what ecm /comp. - Forums at Modded Mustangs
post #1 of 5 Old July 1st, 2014, 07:41 PM Thread Starter
what ecm /comp.
what years ecm can i use ? i have 83 2.3t from thunder bird in 29 model A
and have ecm. from 83 but dont know what years /model i can use. this has air, and C3 auto trans. THANK YOU. ENGINE is STOCK.
firewheel is offline
post #2 of 5 Old July 1st, 2014, 10:53 PM
Mikel89us's Avatar
Send a message via Yahoo to Mikel89us Send a message via Skype™ to Mikel89us
You sure its an 83??? I think the turbo coupes were only made from 85-88
1991 Mustang LX 2.3L 5 Speed convert
1989 Ranger 4X4 2.5L 5 Speed solid Dana 30 front axle, 4.5" suspension lift, 3" body. ( blown up....)
Entire turbo kit waiting to be used again.
Mikel89us is offline
post #3 of 5 Old July 2nd, 2014, 12:21 AM Thread Starter
83 ecm
Yes # on ecm is E3ZF-12A650-A1A TA EEC-1v EFI -TC This year is hard to find. so i am looking to see if more years will fit .
THANKS
post #4 of 5 Old July 3rd, 2014, 02:24 PM
OHC230's Avatar
Yes, I used to own an 83' TC. Any of the turbo ECU's can be made to work with the engine. The preferred one's are from the 87+ TC, with the LA box-codes, but really, if you're serious about engine tuning and want to get the most out of your engine, I would seriously consider using a tuner device, like the Moates 1/4 horse, to tune your current ECU.
It can take some digging on your part, but there are BIN files available to drop the vane air meter from the system as well as a host of other mods that really make a difference with overall engine performance.
OHC230 is offline
post #5 of 5 Old July 7th, 2014, 09:21 AM
THANKS
That is the engineering number, not a production year number.
Many times Ford would run engineering part numbers for several years before they needed to be 're-engineered'.
You are likely looking at the engineering number for the ecu case.
as stated, you should be able to sort it out, but tuning it would nice if you could tune it...
The LA3 ecu's have great support (87-88 tbird), and some of the mustang MAF 2.3 ecu's have pretty good tuning support as well.
vristang is offline
