LinkBack (1) | Thread Tools |
#1
1995 Mustang V6
Installing Gauges.
I just got my reverse glow gauges and I was wondering about how long it will take to install? I already have the steps/walkthrough from AmericanMuscle.
Also, my gauges came as a whole white piece including the area where the turn signals & brights signals are and the bottom where the "check engine", bater and "theft" lights are. I just want the circle gauges to be white. Can I cut out those parts? Has anyone done it? My gauges would look something like this (click larger image): Ford Mustang Silver Reverse Glow Gauges (94-95 GT) at AmericanMuscle.com - Free Shipping! I want something like this (just the circles): AmericanMuscle.com - Customer Images - View
cuttin them may mess the wiring up in the guages,just send them back an get the others u want, the one piece may look better installed then u think they will look
i agree that cutting them will prob mess them up.
-2000 GT Vert- Grabber Blue Paint, Cervini Stalker Hood, Xenon Front/Saleen Rear Bumpers, Bullitt Side Scoops, 18"FR500 Wheels, CDC Bar And Much More! |
2004 Mustang V6
![]() iTrader: 1 reviews
the bezel makes it so it looks like that. Those are most likely the same gauges. Just installed mine. If you want an idea of what it will look like installed, undo the two torx screws holding in the lens and bezel pull it off and hold it up to the gauges not yet installed. If you still don't like it, replace the gauges with something else.
+1 do not cut, if you want a reason why flip over the gauges and see on the back where the stuff to make them glow goes. |
#5 | |
1995 Mustang V6
![]() Has anyone had experience doing this?
what cuttin the pieces off or install the guage
1995 Mustang V6
Yeah. Or any general tips for installing them.
2004 Mustang V6
give yourself time and leave off lens when you first install the gauges.Then drive and put the gauges where they should be. Take a pic of gauges with car off, car on accessory, and car running. It will take more than one try to get the needles right, mine are still a bit off, but then again my gas was off since i had the car. PITA but definitely looks good. I found a good place for the switch if you want a pic, dont know if our interiors are alike.
2002 gt vert
i got mine from brothersperformance.com
bbk speedware series they came with self adhesive on them they came with step-by-step DETAILED instructions and a tool to take your needles off plus they look sweet
2002 mustang gt vert. 18' bullitts k&n drop in air filter flowmaster mufflers soon to have mac off road x pipe and steeda udp pullies |
#10 | |
1995 Mustang V6
Yeah, that pic would be great! I have no idea where to put my switch.
Wax on, Wax off
I love the look for the white face guages, but I had a nightmare installing them in my last car (cavalier).
I was told I could just slip the new face over the needles, however when I tryed I could not get the guages over the needles because some were facing different angles and I would break the white face trying to bend it over them. I ended up having to take the needles off and sending my cluster to get recalabrated for $80. I would love to get some for my Mustang, but the fear of going through that is scary. The BrothersPerformence ones seem to have a tool for removing the needles, but I am worryed about getting them in the right spots again
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
Well Zat, I had that problem with my Eclipse but I just kept on messing with it until I got it, all you have to do is turn the key over to ACC, dont start it, and take a pic with your cell or something, or just do it with a full tank of gas and the car cold, so you know where they go.
2004 Mustang V6
use torx screwdriver to get off the lens your going to have to anyways to change gauges. Will have pic when my girl comes over, I dont own a camera
#14 | |
1995 Mustang V6
How to Install Mustang Gauge Inserts Any other suggestions?
2004 Mustang V6
Once you have the gauges on,(I had to take off the old gauge and super glue the new one on) put the needles where they are in the first picture(car off). Install gauge cluster without lens(pic of lens being pulled off below)
![]() and without the dash panel. Plug in gauge cluster, reconnect battery, and start car. Once your car is at its normal idle check to make sure the rpms are correct, if not readjust needle. Then check batt, oil, and fuel and adjust if necessary. This is the hardest part and should be done very carefully(i am not responsible if anyone wrecks their car). Drive on a 4 lane road, get a friend to drive along side of you and make sure your mph is correct. If it is not correct it. The only problem i currently have is that my speedo is 5mph off(reads 50 when going 45) but I cannot put it any further down because when i turn off the car it pushes on the little pin that stops the needle. Good luck and let me know how it goes. Will post switch pic later |
dam why dont u just draw u a diagram out of the cluster an an mark where everything goes,better than goin down the road an trying do that an trying not to wreck
2004 Mustang V6
did that and they were not accurate when put in car for whatever reason
1995 Mustang V6
Thanks guys. Anything else?
04DSGV6: Any word on that pic of the switch. Just wondering.
never had no problem doin it that way on the ohter truck,then on the mustang it was a 3 piece an was easy
2004 Mustang V6
LinkBack to this Thread: http://www.moddedmustangs.com/forums/visual/60488-installing-gauges.html
| Forums at Modded Mustangs | This thread | Refback | March 14th, 2008 12:26 PM | |
Threads Similar to: Installing Gauges.
| Installing Top | jblood37 | General Tech | 1 | October 25th, 2007 06:19 PM |
| INSTALLING AN AMP | 1BADSTANG | Audio/Video | 1 | October 1st, 2007 10:29 PM |
| installing an amp | 1BADSTANG | 5.0 Mustangs | 0 | September 29th, 2007 10:45 PM |
| need help....i'm installing my JLT CAI..... | MyLittlePony | 2005 - 2010 | 13 | March 16th, 2007 10:12 PM |
| Installing Elec After Market Gauges | mustang44 | V6 Mustangs | 2 | November 18th, 2006 05:56 PM |
