1991 5.0 HO Miata swap - Forums at Modded Mustangs
post #1 of 6 Old February 12th, 2018, 02:24 PM Thread Starter
Look Ma! My First Post!
Hello guys I'm new to this site. I'm building a 5.0 swapped Mazda Miata. I purchased a 1991 Thunderbird with a 5.0 HO and auto trans. I have stripped the drivetrain, ECU, wiring harness etc. My question is can I use the wiring harness and ECU if I'm using a T5 manual trans. I'm not sure if the harness can be modified into a "hotrod" harness or if I need to go with a different engine management system like Holley or Haltec etc. Thank you in advance!
Greg Johnson is offline
post #2 of 6 Old February 12th, 2018, 08:35 PM
07gtS197's Avatar
iTrader: 5 reviews
You should be fine. I believe the only connectors that goes to the trans are the backup switch connector and the neutral safety switch. You can bypass the switch nss and the backup switch is probably the same thats on the t5.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
07gtS197 is online now
post #3 of 6 Old February 12th, 2018, 09:12 PM
iTrader: 8 reviews
There isn't a neutral safety switch on a T5 if I remember correctly, only the backup sensor.
BA Mustang is offline
post #4 of 6 Old February 12th, 2018, 09:21 PM
07gtS197's Avatar
iTrader: 5 reviews
They do. Regardless if hes using the auto ecu it will be looking for the mlps/nss signal showing that the transmission is in either park or neutral or it wont start. It will need to be bypassed or else it will not start.
I was actually referring to the mlps on the side of the transmission on the aod. It is sometimes called a neutral safety switch but thats only one of its functions.
07 GT Tungsten Gray
02 GT Mineral Gray
98 Crown Vic P71
post #5 of 6 Old February 14th, 2018, 11:31 PM
Qwik Enuff
wbrockstar's Avatar
The T5 doesnt have a nss,but it does havep a neutral gear switch.I dont know if the Thunderbirds and Miatas use them or not,but the (T5) Mustangs use a clutch safety switch & neutral gear switch.The CSS is at the clutch pedal & the NGS is at the T5.The following link details these switches.
NSS/Clutch Pedal Switch Code 67 Troubleshooting
91 LX 342ci (10.5:1)
TFS 190cc (stage ll)
TFS Track Heat
Lunati 61011(.549"/.565")
Flowtech 1 3/4" Shorties
QA1 Coilovers
Weld ProStar XP'S
ISIT EVER ENUFF
wbrockstar is offline
post #6 of 6 Old February 17th, 2018, 11:24 AM
fb93's Avatar
IIRC, the o2 sensor harness for the auto vs. manual are pinned differently, and using the wrong one could kill the ECU.
Found this.
O2 Sensor Harness Differences - Ford Mustang Forums : Corral.net Mustang Forum
fb93 is offline
