fpdm/fuel pump wiring upgrade - Forums at Modded Mustangs
post #1 of 59 Old February 11th, 2009, 06:25 AM Thread Starter
mm's nitrous mod
SWEET2KSTANG's Avatar
iTrader: 8 reviews
fpdm wiring upgrade
i did a wiring up grade on my car and these are the steps i took:
went to parts store and picked up 25ft of 10 gauge wire (i've heard some people using 8ga wire), universal relay, 30A inline fuse fitting, t-fittings, and package of misc electrical fittings.
disconnect negative off battery
solder the inline fuse to one end of the 10ga wire, this will be the end that will be hooked to 12+ scource
run the 10ga wire thru thru the engine compartment, thru the wire groment on drivers side firewall.
i already had my interior out, but you will atleast need to pull up the carpet on the drivers side. route the wire under the carpet to the back. i ran mine with the factory wiring under the carpet to keep secure and clean.
find a place you want to mount your relay to, i mounted mine on the bracket that holds fpdm.
the power wire that was ran to the back will be connected to pin 30 on the realy. after you find where you want to mount the relay, cut the power wire to length needed.
pull harness off the fpdm, and cut the tape back off the factory wire harness to expose all the wires to the connector. cut the pink/black trace wire, be sure to leave enough wire to put a connector on!
the pink/black wire that comes off the fpdm connector will need to be lengthed and connected to pin 87 on the relay. the wire that runs in the harness will need to be lengthened and be connected to pin 86.
now this is the part that can get exciting. the tank will need to be lowered enough to get to the wiring on the fuel pump hat.
the extra wire that was was cut off from the power wire will be used to run from the fpdm harness to fuel pump hat. run the wire down to the tank so it will reach the fuel pump hat. i routed the wire down thru the grommet directly below the inertia switch.
locate the brown/pink wire on the fuel pump hat and tap into it with either a t fitting or a quick splice. connect the wire you ran down to the tank to this wire. be sure that the wire is tucked up safely and wont be getting pinched or cut.
you can mount the tank back up and pull the extra length of wire up to get out the slack. connect that wire to the brown/pink wire on the fpdm harness.
pin 85 will need to be grounded with same gauge wire that the power wire is. i used the same ground that the fpdm was using.
zip tie everything up, clean up, and put interior back together.
wagon burner built! track times coming soon!(04 lightning)
follow shop builds on facebook at: MP2 Performance
SWEET2KSTANG is offline
post #2 of 59 Old February 11th, 2009, 06:26 AM Thread Starter
mm's nitrous mod
iTrader: 8 reviews
connect the power wire to the side of the fuse block that the battery + wire goes to. install fuse and hook battery back up.
post #3 of 59 Old February 11th, 2009, 06:36 AM
~C~
~C~, The Other White Meat!
~C~'s Avatar
Send a message via AIM to ~C~
Damn nice write up Sweet! How long did this take you to do?
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
~C~ is offline
post #4 of 59 Old February 11th, 2009, 06:42 AM Thread Starter
mm's nitrous mod
iTrader: 8 reviews
i was changing my fuel pump, and detailing my interior the same night. i think without taking the interior completely out, this could be done in about 2-3hrs depending how familiar you are with droping the tank.
post #5 of 59 Old February 11th, 2009, 06:58 AM
PapaSmurf's Avatar
iTrader: 13 reviews
very nice writup Mike
315hp/300tq
Full Boltons, MHS Stage 3R cams, Stage 2 Heads, Built rear/4.30 gears
Sonic Blue Crew
PapaSmurf is offline
post #6 of 59 Old February 11th, 2009, 10:16 AM
R3dFyre02's Avatar
dumb question, but what does this do? just give a few more amps and true 13.5 volts from th alt to the pump rather than run its power through the cars wiring harness?
02GT - Blown motor
86LX 3.8TBI auto replacement daily driver
How to retrofit HID's
R3dFyre02 is offline
post #7 of 59 Old February 11th, 2009, 10:21 AM
yeah, free's up a few % duty cycle. Its not much but every little bit helps! Although this is generally done with a BAP. I don't see it in these pics.
