funny idle problem - Forums at Modded Mustangs
post #1 of 2 Old May 27th, 2007, 02:25 AM Thread Starter
fastford3388's Avatar
Send a message via AIM to fastford3388
funny idle problem
Just wondering what could be causing this problem. I'm getting a funny idle that revs kinda high and goes back down low but only when i just start it up. check engine is throwing a EGR valve position sensor gone bad but i have replaced it once. also, when i'm off the throttle the car seems to lose power and when i'm slowing down it seems to rev a little high. could i have a crack in my intake gasket? vacuum leak? any help would be awesome.
- '90 Mustang LX-Sold "Debbie"
- '89 Mustang GT- Deceased "Lucy"
- '91 Mustang GT-70,000 mi "The Unicorn"
fastford3388 is offline
post #2 of 2 Old May 27th, 2007, 06:51 PM
all motor
SALIV8's Avatar
pull the vacuum off the egr and see if it stumbles which it shoud do at idle, if it doesn't there's ur problem, then check your iac pull it and spray carb cleaner and put back that should help.
SALIV8 is offline
