8.8 upgrades to handle future motor - Page 2 - Forums at Modded Mustangs
post #21 of 70 Old November 18th, 2012, 08:22 PM
PhD in Procrastinology
1BDSTNG's Avatar
Originally Posted by foxfive View Post
C-clips lock the axles in place near the differential. If you look at the spline of the axle there is a groove in which the c-clip goes.
Thanks
1991 GT- 347ci
2014 GT/CS
Instagram: @1bad_5oh
Originally Posted by Imran View Post
i clamp it with my teeth and hold it in my mouth.
1BDSTNG is offline
post #22 of 70 Old November 18th, 2012, 10:29 PM
PipeGluer's Avatar
yeah otherwise your axleshfts would fly out. and you wouldnt be doing much lol'ing...
PipeGluer is offline
post #23 of 70 Old November 19th, 2012, 05:51 PM
ryanw's Avatar
On the 9" ends... what holds the axles in if theres no C clips ?
Oh and over on fbp, didnt it turn out the flyinryan was also people champ ? I tried hanging out there but other then the first few months, it died.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
ryanw is offline
post #24 of 70 Old November 19th, 2012, 07:46 PM
FastStang91Lx's Avatar
The bearing is pressed on the axle and then it's held into the end via a retainer and bolts.
FastStang's Ongoing projects thread Click here!
FastStang91Lx is offline
post #25 of 70 Old November 19th, 2012, 07:54 PM Thread Starter
mr. chokebot
WillyT's Avatar
unicorn poop
WillyT is offline
post #26 of 70 Old November 20th, 2012, 07:18 PM
The Big Spoon
jessemachone's Avatar
makes sense about flyinryan!
Willy, where do you get unicorn poop? I'have been looking for that stuff high and low - much better than gorilla glue and jb weld.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
jessemachone is offline
post #27 of 70 Old November 20th, 2012, 07:36 PM Thread Starter
mr. chokebot
WillyT's Avatar
WillyT is offline
post #28 of 70 Old November 21st, 2012, 04:12 PM Thread Starter
mr. chokebot
WillyT's Avatar
Any preference on carrier bearings? I'm seeing lots of ratech and motive gear.
WillyT is offline
post #29 of 70 Old November 21st, 2012, 04:29 PM
Priest of the Car Gods
ReverendDexter's Avatar
Just FYI, if you're not drag racing, a stock 8.8 will likely be plenty strong. It's the torque-shock of a drag-lauch that breaks things, not rolling on the throttle coming out of a corner. Now, that's not to say don't build your 8.8, but I wouldn't go crazy building a rear end that can handle >9000 lb-ft of torque for a road-race car, as you're just adding unsprung weight that you don't need.
Also, if you're not drag racing, I'd go with a Torsen T2-R, not a Detroit, definitely do whatever you need to do to eliminate the C-clips, and then spend some of that money you're talking about on a disc brake conversion (assuming you still have drums).
Function > Form, always
ReverendDexter is offline
post #30 of 70 Old November 21st, 2012, 05:10 PM Thread Starter
mr. chokebot
WillyT's Avatar
It's going behind a 408, so I'm erring on the side of caution.
What are some advantages of a T-2 over the TruTrac? The TT was recommended by a friend of my father, who has done road racing since the 70's.
Yep, still have drums. Either Baer or Wilwood, haven't made up my mind yet. The Wilwood I can get at-cost, so that's pretty attractive.
WillyT is offline
post #31 of 70 Old November 21st, 2012, 05:21 PM
I'm not an expert when it comes to the differneces in the behaviors between different limited-slip differentials, but my understanding is that Detroits come on more aggressively, which can unsettle the car under hard acceleration. The R version of the Torsen T2 is what I've seen Griggs recommend and use (I believe MaxMo as well), and apparently it basically acts like a spool except in low-speed cornering situations, which makes it very predictable. Basically, instead of being open until the unit senses slip, the T2R is locked under normal conditions, and allows slip as necessary.
I'm not sure if the T2R has the fault like other torsens where if one wheel completely loses grip (i.e. in the air) they act like an open diff. I'd assume not, but I'd double check that assumption before spending a grand on a differential.
Someone with more personal experience may have more to add.
post #32 of 70 Old February 1st, 2013, 04:26 PM Thread Starter
mr. chokebot
WillyT's Avatar
Well, guess it's time to get started!
Last edited by WillyT; November 20th, 2013 at 09:09 AM. Reason: updated image link
WillyT is offline
post #33 of 70 Old February 1st, 2013, 08:28 PM
Muratic acid will wipe that rust away from a cheap spray bottle. Very caustic though, must be used outside or in a WELL ventilated area. Just keep hosing it down periodically. Will etch concrete too, FYI, so don't go crazy. Rinse when done and abruptly dry and coat it.
post #34 of 70 Old February 1st, 2013, 10:15 PM Thread Starter
mr. chokebot
WillyT's Avatar
I work in a machine shop with all kinds of nasty chemicals. I've probably got 13 different kinds of cancer and don't even know it. I've got plans on how to clean this sucker up
No more drum brakes! Good riddance.
WillyT is offline
post #35 of 70 Old February 2nd, 2013, 06:43 AM
1BDSTNG's Avatar
I'm thinking about buying a spare rear. I can find them for $250 'round here. What's a good price?
1991 GT- 347ci
2014 GT/CS
1BDSTNG is offline
post #36 of 70 Old February 2nd, 2013, 09:08 AM Thread Starter
mr. chokebot
WillyT's Avatar
Paid $100 for mine. Wasn't in the best of shape, water had gotten into it and was kind of tricky to turn at times. But meh, it's all getting thrown out anyways.
Pity you're not closer, in a few months my stock one will be available.
WillyT is offline
post #37 of 70 Old February 28th, 2013, 06:50 PM Thread Starter
mr. chokebot
WillyT's Avatar
mmmmmmmmmmmm clean!
Last edited by WillyT; November 20th, 2013 at 09:11 AM. Reason: updated image links
WillyT is offline
post #38 of 70 Old February 28th, 2013, 07:09 PM
1BDSTNG's Avatar
Me like the shiny. When are the innards going...well, uh, in?
1991 GT- 347ci
2014 GT/CS
1BDSTNG is offline
post #39 of 70 Old February 28th, 2013, 07:29 PM Thread Starter
mr. chokebot
WillyT's Avatar
I have to buy them still
I've got time, the carrier still had to be welded; the ends have to be cut off and the 9" ends welded on.
And then there's April 15th that still has to happen
WillyT is offline
post #40 of 70 Old February 28th, 2013, 07:29 PM
Why not have a Fox?
93Bandit's Avatar
Holy crap! You cleaned that up real good! When ya gonna clean mine??? Hmmm???
Clueless College Kids Slow Budget Fox Build
Originally Posted by 8t6gt View Post
Dont even know what you're talking about. But Aladdin was always the Disney character I trusted the most, so go for it.
93Bandit is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/5-0-mustangs/263838-8-8-upgrades-handle-future-motor.html
overview for thatguywillt This thread Refback March 21st, 2015 11:27 PM
