Timing - Forums at Modded Mustangs
post #1 of 7 Old January 8th, 2006, 12:19 PM Thread Starter
Timing
What is the differnce timing chain or gears Which one is better.
Max
max5.0 is offline
post #2 of 7 Old January 8th, 2006, 12:26 PM
mdvaldosta's Avatar
You've got both. The timing chain goes around the timing gears.
mdvaldosta is offline
post #3 of 7 Old January 8th, 2006, 12:35 PM Thread Starter
Ok iam trying to find out about a noisy gear driven kit?
max5.0 is offline
post #4 of 7 Old January 8th, 2006, 12:38 PM
mdvaldosta's Avatar
Ah, the gear drive is more accurate over the long haul because chains tend to stretch as they age. But, it's more expensive - it's louder - and doesn't really increase horsepower.
post #5 of 7 Old January 8th, 2006, 04:30 PM
1slo5.0's Avatar
A gear drive takes more horsepower to run and transmitts harmonics from the crank to the valvetrain thru the camshaft. Stick with a chain or if you have too much money, get a belt drive.
1slo5.0 is offline
post #6 of 7 Old January 8th, 2006, 08:00 PM Thread Starter
guess i will stick with the chain.
Max
max5.0 is offline
post #7 of 7 Old January 8th, 2006, 10:39 PM
you have belt driven, chain driven, and gear driven. belt driven ive heard is for the most part reliable. gear driven you can get in a loud or quiet kit but highly expensive even tho effective. chain driven if effiective up to the time the chain gets streched and worn because then you got problems. so isn't much of a difference.
FastFiveO is offline
