4 valve too clean - Forums at Modded Mustangs
post #1 of 17 Old March 30th, 2008, 08:59 PM Thread Starter
4 valve too clean
So I had purchased a 93 GT with a intake backfiring problem and after checking the timing, wiring order, injectors, fuel pressure and rocker nuts, I pulled all the plugs and they all look like normally used plugs but on the #4 valve, it is clean an smells of unburned fuel. Does anybody have any suggestions...I will take any and all at this point, thanks. -Matt-
1982matthew is offline
post #2 of 17 Old March 30th, 2008, 09:15 PM
ryans88gt's Avatar
bad injector? bad plug or wire?
ryans88gt is offline
post #3 of 17 Old March 30th, 2008, 10:38 PM
fogged306's Avatar
Probably not an injector if it smells like fuel. I second the bad plug or wire, maybe bad cap too.
and if you're reading this again ryan... why?? I'm sure you did the avie for the camaro guys, but what did we ever do to you?!
fogged306 is offline
post #4 of 17 Old March 30th, 2008, 10:45 PM Thread Starter
wires, plugs and cap and rotor all ford new......
post #5 of 17 Old March 30th, 2008, 10:55 PM
fogged306's Avatar
have you checked for spark at the plug?
post #6 of 17 Old March 30th, 2008, 10:59 PM
nolife's Avatar
Attach a timing light on your #4 wire and see if it is firing. The injector could be leaking. Do you notice any fuel smell in the oil or is your oil seem thin?
nolife is offline
post #7 of 17 Old March 31st, 2008, 12:04 AM
ryans88gt's Avatar
I changed it just for you, you homophobe
post #8 of 17 Old March 31st, 2008, 12:22 AM
fogged306's Avatar
Homophobe?? I wanted you to change it because my pants got tight every time I read one of your posts!
post #9 of 17 Old March 31st, 2008, 12:25 AM
ryans88gt's Avatar
post #10 of 17 Old March 31st, 2008, 12:29 AM
fogged306's Avatar
Originally Posted by ryans88gt View Post
Oh stop... everybody knows you swallow, you're not foolin' anyone
post #11 of 17 Old March 31st, 2008, 12:33 AM
ryans88gt's Avatar
Nah I prefer to have my face painted.
post #12 of 17 Old March 31st, 2008, 12:38 AM
fogged306's Avatar
ok I'm done spamming this poor bastards thread.
post #13 of 17 Old March 31st, 2008, 02:11 PM Thread Starter
I am a poor bastard.....I can't fix my problem, got spark and oils fine also changed the injectors and still no good.
post #14 of 17 Old March 31st, 2008, 03:00 PM
ryans88gt's Avatar
If it smells of unburned fuel you are looking at an ignition problem I guess. You have confirmed spark at the problem cylinder?
post #15 of 17 Old March 31st, 2008, 04:56 PM Thread Starter
i can pull that plug out and put it in the wire and lay it against metal and i get spark, i am so puzzled right now.....working on cars everyday and not being able to figure this out is pissing me off...
post #16 of 17 Old March 31st, 2008, 05:36 PM
fogged306's Avatar
If you pull the #4 plug wire and run the car, does the backfire stop? Maybe you have more than one problem on your hands. From my experience, backfire will only happen if you have a bad intake gasket, or your intake valve is bent, or the intake valve is open at the wrong time (timing), maybe I'm missing a thing or two there, but those are all I've seen.
post #17 of 17 Old March 31st, 2008, 06:51 PM Thread Starter
thanks for suggesting that I didn't take notice I will try that and see. Its pouring right now so I will have to check it tomorrow.
