Dual Halo Projector Headlights with LEDs
Old October 24th, 2007, 12:50 AM   #1
dasoccerbomb is on a distinguished road
Send a message via AIM to dasoccerbomb
OK so stupid question for someone out there to answer
I bought the Dual Halo Projector Headlights with LEDs off eBay and let me tell you they look freaking awesome. Anyway after hours of reading different posts i decided to seal them with RTV.
OK ... so my question is how in the world can you replace the high beam buld now that you have completely sealed your lights shut?
Thanks
Old October 24th, 2007, 03:03 PM   #2
wadepetersen is on a distinguished road
not sure but my bet you would be you have to cut them bitches open
Old October 24th, 2007, 05:02 PM   #3
slownomo is on a distinguished road
not sure how you would change them but
WHERE did you find the dual halo's? I see tons of single halo's out there but would rather have 2 seems they are easy to get for 99 up but 98's have only one as far as I've seen anyhow
Old October 24th, 2007, 05:29 PM   #4
I actually have on 04 mustang. I got my halo's off ebay
Sonic Blue 2004 Mustang GT
* Steeda Tri-Ax Short Shifter
* Motive 3:73 rear gears
* White Face Gauges
* Flowmaster Series 40 exhaust
* K&N fipk Cold Air kit (Generation2)
*Dual Halo Projector Headlights with LEDs
* more to come......
Old October 26th, 2007, 12:29 AM   #5
ZOOTOXIN's Avatar
ZOOTOXIN will become famous soon enough
Re: Dual Halo Projector Headlights with LEDs
Thanks
FIRST COMPLETLY COVER LENS WITH TAPE AND PLASTIC TO PROTECT
you are to reseal the casing-where the front clear plastic meets the black back housing. You must use marine grade epoxy. The part where you change the bulbs you just use a little outdoor water proof silicone (that area is fine and this way lights can be changed easily). you must completely remove the rubber stripping off of the top of the lights and replace when you are done with double sided tape. dont worry the non OEM lights rubber strip is originally put on with double sided tape cut in small strips. the reason you must do this is that top groove under the stripping is the place that will leak the most. that is where the water channels.
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
Threads Similar to: Dual Halo Projector Headlights with LEDs
Halo projector headlight install. GreenFaleen V6 Mustangs 47 December 22nd, 2006 10:45 PM
halo and projector headlight and front turn signal recalls spicetraders Audio/Video 4 December 1st, 2006 10:52 PM
Dual Halo Projector Headlights 97TunedMustang Visual 24 November 16th, 2006 04:53 PM
Projector Headlights Conversion To HID... 97TunedMustang Visual 1 September 21st, 2006 04:04 PM
