Headlight issues (in a bind - need help fast) - Forums at Modded Mustangs
post #1 of 23 Old August 14th, 2010, 10:52 PM Thread Starter
Currently pulled over on side of interstate...
Just purchased car, driving home. Everything works great runs fine etc.
Out of nowhere both headlights just turned off on me. Parking lights still on... Tail lights work fine, blinkers fine, gauge cluster etc all still light up. It's just both headlight bulbs are out.
Is there a specific fuse? No manual in car but then agai if it were a fuse wouldn't orange parking lights go out too?
Need help asap thanks guys !
Invictus is offline
post #2 of 23 Old August 14th, 2010, 10:54 PM
ccampton's Avatar
what kind of car? specifics plz...
K&N CAI, MAC O/R H, Flowmaster American Thunder Catback, Smoked Fog Lights, Sequential Tail Lights
ccampton is offline
post #3 of 23 Old August 14th, 2010, 10:54 PM Thread Starter
Car is an '01 Gt roush edition. No aftermarket HiD mods are any such to lights. In fact i was just admiring how well they lit up the road the lighting in my last mustang sucked!
Invictus is offline
post #4 of 23 Old August 14th, 2010, 10:56 PM
ccampton's Avatar
do the high beams work?
ccampton is offline
post #5 of 23 Old August 14th, 2010, 10:59 PM
31-Spline upgrade in progress!!
My stang burnout vid!
jqualls04GT is offline
post #6 of 23 Old August 14th, 2010, 11:00 PM Thread Starter
No highs or lows don't work
Invictus is offline
post #7 of 23 Old August 14th, 2010, 11:01 PM
ccampton's Avatar
im gonna say either both bulbs happened to go out, electrical problem, or fuse. my best bet would be if you have good fuses, that the bulbs went out. its not uncommon for them to go out together.
ccampton is offline
post #8 of 23 Old August 14th, 2010, 11:01 PM Thread Starter
Fuse 10 and 38 under the dash are okay, just changed them anyway with no luck. Thanks for that diagram
Invictus is offline
post #9 of 23 Old August 14th, 2010, 11:03 PM Thread Starter
If i take the bulbs out can i tell my looking at them if they're bad? I managed to make it to a big gas station with hotel rite across the street, could be way worse!
Invictus is offline
post #10 of 23 Old August 14th, 2010, 11:20 PM
MikeJones's Avatar
Thanks for posting that picture of amp fuses and what they are.
Mod6 Eagle Melling
Bigbore Bullet Cams Meziere
Kooks Probe Pistons
Thanks to NA SVT and NeverEnough
MikeJones is offline
post #11 of 23 Old August 14th, 2010, 11:25 PM
MikeJones's Avatar
Yeah, sometimes they look burnt.
Mod6 Eagle Melling
Kooks Probe Pistons
post #12 of 23 Old August 14th, 2010, 11:42 PM Thread Starter
Bulbs look perfect, brand new
Invictus is offline
post #13 of 23 Old August 14th, 2010, 11:44 PM
GP-SE's Avatar
check the wiring, could be a bad ground.
GP-SE is offline
post #14 of 23 Old August 14th, 2010, 11:52 PM
0949er's Avatar
did they go out over a bump or something? And you said they are HIDs or they are not HIDs?
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cams XE270-AH
+ See Garage
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
PLANS ON HOLD
0949er is offline
post #15 of 23 Old August 14th, 2010, 11:55 PM
bigjohnstud4200's Avatar
Driving lights?
Tuned by [email protected]
CMS Stage 1 Cams, 4.10 Gears, TrickFlow 70mm TB & Plenum, MAC Prochamber with Pypes M80's, MGW Shifter, Custom Paint, Cobra Cloth Top, Staggered Chrome 18" Saleen's and Sequential Tails.
bigjohnstud4200 is offline
post #16 of 23 Old August 15th, 2010, 12:04 AM Thread Starter
Originally Posted by bigjohnstud4200 View Post
Driving lights?
Is that the orange Side marker lights? Yes they are on and work fine. Blinkers also works. The actual headlight bulbs (high/low beam) will not work.
They are not HID.
Invictus is offline
post #17 of 23 Old August 15th, 2010, 12:14 AM
They are not HID.
I was actually talking about what people refer to as "fog lights". I'm guessing if you have them, they are not working either?
post #18 of 23 Old August 15th, 2010, 12:24 AM Thread Starter
Ah sorry! No the car does
Not have fog lights. : /
At this point im no longer in a bind I've already gotten a hotel room however come tomorrow night i will need suggestions : /
Invictus is offline
post #19 of 23 Old August 15th, 2010, 09:15 AM Thread Starter
Bump
Invictus is offline
post #20 of 23 Old August 15th, 2010, 11:48 AM
R3dFyre02's Avatar
make your own harness... Battery to relay 12v source in. ground relay. signal from headlight switch to trigger on relay. positive output from relay to low beam bulb. this draws 13.5-14v straight from the battery giving a bit more light output and bypasses any issues in the cars wiring. Sorry, Im kinda typing this out on my droid so I can attach pics and stuff.....
02GT - Blown motor
86LX 3.8TBI auto replacement daily driver
How to retrofit HID's
R3dFyre02 is offline