2000 Black convertible GT: KB 18psi, and other goodies...
2006 Nissan Titan: Tow package, 4 inch lift. (The DD)
RyanGT is offline
post #8 of 59 Old February 11th, 2009, 11:58 AM
Trick Tuners's Avatar
Nice write up! I would love it if you could cut and past it onto the DIY section of my forums. The "How to" section for the DIY guys - Trick Tuners Forums If you are too lazy to register and will allow me to copy and paste i can do that too. rep'd
Trick Tuners is offline
post #9 of 59 Old February 11th, 2009, 03:43 PM Thread Starter
mm's nitrous mod
iTrader: 8 reviews
will do.
post #10 of 59 Old March 15th, 2010, 01:30 PM
Achieving more N/A power!
gills99stang's Avatar
Send a message via AIM to gills99stang
Update the pics...!
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
gills99stang is offline
post #11 of 59 Old March 15th, 2010, 08:19 PM Thread Starter
mm's nitrous mod
iTrader: 8 reviews
update the pics? not enough or you need more? my fuel system has been thru another make over so its not the same as it was then.
post #12 of 59 Old March 15th, 2010, 10:03 PM
Mizark347's Avatar
Would anything be done differently if you were using a KB Boost-A-Pump?
Mizark347 is offline
post #13 of 59 Old March 16th, 2010, 12:36 AM Thread Starter
mm's nitrous mod
iTrader: 8 reviews
i believe all you will have to do is instead of cutting the wire to go to the relay, connect it to BAP. the wire from the BAP will go to the relay on pin 87 and the other end will still be on pin 86.
post #14 of 59 Old March 16th, 2010, 12:02 PM
Your Photobucket picture links are expired...
Brendan
post #15 of 59 Old October 31st, 2010, 10:06 AM
BakerFX4's Avatar
iTrader: 15 reviews
I see that the larger wire was put together above the hat. Doesnt that just bottle neck the power that goes to the pump. Same thing to the FPDM. I dont see how its helping if you still have the stock smaller wire going to the pump or FPDM. That smaller wire can only run so much through it. On the GT pumps, couldnt you just finish running the wire through the hat down to the pumps with the spade connector on the end? Would that make it a little better?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #16 of 59 Old October 31st, 2010, 10:57 AM
BakerFX4's Avatar
iTrader: 15 reviews
Post from an electical engineer guy or something...
A bottle neck is a bottle neck. if the wire guage at the input or output wire is smaller, then that said wire becomes the weak link, possibly weaker than the fuse you install at the beginning of the circuit and therefore the short piece of wire would melt first before the fuse would blow (in theory) I really think this upgrade is pointless unless you "upgrade" all the wire. Amperage is the "number" of electrons the more electrons that can fit the more work that can be done a bottle neck by use of small guage wire will not allow anymore electrons through than it can support, and is useless. Has anyone actually proven that this upgrade works? We were getting ready to do this to a friend of mines 4v car and after I saw what everyone is doing by way of splicing into the existing wire I wasn't interested. I guess thats why this kit is designed for the BAP because it provides the same size wire all the way to the BAP and is a good install for it. To me it is junk for the fpdm if you are leaving existing wire in place..
just my 2 cents.
lata,
Matt
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
post #17 of 59 Old October 31st, 2010, 11:22 AM
JTs03v6's Avatar
I used 1/2" of solid 12g wiring and replaced the 16g inside all of the pins. Actually radio shack has replacement pins and thats what I used instead of reusing the stock ones.
