351 swap in my fox... - Forums at Modded Mustangs
post #1 of 52 Old December 16th, 2010, 10:30 PM Thread Starter
I was currently building my 306. I have a chance to to get a smokin deal on a 351w short block he says its fully forged 10:5:1 compression but is not sure on the internals.. So tom going to go an pull the oil pan an look at it..
For my current build I have brand new trick flow upper (heads. 1.7 rocker arms, push rods, lower an upper track heat intake 30lb injectors, 76mm maf an fuel rails, all new gaskets.)
So heres my questions.. Will all my parts bolt on to the block? ( I think I will have to replace the push rods) I know I need a new distributor, mounts an headers, oil pan an oil pick up..
If any one has any knowledge or experience with this swap any info would be greatly appreciated... Thanks
Ijuswan2gofast is offline
post #2 of 52 Old December 16th, 2010, 11:21 PM
FastStang91Lx's Avatar
You have to know what heads you are using before you can determine a compression ratio, meaning what cc combustion chamber puts that motor at that ratio? Couldn't tell what you have for heads, stock or TF?
FastStang's Ongoing projects thread Click here!
FastStang91Lx is offline
post #3 of 52 Old December 17th, 2010, 12:13 PM Thread Starter
I have TF 170cc/66cc.. Now will I have to change the bottom intake manifold. I have the TF track heat maniflod.. Thanks for the help
post #4 of 52 Old December 17th, 2010, 01:13 PM
yeah youll have to change it. If youre gona 351 and want to stick with a tf intake get the tfsr
93hatch is offline
post #5 of 52 Old December 17th, 2010, 03:47 PM
+1... and those heads are maxxed out for a revving 351, so if you ever stroke it, plan on a different set.
post #6 of 52 Old December 17th, 2010, 03:51 PM
na theyll be fine. Tons of people making good power with 347s and ootb tf 170s, his wont be as fast as them but itll be alright. And why get another set when he can send them to tea for their 205 cnc program
93hatch is offline
post #7 of 52 Old December 17th, 2010, 03:59 PM
That too...
I would call my 185 cnc's just right for a 347 or 351, but I too will have to send them out if I ever go bigger
post #8 of 52 Old December 17th, 2010, 06:27 PM
Waste of money. heavier motor for roughly the same hp.
flattusmaximus78 is offline
post #9 of 52 Old December 18th, 2010, 08:36 PM
93lxreef's Avatar
Not necesseeerrrarlilly....The 351w will out torque a 347 hands down. I know and love em. When I buy a fox, first thing I do is find a buyer for the 302, and in goes the windsor. The 9.5 inch deck height is hard to beat!
93lxreef is offline
post #10 of 52 Old December 18th, 2010, 08:42 PM
The trick flow top end will make a little more hp and more tq than a 302, but the 351 is heavier. If you want a 12.5 fox that traps 109 and tell people it has a 351 go for it. I'd rather put the kit on the 302 and do the same thing.
post #11 of 52 Old December 18th, 2010, 08:43 PM
What exactly makes a 351 out torque a 347? The heavy ass rotating assembly?
93hatch is offline
post #12 of 52 Old December 18th, 2010, 09:05 PM
fogged306's Avatar
Nah, it's the 4 extra cubes.
fogged306 is offline
post #13 of 52 Old December 18th, 2010, 09:07 PM
93lxreef's Avatar
If you want a fox that traps 12.5 buy a 347. If you want a fox that will trap 10.5, lose the 170 heads, buy some 225's, and a stroker kit for the 351. Don't get me wrong, 347's are great.... if you like 12's. I in my honest opinion building an engine that would only do that is the waste of money....
Rotating mass=torque. Also, the longer rod of the windsor naturally gives more mechanical advantage to create torque.That's without even stroking it.
An aluminum headed windsor will probably weigh about 50lbs more, you'll more than make up for it in power. I've done it. So have thousands of others. It's no secret!
93lxreef is offline
post #14 of 52 Old December 18th, 2010, 09:10 PM
Fucking wasted my goddam money on a 347 shoulda pulled a 351 from an f250 and been faster. Fuckmylife
93hatch is offline
post #15 of 52 Old December 18th, 2010, 09:37 PM
fogged306's Avatar
Rotating mass= less acceleration
fixed
post #16 of 52 Old December 18th, 2010, 09:49 PM
93lxreef's Avatar
Yeah, yeah, give me till the spring and we'll post time slips.
"You can lead a kid to water but If you hold his head under they'll arrest you"
93lxreef is offline
post #17 of 52 Old December 18th, 2010, 10:16 PM
Lmao oh noes hope its not faster than my 347 -_-
93hatch is offline
post #18 of 52 Old December 18th, 2010, 10:37 PM
fogged306's Avatar
This will prove nothing unless you have a 351 and a 347 with the exact same top end on it and each had a custom cam and then you had the exact same weight/suspension/trans/exhaust ect. car. Argue all you want, all things equal the 347 will outrun the 351 all day long. Of course a stroked 351 will be faster, but stock stroke 351 won't. Do some research if you don't believe me.
post #19 of 52 Old December 18th, 2010, 10:54 PM
93lxreef's Avatar
With all due respect....not trying to argue all things equal. Just saying that with a 347 you are limited by how much power you will ever make. Period. with the 351 you can stroke it and make waaaaayyy more horse power than the little 347. If you're ok with that, cool. If you want 600+ hp later, get the windsor....that's my plan. My car is a weekend toy, not a DD.
Honestly, if I were to build a daily driver, I'd probably go 347. But I'm gonna be the guy that shuts up the shit talkers and make more power. peace.
Coming soon.....408w TKO tremec.....
NEVER enough horsepower!
93lxreef is offline
post #20 of 52 Old December 18th, 2010, 11:06 PM
HMERacing's Avatar
I want a stroked 351W now! maybe a 427
Mike
1989 Mustang LX, 2001 Transam WS6
Originally Posted by 302Army187 View Post
I'm going to install an U pipe.
bitch is going to re route the exhaust pulse back out of the intake between intake pulses.
HMERacing is offline
