Discussing remove stickers in the Visual Forum. whats the easyest way to take off the mustang stickers on the side of my ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1998 mustang V6
0.2@speed of light
remove stickers
whats the easyest way to take off the mustang stickers on the side of my car? check out my garage for pics!!!
2004 Mustang V6
bad idea. Your car is a 1998 that means that your paint on the rest of your car has seen 10yrs of weather and such and the paint under the sticker hasn't seen anything. When you take off the stickers the paint is gonna look way different.
'02 GT-Under Construction
8.15@86 (1/8)
That sucks but it's true
07 GT500 & 2002 GT: See Garage For Mods: http://www.moddedmustangs.com/forums...-member-12476/ TEXAS MUSTANG CLUB
1998 mustang V6
0.2@speed of light
but i figure since the car is black you might not notice it as much i really dont like em so what other options do i have
91 Sonic Blue Goodness
19.83 @ 12mph
a blow drier, windex a razor and a very steady hand.
2001 Mustang GT
UNKown
you will
Mods: -PyPES cat back -Ford racing springs -Tires 275/17x9F & 285/18x10R -S&B Cold air intake -R498 10" Fixed Black mist Antenna ![]() ©1969-2008 |
19.83 @ 12mph
^ it can be buffed out
1998 mustang V6
0.2@speed of light
so whats the blow drier for?
19.83 @ 12mph
to heat the glue
1998 mustang V6
0.2@speed of light
so blow dry it first, then sray with windex, then razor it off
19.83 @ 12mph
blow dry one end of it to get the glue soft.. try and peel it up with a finger nail..
if that doesn't work use the razor. from there slowly peel using the windex to keep everything wet. |
1998 mustang V6
0.2@speed of light
ok thanks ill try it!!
2001 Mustang GT
UNKown
on my other car i tried and tried and tried ..took it to a shop and you could still see the imprint from the logo
![]() best of luck !
1998 mustang V6
0.2@speed of light
yeah but it looks a lil better because its like a shadow!
02 ROUSH STAGE 2
[quote
if that doesn't work use the razor.[/quote] they make plastic razor blades for this also Plastic Razor Blades |
2004 Cobra
Agreed .. heat the stickers and they should peel off. I used some bug/tar remover (ford brand) to get the glue off. Wash it good and put some polish on it should be good to go (hope the paint matches)
2008 Mustang GT
i used the blow dryer and it worked fine. no marks...my car has been housed in a garage until a few monthes ago so not too much weather damage
#18 | |
A blow dryer and WD-40
zo•o•tox•in (zō'ə-tŏk'sĭn)-animal poison; venom
1989 SILEIGHTY
.0045 on Kumho 712's
Yeah, if you straight peel it you might yank off some clear coat.
removing a decal from a car
if you are removing a decal from a car that is on a painted area, don’t use a metal razor blade as its easy to scratch the paint. Depending on the size of the job (i.e. small or large) I know of 2 products. There is a video demo at Wonder Products | Removing Decals, Vinyl and Stickers the Easy Way[/url]. (one does big areas and the other small areas) Hope this helps. P.S if you need a cheap product that is chemical free to remove the goo or adhesive, try eucalyptus oil (its chemical free and available at most supermarkets).
Threads Similar to: remove stickers
| stickers | 01 mustang | Visual | 8 | May 4th, 2008 01:59 AM |
| mm stickers | uconnV6 | The Clubhouse | 13 | April 24th, 2008 09:41 PM |
| mm stickers!!! | mystang0673 | 99-04 | 2 | March 22nd, 2008 07:47 PM |
| stickers | 91foxhatch5.0 | Feedback Forum | 9 | June 2nd, 2007 04:24 PM |
| mm stickers | 232stang | The Clubhouse | 20 | March 20th, 2007 02:14 AM |
