C-Pillar Scoops
Old July 28th, 2007, 11:44 AM   #1
SickSixer04's Avatar
SickSixer04 is on a distinguished road
C-Pillar Scoops
OK... So I want to get c-pillar scoops and put them on my car. I know that most come and have to be painted to match but does anyone know how they are installed? Is it something you can just bolt on or do they get molded? I have no idea and every website I look at offers no help. If anyone has ever done this and knows that would be great! Thanks for the help!
Real cars don't power the front wheels... They RAISE them!
Drive fast... attract cops... Drive faster... attract sponsors.
Old July 28th, 2007, 11:51 AM   #2
TheUNZippee!'s Avatar
Most body pieces like that come with a template you use to get the piece positioned properly. Some C-pillar scoops also need to be gently bent by hand to get them to form better to the body. Just follow the instructions, and don't be shy about holding them up to the car and eyeballing them a bunch of times.
Originally Posted by My Wife
Old July 28th, 2007, 12:17 PM   #3
But how do they actually attatch?
Old July 28th, 2007, 12:33 PM   #4
The ones I have seen use tape, brackets, and screws to attach to the window.
Old July 28th, 2007, 02:07 PM   #5
HessiaN257's Avatar
13.9@101
HessiaN257 is on a distinguished road
http://mustangworld.com/ourpics/fcar/scoops2.htm
13.9@101 before some mods
Old July 28th, 2007, 04:43 PM   #6
ZOOTOXIN's Avatar
ZOOTOXIN will become famous soon enough
The C-pillar scoops install the exact same way the OEM ones do. They are a total replacement so the pins go into the same holes. The adjusting comes into place when the pins don't line up well with the holes on your car (this is do to normal racking). In that case you simply use a dremmel tool and grind away the epoxy that is holding the out of alinement pin and you simply adjust and repoxy. You absolutely want a pro body person to install and paint but if you must do it yourself, at least make sure you are indoors because you can plan on the pillars being off the car for about 2 days. It is an easy job but time consuming.
zo賓付ox品n (zō'ə-tŏk'sĭn)-animal poison; venom
Old July 28th, 2007, 04:44 PM   #7
ZOOTOXIN's Avatar
another pic. This is a set I was selling for 100.
Old July 28th, 2007, 05:27 PM   #8
Thanks... Thats exactly what I needed.. I never saw the back so i was just a little confused. I think I'm going to get it and have my boyfriend put them on... He should be able to handle it. Thanks so much!
Old July 28th, 2007, 05:40 PM   #9
scout's Avatar
scout is on a distinguished road
c-pillar
hello do you still have those c-pillars for sale.
Old July 29th, 2007, 04:22 PM   #10
ZOOTOXIN's Avatar
Re: c-pillar
Yes, I just never sold them because it isnt a simple install. Like I said you might have to move a pin. Plus you have to prep the fiberglass before painting. For that reason they are sold as is. I just dont want someboby saying Id rather not do that work and want to return them. I really dont want to deal with all that. If you are a person who can and loves to put in the time I will sell them to you. The pillars will be off your car for about 2 days. A do-it-yourselfer with a garage would kill for these pillars. They arent damaged in anyway. 100 plus shipping. I am in Balt MD.
Old July 29th, 2007, 05:36 PM   #11
Murderjetz's Avatar
Murderjetz is on a distinguished road
Send a message via AIM to Murderjetz Send a message via MSN to Murderjetz
are there any made for the SN95 that actually look good?
Listen to my music | Visit my garage
Old July 29th, 2007, 07:06 PM   #12
ZOOTOXIN's Avatar
is the SN95 body the 95 to 98? if so, then yes, they are the exact roof as the 99-04. so any c pillars made or newedge will fit yours. check out www.abcexclusive.com for pillars.
Threads Similar to: C-Pillar Scoops
Gauges For A-Pillar Mach Boy 99-04 7 November 11th, 2007 10:11 PM
Guage Pillar Garhfer 99-04 7 June 11th, 2007 06:34 AM
Rear Louvers and c pillar scoops Ensit Mike 2005 - 2010 11 February 27th, 2007 06:10 PM
c pillar scoops chrish91286 V6 Mustangs 6 January 18th, 2007 08:59 PM
