blower cams or N/A - Forums at Modded Mustangs
post #1 of 23 Old January 7th, 2011, 07:54 PM Thread Starter
blower cams or N/A
should i go blower cams or N/A?
plan on going blower in the fall and im gonna be doing cams this week and not sure what wud be best to do.
ik it sounds kinda dumb but will the blower cams be not very usefull untill i get the blower
430/392
Kenne Bell powered
[email protected]
1.59 60 foot
bigboy05 is offline
post #2 of 23 Old January 7th, 2011, 07:55 PM Thread Starter
kenne bell 2.1 btw
430/392
Kenne Bell powered
[email protected]
1.59 60 foot
bigboy05 is offline
post #3 of 23 Old January 7th, 2011, 07:55 PM
ajm
blower. always plan for the future not the instant gratification. youll only kick your ass in the long run. ESPECIALLY if you cant do the work yourself.
ajm is offline
post #4 of 23 Old January 7th, 2011, 07:56 PM
mrbigjeep's Avatar
blower cams
mrbigjeep is offline
post #5 of 23 Old January 7th, 2011, 08:08 PM Thread Starter
yeah i was thinking blower cams for the future... will be worth it in the long run.. just curious how do they help the blower much more compared to the NA cams
430/392
Kenne Bell powered
[email protected]
1.59 60 foot
bigboy05 is offline
post #6 of 23 Old January 7th, 2011, 09:33 PM
Procrastinator
blower cams wont hurt NA, just wont be as much power as a NA cam. However it doesnt go the other way around, NA cams dont make good blower cams.
DickH is offline
post #7 of 23 Old January 7th, 2011, 09:52 PM
tbirdscwd's Avatar
iTrader: -1 reviews
Since you are going with a blower so soon in the future, then I would definitely go with a set of blower cams. You will be leaving a bit on the table while it is still NA, but you will be happier once you end up getting the blower.
On lower boost levels, it really doesn't make a huge difference as far as choice in cams. Anything will be a lot better than stock, but the more pressure you run, the more a blower cam will work in your favor.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
tbirdscwd is offline
post #8 of 23 Old January 7th, 2011, 10:44 PM
limited's Avatar
cms stage 2 blower cams work well n/a. for a KB i would look into mph grind for kb's(tim works for norms garage now)
I have vt/cms stage 3 blower and unless you turn a lot of rpms they would not do too well n/a
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #9 of 23 Old January 7th, 2011, 10:45 PM
limited's Avatar
They have little to no overlap to prevent boost loss
limited is offline
post #10 of 23 Old January 7th, 2011, 11:23 PM Thread Starter
thanks for the info man.. yeha im deff gonna go with the blower cams.. my tuner reccomended anderson cams..anyone ever heard of them?
430/392
Kenne Bell powered
[email protected]
1.59 60 foot
bigboy05 is offline
post #11 of 23 Old January 7th, 2011, 11:31 PM
tbirdscwd's Avatar
iTrader: -1 reviews
If you plan on getting a KB, then I wouldn't waste my time looking anywhere else but here for your camshaft needs. Hands down the best cams for that type of blower
post #12 of 23 Old January 7th, 2011, 11:49 PM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Yea definatley blower cams. Blower cams will still work fine NA.
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is offline
post #13 of 23 Old January 8th, 2011, 12:04 AM
ajm
people want that killer, super, im the biggest badass on the street sound, yet it comes from overlap. Big overlap + boost = kick youself in the nuts bc you want to act like the cool guys vs the person that actually has a fast car. Generally speaking
ajm is offline
post #14 of 23 Old January 8th, 2011, 12:08 AM Thread Starter
blower cams still sound really good though rightt?
430/392
Kenne Bell powered
[email protected]
1.59 60 foot
bigboy05 is offline
post #15 of 23 Old January 8th, 2011, 12:08 AM
BakerFX4's Avatar
iTrader: 15 reviews
if you are getting a KB, click on the "here" in Tbirds link. Thats all you need to know/do!!!!
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
BakerFX4 is offline
post #16 of 23 Old January 8th, 2011, 12:10 AM Thread Starter
yeah i was checking that out.. i think i may go with that one because it isnt crazy expensive compared to all the other ones either
430/392
Kenne Bell powered
[email protected]
1.59 60 foot
bigboy05 is offline
post #17 of 23 Old January 8th, 2011, 12:17 AM
ajm
As time goes this forum is getting worse and worse. Its just all about people wanting to sound cool, showing their new parts, etc in the tech section. In th eend its still a pissing contest.
Ps. If you want sound just grind your factory cam lobes with a dremel to any desire. im sure itll work well....Thats about the equivalent of matching your setup/goals with a set of cams based off of that "cool sound". Afterall performance dont matter, just as long as you sound cool.......Along with everyone else that rips on rice rockets but they want hids, and all this other visual bullshit on a simple bolt on non track car.
ajm is offline
post #18 of 23 Old January 8th, 2011, 12:34 AM
tbirdscwd's Avatar
iTrader: -1 reviews
bigboy, what is more important to you.....the best cam for your setup or the best sounding cam?
post #19 of 23 Old January 8th, 2011, 02:27 AM
Right or wrong I have comp 278 and 2.8H. The 278s have very similar specs to several stage 3 or 3.5 blower cams. I was building new so had pistons fly cut and it was to tempting not to try 278s. It's a new setup so no numbers yet. The idle is very aggressive even with cats and magnaflows.
It will be interesting to see how setup this works out.
To the OP save your $$$ on cams and put it to the blower. You can always install cams later but you need the blower now! To may 350+ rwhp stock sports cars out there today.
ytngt is offline
post #20 of 23 Old January 8th, 2011, 04:53 AM
stal94gt's Avatar
best advice for you! hell i made over 500rwhp with stock cams.
stal94gt is offline
