swapping a automatic 2.3 to a manual - Page 2 - Forums at Modded Mustangs
post #21 of 35 Old January 7th, 2013, 04:41 PM Thread Starter
1993 Mustang LX Hatchback
nickleo0430's Avatar
Send a message via MSN to nickleo0430 Send a message via Yahoo to nickleo0430
thats understandable
mine isnt really a daily driver so im considering the side exhaust seriously
1993 140 2.3L I4 Ford Mustang LX Hatchback
2006 269 4.3L Vortec V6 Chevy Silverado C1500 2WD SWB
1990 350 5.7L Vortec V8 Chevy Silverado K1500 4WD SWB
Not a cowboy, but no damn city slicker either
Just pure Bama Boy
nickleo0430 is offline
post #22 of 35 Old January 8th, 2013, 02:44 AM
Rider
Arummel, didn't stinger discontinue that adapter plate or something? On their site it just says no longer available for that plate...
90 lx 5.0 twin 54mm turbo kit, soon to have nitrous, radials and a t56
Falconman is offline
post #23 of 35 Old January 8th, 2013, 09:32 AM
Resident Know-it-all
nxcoupe's Avatar
Another company started selling them. Do a search online, you,ll find it. And for the record, a V8 trans will slide right into your 4cyl bellhousing. The adaptor and special flywheel from spec, allow the larger flywheel and 10.5" clutch to be used, along with a scattershield if you want.
92 coupe, pictured^, coyote power with turbo.
93 coupe, 2.3 turbo 5spd
93 calypso no option coupe, 94 GT, 90 Coupe, 82 coupe, 12 5.0 6spd, 14 gthig gt auto.
nxcoupe is offline
post #24 of 35 Old January 8th, 2013, 10:19 AM
Send a message via Skype™ to arummel93
This^
Can't remember the name of the company off the top of my head.
As for the V8 trans on 4cyl bell, it will bolt on, but the V8 input shaft is different. You'll either have to have the v8 input shaft turned down to accept the 4cyl bushing, buy an adaptor bushing (Rapido group sells them but they are a pain in the ass), or turn out the crank to use all the v8 stuff.
arummel93 is offline
post #25 of 35 Old January 8th, 2013, 10:35 AM Thread Starter
lol well either way we will figure it out
Just pure Bama Boy
post #26 of 35 Old January 8th, 2013, 10:37 AM
We can fix it. We have the technology.
post #27 of 35 Old January 8th, 2013, 12:00 PM Thread Starter
sometimes the tech gets confusing too tho
Just pure Bama Boy
post #28 of 35 Old January 16th, 2013, 10:00 AM
Lankolf's Avatar
Send a message via MSN to Lankolf
Go on Car-Part.com--Used Auto Parts Market and look up the stock t5 transmission for your year. You can probablly find a junkyard close by that will have a car with all the parts you need. I just did the swap last week so if you need any help I can walk you through it. Definatly do it though, you'll gain a respect for your 2.3l you never knew you could have. I almost enjoy driving my 2.3l 5 speed as much as my 5.4l five speed.
1965 Mustang GT Coupe
1992 Mustang LX 2.3L (SVO turbo swap underway)
1996 Mustang GT 5.4L Swap (Sold)
1997 Mustang 3.8L (R.I.P)
Lankolf is offline
post #29 of 35 Old January 17th, 2013, 11:31 AM Thread Starter
awsome thanks
Just pure Bama Boy
post #30 of 35 Old January 31st, 2013, 02:43 AM
SVO Shark
Modded 2.3 1986 SVO
Hey guys. New here so i'm not sure of any kind of format you might use. I am buliding my first engine. 2.3 Turbo and here is what I got so far. Esslinger Alum ported and polished head with the 2277 roller cam. Stinger center mount exhaust. Precision 6262 72mm Turbo. Spearco front mount intercooler. Gutted upper intake turned 120deg. Ported lower intake. 255lb walboro fuel pump. Adjustible fuel pressure regulator. 3in exhaust, no cat with magnaflow muff. AFR meter, Megasquirt 3 with 2 step and no lift shift. 8.8 Rear end. 96lb injectors. I Plan to add 2stage nitros and water meth injection next. Waiting on the megasqirt due in this week. I'm hoping for close to 500hp. Can anyone tell me what else I might need to make this happen and be reliable. I plan on driving it from time to time so it's not a straight drag car. Just a scary street ride. Thanks guys. Later I want to stroke it but first I need to get this part done and tuned.
SVO Shark is offline
post #31 of 35 Old January 31st, 2013, 02:49 AM
Start a new thread.
Sounds like a nice build though. What trans are you putting behind it to hold up to that power?
And welcome to MM! Always nice to have another turboford guy around
post #32 of 35 Old January 31st, 2013, 08:59 AM
Lankolf's Avatar
PICTURES!!!??? Sounds too good to be true!
Lankolf is offline
post #33 of 35 Old January 31st, 2013, 02:32 PM
Nah, it ought to be able to make that with the essy SVO head and supporting mods. As long as your bottom end is able to handle it. But the rest of the car needs to be able to hold that power
post #34 of 35 Old January 21st, 2014, 03:40 AM
Look Ma! My First Post!
joel
Hello, I need aome help. I have a 2.3 mustang 1993 automatic bit i want to convert it
To a manual transmission. Would some one help me listing what i need.
joelj is offline
post #35 of 35 Old February 5th, 2014, 05:52 PM
i found the new place selling the bellhousing adaptor for 185 new im doing the same swap on my 93 lx notch i have every thing but this adaptor plate, clutch, and the t5 itself waiting on taxes to come in to get them
http://cididit.com/adaptor_plate.htm
---------- Post added at 09:52 PM ---------- Previous post was at 09:43 PM ----------
2.3L Ford Adaptor Plate - Canfield Industries Fort Collins, Colorado
93notchcarbed4.6 is offline
