What did YOU do to your mustang today? - Page 286 - Forums at Modded Mustangs
 14Likes
post #5701 of 7059 Old October 11th, 2013, 05:00 AM
Mike's2000GT's Avatar
^ yep, if I have a car, I'm gonna drive it!
Mike's2000GT is offline
post #5702 of 7059 Old October 11th, 2013, 09:56 AM
BLUE91GT's Avatar
Getting ready to install Eibach pro struts/shocks, Vogtland springs, MM caster camber plates, Steedaq X2 ball joings, Steeda bump steer, Poly offset rack bushings, Poly strut bushings, poly front/ rear coil spring isolaters, and Bama tune.
02 GT- TF TB/ upper, Basanni cat back, steeda triax, steeda UDP,MAC CAI, Vogtland springs, Steeda SFC, Poly bushings,KYB shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Aluminum DS, 04 Cobra brakes, Steeda FLSC.
BLUE91GT is offline
post #5703 of 7059 Old October 11th, 2013, 12:27 PM
Ford Design Engineer
WheelStander's Avatar
Got my camber in spec
2003 Svt Cobra : 515wHp 524tq : [email protected]
WheelStander is offline
post #5704 of 7059 Old October 12th, 2013, 01:41 AM
Got this in the mail!
Name:	Screen Shot 2013-10-12 at 12.31.57 AM.jpg
01 Mustang GT Bullitt #2923 : UPR O/R X Pipe - Pypes M80s - MGW
BullittGT is offline
post #5705 of 7059 Old October 12th, 2013, 11:39 AM
Bought a chisel less than an hour ago.
Just finished taking off the upper adhesive on the '03 top.
Probably clean the window area later today. Get ready for a primer run? Maybe apply Windo-Weld?
Also have other non-automotive things on the agenda today.
---------- Post added at 11:39 AM ---------- Previous post was at 11:11 AM ----------
Originally Posted by gravik View Post
You pussies need to drive your cars.
Get on my level.
When I saw these low mileage ponies, I decided to snap a picture of my work horse. But she decided to not cooperate for the shot, so here's my car's response to your low mileages:
When she feels like showing it, it's currently around near 159k. Next oil change is just past 160k.
And yes, she needs to get cleaned.
lemon is offline
post #5706 of 7059 Old October 13th, 2013, 12:17 AM
<<J G O>>
josegovi's Avatar
Installed new side skirt which completed the body kit finally!!! and photoshoot!! (CLICK IMAGE # TO SEE FULL SIZE)
Image 1
Image 2
Image 3
Image 4
Image 5
Image 6
Image 7
Image 8
Image 9
Image 10
Image 11
Image 12
josegovi is offline
post #5707 of 7059 Old October 13th, 2013, 01:46 PM
how bout my pony still beating people at 142k !!!!
Tyler1018 is offline
post #5708 of 7059 Old October 13th, 2013, 02:11 PM
158k > 142k.
Come now, math isn't too hard.
lemon is offline
post #5709 of 7059 Old October 13th, 2013, 09:29 PM
tg1227's Avatar
Ordered her some new mickey thompsons
[SIZE="5"][/SIZE
tg1227 is offline
post #5710 of 7059 Old October 13th, 2013, 09:44 PM
BTM AutoSport
iRoush's Avatar
New Splitter Apron / Splitter Design
The wood is just for template purposes, the actual splitter is being made out of tegris.
BTM AutoSport - Like us on Facebook! - Follow us on Instagram!
2016 SCCA National Champion
2016 SCCA CAM Challenge Champion
2016 SCCA ProSolo Champion
#99 '99 Roush Stage II - CAM-C
2016 Ford Mustang Ecoboost
iRoush is offline
post #5711 of 7059 Old October 13th, 2013, 09:51 PM
jeep45238's Avatar
Drove the piss out of it for 200 miles with a bunch of turbo'd SN95's and Terminators.
