Write Up: How to remove your rear seats - Forums at Modded Mustangs
post #1 of 12 Old March 25th, 2010, 12:05 AM Thread Starter
Imran's Avatar
First, you have to do the easiest part, which i found to be the hardest, because all the other write up's left out the part in which they tell you to push the button forward and not down.
Refer to these two videos on how to remove the ass cushion portion of the seat.
This first video shows the button mechanism and how to push it.
Believe me, this video will definately help you understand how to push the button. I must have spent 20 minutes trying to figure out how to push this damn thing right because i was pushing it down towards the floor.
and here is where it is located under the seat. There is one under the middle part of the drivers side rear seat and the other under the middle of the passenger side rear seat. Yes, that's me.
so anyways, once you push the button on one side, you lift it up a little bit, then go to the other side and push that button and lift. The seat should lift right off. Remove the seat from the car, and you should see something like this.
now, look under backrest portion of the rear seat near the middle. There should be two 10 mm bolts near the middle of where both the left and right rear seat should meet, one bolt on the side of each rear seat nearest to the middle. Remove them with a 10 mm socket.
now, fold down the rear seats and go back up to the top of the rear seats. Remove the head rest panel via these three bolts, one on each side and one in the middle. Note that only one is pictured in the first picture, and the other one is on the opposite side.
after you remove them, it should come right off.
Now, you should see these bolts. Remove all of them with one of those screwdrivers with the interchangeable tip removed. I don't remember the size, but you'll figure it out
after you remove them, note that it doesn't immediately drop the rear seat bracket. The area where the trunk carpet is connected to the rear seat backrest bracket is holding it via plastic tabs.
An easy way to remove these tabs is by prying it off with one of these things. The pictures are self explanatory
After you have removed these two or three tabs, you can remove the carpet from the seat bracket and take out the backrest and bracket connected to it.
WATCH OUT!! there are exposed metal parts of the bracket that can and will scratch you and your interior up.
30 minutes after i was done i noticed two or three areas on me where i was scratched up and was bleeding, and i didn't even notice it till i saw the dried up blood.
Now that you've removed your rear seats, you will have something that looks like this. Get a rear seat delete if the excessive noise and things from your trunk flying at your face during braking annoy you, or just don't put anything in your trunk and deal with it like i am doing (for now)
GOOD LUCK!
Imran is offline
post #2 of 12 Old March 25th, 2010, 12:07 AM
GreyWarrior07's Avatar
Nice right up you got there son, let me be the first one to rep ya
My other car is a 867 HP Challenger -> http://www.youtube.com/watch?v=b89K9NlpYCg&feature=plcp
CHECK MEH GARAGE
BAMA Performance Drag Team #9
GreyWarrior07 is offline
post #3 of 12 Old March 25th, 2010, 12:08 AM
BWAL's Avatar
nice write up man
'65 Fastback
'89 LX 5.0
'90 LX 5.0
'92 LX 5.0
'92 LX 5.0
'97 Cobra
BWAL is offline
post #4 of 12 Old March 25th, 2010, 12:13 AM Thread Starter
Imran's Avatar
thanks, took alot of blood and sweat to do this, i never cry, so unfortunately, no tears
Imran is offline
post #5 of 12 Old March 25th, 2010, 12:15 AM
BadBlackGT's Avatar
Nice write up. You buying a cover up kit, or making one?
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
BadBlackGT is offline
post #6 of 12 Old March 25th, 2010, 12:17 AM Thread Starter
Imran's Avatar
I have 99_mustang_gtr making me a custom rear seat delete with the punisher logo on the backrest portion. It's gonna look badass IMO
Imran is offline
post #7 of 12 Old March 25th, 2010, 12:18 AM
BadBlackGT's Avatar
Nice, do post pics when you install!
post #8 of 12 Old March 25th, 2010, 12:20 AM Thread Starter
Imran's Avatar
should be done and shipped by monday/tuesday. I'll take pics when it gets here.
Imran is offline
post #9 of 12 Old March 25th, 2010, 03:06 AM
mrsinister2424's Avatar
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Damn, thanks for the writeup. I've always wanted to take my rear seat out.
Oh shit. I have a self made rear seat delete. How did that get there?
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
mrsinister2424 is offline
post #10 of 12 Old March 25th, 2010, 03:16 AM
Cum On Me Bro
sikedsyko's Avatar
lawl you were pretty excited about getting that button the first try huh? You'll get used to it once you take it in and out a bunch of times.
but really, good write-up!
sikedsyko is offline
post #11 of 12 Old March 25th, 2010, 03:18 PM Thread Starter
Imran's Avatar
yep that button was only such an obstacle because i didn't know which direction to push it in. I could do this 100 times easily now just because i know how to do it
Imran is offline
post #12 of 12 Old December 13th, 2010, 10:06 AM
Resident Diabetic...
braupe's Avatar
Nice write up. Reps to you sir!
2006 GT ~C&L Racer~Steeda UDP~JBA LT~Pypes O/R X Pipe~Borla S-Type A/B~MGW Shifter~FRPP K Springs~Koni STRT.S~J&M Panhard Bar~3.73.
2011 F150 4X4 Lariat Coyote. Ball Cooling Seats. Gibson Dualsport.
2011 Explorer Limited.
braupe is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/96-04/158417-write-up-how-remove-your-rear-seats.html
Tech - mustang6ers This thread Refback January 15th, 2015 08:14 PM
How-To: The Compilation | V6Mustang.com This thread Refback October 30th, 2013 03:51 PM
How-To: The Compilation This thread Refback February 10th, 2013 12:41 PM
How-To: The Compilation This thread Refback February 5th, 2013 11:29 PM
Rear Seat Removal This thread Refback April 8th, 2012 07:11 PM
Rear Seat Removal This thread Refback September 13th, 2011 05:22 PM
Rear Seat Removal This thread Refback May 30th, 2011 10:18 PM
How to remove the back seats? - 1996-2004 4.6 Mustang Discussion This thread Pingback February 21st, 2011 12:25 AM
