You guys running KB blowers or any s/c smart guys! - Forums at Modded Mustangs
post #1 of 16 Old August 31st, 2010, 10:29 PM Thread Starter
Okay so Ive been looking at meth injection to cool down some temps but I came across someone selling a kenne bell full intercooler kit. Only thing is the air to water or water to water intercooler is dented and dinged pretty good. Could I get one of these: Air to Water Heat Exchanger :and it take place of the stock kenne bell one and possibly be a little better? All thats left on this kit is to find something to take place of the stock one and I can get it mounted and tuned. Thanks guys, any links or suggestions of what to try would be nice!
Kennebell 2.1 at 10lbs.
04Kennebell is offline
post #2 of 16 Old August 31st, 2010, 10:30 PM Thread Starter
Would the 3.5 thick or 2 inch thick be better? or closest to the stock one?
post #3 of 16 Old August 31st, 2010, 10:38 PM
turbot4's Avatar
iTrader: 9 reviews
i have the ron davis on mine....i can't see how or why you are running 10psi non intercooled...your asking for trouble..
turbot4 is offline
post #4 of 16 Old August 31st, 2010, 10:44 PM Thread Starter
Not by choice. Just picked the car mid summer hasnt been drove much or beat on at all by me. Been sitting till I can get intercooled. Can you hook me up with a link. I looked up ron davis but that site is huge lol. Is what i found something that will also work?
post #5 of 16 Old August 31st, 2010, 10:50 PM
turbot4's Avatar
iTrader: 9 reviews
appears it would, mine flows side to side..
turbot4 is offline
post #6 of 16 Old August 31st, 2010, 10:53 PM Thread Starter
You wouldnt happen to know the dimensions would you? I got his old kennebell flip switch as well tuned for the intercooler set up. Just dont want it affecting how it runs if the intercooler is larger than what it is tuned for.
post #7 of 16 Old September 1st, 2010, 12:24 AM
turbot4's Avatar
iTrader: 9 reviews
I would need to measure it...i will get back to you.
turbot4 is offline
post #8 of 16 Old September 1st, 2010, 11:48 AM
I know intercoolers are important but S351s use to never use them....
steweod is offline
post #9 of 16 Old September 1st, 2010, 03:29 PM
Send a message via AIM to hardhitter
They would if they knew what was good for them.
Vortech V2 Si
hardhitter is offline
post #10 of 16 Old September 1st, 2010, 03:31 PM
GreyWarrior07's Avatar
the 858 whp by me has a big one lol
My other car is a 867 HP Challenger -> http://www.youtube.com/watch?v=b89K9NlpYCg&feature=plcp
CHECK MEH GARAGE
BAMA Performance Drag Team #9
Last edited by GreyWarrior07; September 1st, 2010 at 03:33 PM. Reason: meant to quote
GreyWarrior07 is offline
post #11 of 16 Old September 1st, 2010, 03:39 PM
Jobra's Avatar
IMO the stock KB one is fine for a stock engined GT and the power levels being run thought it unless your drive your car very very hard and frequent the track / you live in very hot weather. Get a nice big i/c res tank and pack it with ice if your going to be at the track otherwise your fine.
NEW NUMBERS: 644/634
Jobra is offline
post #12 of 16 Old September 1st, 2010, 03:44 PM
0949er's Avatar
are these the kits that require you to relocate your battery? or the ones that sit on the passenger side where the T/B piping usually goes
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cams XE270-AH
+ See Garage
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
PLANS ON HOLD
0949er is offline
post #13 of 16 Old September 1st, 2010, 04:15 PM
mell0's Avatar
Send a message via AIM to mell0
i believe these ones sit in the passenger side like the termi intercooler reservoirs. if you can afford it i would look into an afco or LFP dual pass heat exchanger. if not you can pick up stock cobras ones pretty cheap, and i'm sure it would be more than sufficient.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
mell0 is offline
post #14 of 16 Old September 1st, 2010, 06:43 PM Thread Starter
I know the stock kb is good it's just got a huge bash in it and kinda dips in the middle. I was just wanting something close the same size and new. How do you fill these things up when i get it anyways. Or does it feed off the radiator?
post #15 of 16 Old September 1st, 2010, 09:55 PM
turbot4's Avatar
iTrader: 9 reviews
you need the tank and lines with the pump..the pump pushes it through the ic...post a picture of your motor..
turbot4 is offline
post #16 of 16 Old September 1st, 2010, 11:13 PM Thread Starter
I dont have it all yet. But I know it does have the tank, lines and a pump along with everything else in the kit.