USAF E4 ~ Never settle for the ordinary.
Rights cease to exist when restrictions are put on them.
jeep45238 is offline
post #5712 of 7059 Old October 13th, 2013, 09:56 PM
01TB03AB's Avatar
Nice. I only got 2 passes outif my ET streets before my engine popped. I'm looking forward to running it again now that my new engine is in.
Speaking of new engine. Went to start it for the first time and the fuel pump was lifeless. So I threw in a TRE 255 super car pump at midnight. I was ticked but my neighbors were more mad and my wife evern more mad when I fired it up at 1 am
Comp Orange 04 Cobra
Azure Blue 03 Mach 1
True Blue 01 Bullitt S/C
Torch Red 04 Mach 1 ,
Torch Red 03 Cobra 10th Anniversary
01TB03AB is offline
post #5713 of 7059 Old October 13th, 2013, 10:53 PM
UCC
DFORCE's Avatar
Lol sweet
FBO, 3.73, tubular rear U/L control arms. Forged teksid+Trick flow heads+spray build+diet under construction.
DFORCE is offline
post #5714 of 7059 Old October 13th, 2013, 11:13 PM
Oiljunkie's Avatar
Started pulling out my 2V and T45. Snapped off the lil fitting on my coolant reservoir tank so i guess ill be buying a new tank.
Not really motivated to even complete the job even though i have buyers for both.
Just need to pull the drive shaft, drop the tranny cross member, pull off the shifter and then pull off the steering shaft and all should be ready to come out the top
00 GT, 4v and Heaton Swap, T56 Mag Build thread: https://www.moddedmustangs.com/forums...aton-swap.html
Oiljunkie is offline
post #5715 of 7059 Old October 13th, 2013, 11:22 PM
01TB03AB's Avatar
Don't forget the 2 ground cables by the driver side motor mount or the oil pressure sensor and a/c wires and anything connected to the harness
01TB03AB is offline
post #5716 of 7059 Old October 14th, 2013, 12:05 AM
Oiljunkie's Avatar
yeah i got the ac compressor unbolted and off to the side, got the grounds taken care of and the sensor. There are plugs everywhere for the harness it seems but i think i got them all. basicaly just have to go back over everything and double check.
This is my first crack at pulling an engine out of a car and its pretty straight forward.
I was goin to try leaving the drive shaft bolted to the pinion but it was suggested that i just drop it to keep it from binding in the tail shaft and creating a major PITA.
And I havent read much about pulling one of these out the top with BBk LT's so hopefully it goes well
post #5717 of 7059 Old October 14th, 2013, 12:07 AM
Dont mind me. Ima dumbass
SecludedGT's Avatar
Fuel pump change at midnight? Definately calls for some beer!
SecludedGT is offline
post #5718 of 7059 Old October 14th, 2013, 01:34 PM
Peeled the pinstriping off yesterday, car looks much better now I think
post #5719 of 7059 Old October 14th, 2013, 02:18 PM
Froush's Avatar
iTrader: 8 reviews
Bought an ais meth kit for it yesterday! Cant wait for race gas octane for a little over 93 price
"Happiness is being blown and stroked at the same time"
V6 => Teksid 302 stroker
Caitlyn Jenner swapped
My Build Thread click link
https://www.moddedmustangs.com/forums...shs-build.html
Froush is offline
post #5720 of 7059 Old October 14th, 2013, 02:21 PM
Too broke
Fatstang's Avatar
Did some bartering with a friend, i do his brakes on his silverado, he polish and seal my stang. Never seen so much flake in DSG, came out sweet
Fatstang is offline
LinkBack to this Thread: https://www.moddedmustangs.com/forums/96-04/176078-what-did-you-do-your-mustang-today.html
::Torrent search site This thread Refback October 1st, 2012 12:03 PM
Thread What did YOU do to your mustang today? | Forums at Modded Mustangs | BoardReader This thread Refback July 28th, 2011 02:18 PM
