Fuel pump going out??? - Forums at Modded Mustangs
post #1 of 29 Old January 7th, 2011, 01:42 PM Thread Starter
tyzride's Avatar
02 Saleen Mustang S281-SC, I was getting on the freeway today and starting accelerating. The motor starting hesitating and chugging really bad. At a constant speed it runs fine. When going up hill today or applying more throttle the motor started chugging and hesitating really bad. It hasn't thrown a code yet and all maintanence has been done recently. Is the fuel pump going out? How do you check the fuse and relays? Thanks.
tyzride is offline
post #2 of 29 Old January 7th, 2011, 01:50 PM
limited's Avatar
have a fuel pressure guage installed? If not this is why I think all fi should have one.
sounds like pump issue, but give her a tune-up with filters and see if it helps
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #3 of 29 Old January 7th, 2011, 01:52 PM
stal94gt's Avatar
you got enough gas in the car?
stal94gt is offline
post #4 of 29 Old January 7th, 2011, 02:20 PM
Procrastinator
before doing anything with the pump id change the fuel filter first.
DickH is offline
post #5 of 29 Old January 7th, 2011, 04:12 PM Thread Starter
tyzride's Avatar
I replaced the fuel filter about 7 or 8 months ago and haven't had any issues since then. How do you check the fuel relays?
tyzride is offline
post #6 of 29 Old January 7th, 2011, 06:18 PM
Procrastinator
If the car starts and runs, the fuse and relay is ok.
DickH is offline
post #7 of 29 Old January 7th, 2011, 09:33 PM Thread Starter
tyzride's Avatar
So how can i find out if the fuel pump is going out?
tyzride is offline
post #8 of 29 Old January 7th, 2011, 10:02 PM
Procrastinator
watch your fuel pressure I guess.
DickH is offline
post #9 of 29 Old January 8th, 2011, 02:36 AM
5.4mustang gt's Avatar
it might b the fuel pump but that sounds like spark plugs or coil packs goin out. give it a tune up n make sure ur gettin spark
5.4 SUPERCHARGED GT
5.4mustang gt is offline
post #10 of 29 Old January 8th, 2011, 02:41 AM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
You need to check your fuel pressure. Either by using a scantool that lets you view live date, or datalog it.
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is offline
post #11 of 29 Old January 8th, 2011, 09:40 AM
when my fuel pump died like 8 years ago, it acted up randomly, shutting down for few seconds to making my car stall completely and had to stop on the sides of highways (sigh) but i'm telling you, before it actually died, sometimes i would have no symptoms for many days in a row...
Warriorofice is offline
post #12 of 29 Old January 8th, 2011, 09:48 AM
Gauge's Avatar
Clean your throttle body bore, and egr. Make sure your air filter is good. Check the plugs also.
Gauge
BBK LT Headers, BBK O/R Hpipe, Flowmaster 44 Catback, Steeda Underdrive, BBK CAI, Stage 2 Comp Cams and springs, Stage 1 clutch.
Gauge is offline
post #13 of 29 Old January 8th, 2011, 02:18 PM
Nicos2001GT's Avatar
What should the fuel pressure be ?
Nicos2001GT is offline
post #14 of 29 Old January 8th, 2011, 03:00 PM
Maverick530's Avatar
how does one check the coil packs, because my car does exactly what he describes but just after accelerating hard
Maverick530 is offline
post #15 of 29 Old January 8th, 2011, 09:34 PM
Gauge's Avatar
^ Just take a 10MM socket and ratchet, and undo the bolt that holds on and pull it out.
Gauge
Gauge is offline
post #16 of 29 Old January 8th, 2011, 09:47 PM
limited's Avatar
actually, it is a 7mm socket
limited is offline
post #17 of 29 Old January 8th, 2011, 10:30 PM
KV007's Avatar
+1 on coils
99 Gt Auto Fr500s,Stalker hood,Tuner, pretty stock for now. 4.10s soon
KV007 is offline
post #18 of 29 Old January 8th, 2011, 11:51 PM
so... how do you know if its going out then lol
post #19 of 29 Old January 9th, 2011, 07:23 PM
Anyone?
post #20 of 29 Old January 9th, 2011, 07:32 PM
limited's Avatar
to be accurate you will also need a vac/boost guage. pressure maintained at injector tip is 39psi. so at 20" vacuum (normal idle without aftermarket cams)it will be ~ 30 psi(every 2" of vac = 1 psi so 39-10= 29) and at 10 psi boost it will be ~50psi(39 +10 = 49)
limited is offline