Turbo 4.3 stroker, 6.73 @ 106mph...still tuning
https://moddedmustangs.com/forums/v6-...ker-build.html
JTs03v6 is offline
post #18 of 59 Old October 31st, 2010, 11:55 AM
BakerFX4's Avatar
iTrader: 15 reviews
In this pic, the pink and black wires could be drilled out of the hat and just continue the larger wire into the hat and put a spade connector on it, onto the pump.Then just silicone around the SMALL holes where your wire went through. Seems like a better deal to me than just cutting the wire above the hat.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
post #19 of 59 Old October 31st, 2010, 11:57 AM
limited's Avatar
I ran 12 guage from the fpdm to the pumps by making my own pass thru connections at hat. just have to make sure they are leak free(both fuel and air) or you will get evap codes. with a bap prefpdm that will raise the power handling capabilities of the fpdm by raising voltage which allows a lower current for the same amount of work.
kinda of like a high power transmission line, it carries 750,000v but only 3a thats why they get away with a wire about an inch thick to power a city
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #20 of 59 Old October 31st, 2010, 11:57 AM
BakerFX4's Avatar
iTrader: 15 reviews
And there has to be a way to go straight into the FPDM plug/pin with larger wire too. I might tear all my stuff down next weekend or so and figure it all out.
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
BakerFX4 is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/96-04/109864-fpdm-fuel-pump-wiring-upgrade.html
04 Cobra Bogging and Stalling after BAP Install - Page 3 This thread Refback August 25th, 2015 03:52 PM
CMC Forums - Welcome to CMC This thread Refback August 25th, 2015 03:25 PM
04 Cobra Bogging and Stalling after BAP Install - Page 3 This thread Refback August 25th, 2015 03:23 PM
04 Cobra Bogging and Stalling after BAP Install - Page 3 This thread Refback August 25th, 2015 03:17 PM
wiring a BAP - TCG This thread Refback March 6th, 2014 12:35 AM
+05 Fuel Pump Wiring Mod...anyone...? - FnSweet.com | The Independent Community Of ROUSH Enthusiasts This thread Refback September 14th, 2013 03:18 AM
OLDBASTARD MMR 4.6 STREET MOD 600. - Ford Mustang Forums : Corral.net Mustang Forum This thread Pingback December 14th, 2012 11:23 PM
Fuel pump wire mod without FPDM? - Ford Mustang Forums : Corral.net Mustang Forum This thread Pingback December 7th, 2012 12:39 PM
Untitled document This thread Refback September 24th, 2012 01:50 PM
MY FUEL SYSTEM BLOWS...HELP PLEASE LOL - Ford Mustang Forums : Corral.net Mustang Forum This thread Pingback February 16th, 2012 07:59 AM
fuel pump wiring upgrade? This thread Refback February 4th, 2012 02:01 PM
Fuel Pump Issues | Mustang Forums at StangNet This thread Refback December 31st, 2011 09:33 AM
Aeromotive stealth 340 fuel pump - 2003-04 Mach 1 Registry Owners Club This thread Refback November 12th, 2011 03:40 PM
fuel pump wiring upgrade? This thread Pingback October 15th, 2011 09:20 AM
Aeromotive stealth 340 fuel pump - 2003-04 Mach 1 Registry Owners Club This thread Refback September 18th, 2011 10:52 PM
Fuel Pump Issues - Mustang Forums at StangNet This thread Pingback August 27th, 2011 04:52 PM
How many have done the Fuel pump ugrade on the 99-04 cars - Ford Mustang Forums : Corral.net Mustang Forum This thread Refback August 14th, 2011 09:11 PM
Untitled document This thread Refback July 16th, 2011 06:00 PM
Fuel pump wont stop priming - Ford Mustang Forums : Corral.net Mustang Forum This thread Pingback March 24th, 2011 02:20 PM
+05 Fuel Pump Wiring Mod...anyone...? - FnSweet.com Roush Enthusiast Forums This thread Pingback January 2nd, 2010 05:28 PM
Tips and Trick for performance gains posted here: - Extreme Forums This thread Refback August 2nd, 2009 01:44 AM
How many have done the Fuel pump ugrade on the 99-04 cars - Corral Forums This thread Refback July 19th, 2009 08:49 PM
