, 2007 01:45 PM |
| Car Wash problem | Reset | Visual | 9 | August 9th, 2007 11:16 AM |
| CAR WASH! | marcfiebka | Visual | 14 | June 28th, 2007 03:04 AM |
| CAR WASH! | marcfiebka | Visual | 2 | June 26th, 2007 09:45 AM |
| How about a $9,000 car wash? | 99mustang232 | The Clubhouse | 4 | May 22nd, 2006 02:24 PM |
