Discussing Under the rear deck lid! in the Visual Forum. Does anyone know how to clean the small area around the trunk opening? Ya know ... ...
Old May 27th, 2008, 10:58 AM   #1
'02SilverBullet's Avatar
Does anyone know how to clean the small area around the trunk opening? Ya know ... open the trunk.... ya got the weather seal around the trunk opening then outside that weather strip... there is the "sunk in" area like where the deck lid stuts mount. I dk if im explaining this right or if you guys get the picture but anyhow.... My chit is dirty as hell in there. There is dirt caked up and thick in that area I descibed. Was wanting to know if anyone has found a easy way to clean that?
Mods Include......
BBK CAI
MM Caster Camber Plates
Baer Decalla Drilled and Sloted Rotors
w/ painted callipers
Hypercoated 18x9 FR500 Rims
Eibach Pro Kit Lowering Springs
More to come.....!
Old May 27th, 2008, 11:04 AM   #2
I just use simple green and a rag then wipe it with a wet rag
Old May 27th, 2008, 02:57 PM   #3
Bullitt2445's Avatar
2001 Bullitt #02445
You mean you let your car get dirty?
2001 Bullit #02445 built in the only color Henry would build- Black.
Old May 27th, 2008, 03:14 PM   #4
Thats just how I KEEP mine clean...
Old May 31st, 2008, 05:42 AM   #5
Moderator
travis_afx's Avatar
'02 GT
your just gonna have to get a cleaner of your choice and wipe it away. I use the foamie(sp?) glass cleaner, spray a librel amount in the channel and wipe it out good.
BBK CAI, 75mm BBK TB, Trick Flow plenum, U/DP, spec clutch, short throw shifter, adj. upper cntrl arms, lower cntrl arms, 50/50 shocks, MAC exhaust, 4.10s, SCT flip switch
Threads Similar to: Under the rear deck lid!
05-08 Deck Lid Trim Panel For Sale demon-cleaner Exterior 0 April 8th, 2008 03:42 AM
rear deck lid panel pyro348 V6 Mustangs 1 January 11th, 2008 03:15 AM
fiberglass rear deck lid? impetus 2005+ 3 July 14th, 2007 09:52 AM
mounting 10" kickers on rear deck? GTstangB.F.D.M. 2005+ 7 April 2nd, 2007 04:41 PM
Rear Deck Speaker Install King Mustang V6 Mustangs 8 November 13th, 2006 06:02 AM
