01 driver door panel
anybody have a diagram to show me how to take of the panel my window came of track and i think its just loose
Rebel Of The Sacred Heart
'02 GT
I would take the tweeter off if you have a mach system, yhou dont have to but it makes it easier to get the door panel off. To do this just pop the front cover off the tweeter and there is a screw that holds it on. Then unplug the connector and set it aside.
First pop the panel off that houses the switches. Do this by gently prying on the panel with a flat head screwdriver. ![]() Then unplug your mirror control if its the drivers side door. Next remove the screws that hold the window switch on. ![]() Now you will be able to get to the two screws holding the dor panel to the door frame: ![]() Then there is a plastic fastener on the front edge of the panel by the speaker that needs to come out. If you dont have the tool for it you can use a flat head screwdriver or pliers or something. If you mess the fastener up you can get one at your local parts store for cheap. ![]() After all that is done then just grab the panel on both sides and pull up and it will come right off
Travis Billings May 6, 1982 - July 5, 2011 Rest In Peace brother, you will be missed.
thanks man
'02 GT
Your welcome
how do you pop the tweeter cover of does it slide or just pull off?
'02 GT
It pulls off, i use a flat head tp pry it off at the bottom using the door panel as a leverage point. It will take a little effort but it will pop off.
Threads Similar to: 01 driver door panel
| Driver door lock is stuck. Can't open door Help!!!! | White 89 | 5.0 Mustangs | 25 | April 26th, 2011 12:49 PM |
| the door panel | stinglikeastang | V6 Mustangs | 26 | January 8th, 2009 12:23 PM |
| door panel | 1fast5.0 | Visual | 0 | February 5th, 2008 09:16 PM |
| door panel | Nameless122 | The Clubhouse | 0 | November 19th, 2007 04:54 PM |
