94-98 Rear End in 99-04 - Page 3 - Forums at Modded Mustangs
post #41 of 57 Old September 21st, 2011, 02:54 AM Thread Starter
Goose!'s Avatar
Originally Posted by stal94gt View Post
Cobra rotors are thicker than gt rotors
Cobra calipers have a wider gap so it can fit the wider rotor.
but i can still use my GT calipers with the cobra rotors?
or will it not work?
2000 V6 - Turbo
2005 Tahoe LT - DD
1994 GT - Parting Out
1998 GT - Parting Out
1995 GT - SOLD
Insta :@Southfour6[/CENTER]
Goose! is offline
post #42 of 57 Old September 21st, 2011, 02:56 AM
stal94gt's Avatar
Probably not. Cobra rotors with new pads maybe to thick for the caliper to fit over. I did not try on my car so it may fit but like I said when I pulled the gt rotor off the first thing I saw was how thin the gt rotor it was compaired to the cobra rotor
bone stock from the factory!
stal94gt is offline
post #43 of 57 Old September 21st, 2011, 03:01 AM Thread Starter
Goose!'s Avatar
ok Im going to run my thinn worn down GT pads until i can get some cobra calipers
thanks for all the help
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
post #44 of 57 Old September 21st, 2011, 03:05 AM
stal94gt's Avatar
No problem. Sorry for the confusion im not he best at explaining
stal94gt is offline
post #45 of 57 Old September 21st, 2011, 09:43 PM Thread Starter
Goose!'s Avatar
got the caliper on using my worn down GT pads, hopefully this will be fine for a month or so
Didnt bother painting them because i will order some cobra rear calipers soon and clean/paint those.
now i cant get the pasenger side caliper piston to spin back into place so tomorrow i am going to rent the good set of tools instead of the little cube thing.
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
post #46 of 57 Old September 21st, 2011, 09:48 PM
stal94gt's Avatar
how far did you have to turn the caliper in to clear the new thicker rotors.
stal94gt is offline
post #47 of 57 Old September 21st, 2011, 09:51 PM
stal94gt's Avatar
btw the cube sucks i always rent the compressor from autozone, it squeezes in while it turns
stal94gt is offline
post #48 of 57 Old September 21st, 2011, 10:00 PM Thread Starter
Goose!'s Avatar
4 turns or so
it almost fit without turning it at all, i could have probably hammered it on but i didnt want to damage anything.
With 4 turns there is about a 1/4" space between the piston and the pad so i think once i hit the brakes it should be fine.
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
post #49 of 57 Old September 21st, 2011, 10:07 PM
stal94gt's Avatar
i was just curious. i wanted to know if you tryed new pads on it or not
stal94gt is offline
post #50 of 57 Old September 21st, 2011, 10:24 PM Thread Starter
Goose!'s Avatar
i dont think it would fit with the new pads but i did not try.
I will just buy a set of cobra calipers and put them on when i put on my SS lines and Bullitt front calipers.
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
post #51 of 57 Old September 21st, 2011, 10:25 PM Thread Starter
Goose!'s Avatar
and on another note
do i have the swaybar in the right way, im pretty sure i do because when i flipped it around i couldnt get it to clear part of the MM LCA
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
post #52 of 57 Old September 21st, 2011, 10:30 PM
stal94gt's Avatar
sway bar is on right, back end looks good man, glad your getting on the road soon
stal94gt is offline
post #53 of 57 Old September 22nd, 2011, 05:48 PM Thread Starter
Goose!'s Avatar
Ok i got it all done
is it normal for the girdle to be this close the the spare tire well?
the exhaust rubs the tires without the spacers
and thats how the sway bar is supposed to sit right?
I think i need to raise the control arm adjuster a fair bit, its sitting quite low
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
post #54 of 57 Old September 22nd, 2011, 07:49 PM Thread Starter
Goose!'s Avatar
got some spacers to solve the rubbing problem
eibach 1"
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
post #55 of 57 Old September 22nd, 2011, 09:00 PM
stal94gt's Avatar
man i forgot to tell you your probably going to need shorter studs to fit the spacers. but it looks good. the car is alittle low so you might want to check to see how much room you have on the bump stop. also the diff cover is close but its probably just how low your car is.
stal94gt is offline
post #56 of 57 Old September 22nd, 2011, 10:12 PM Thread Starter
Goose!'s Avatar
The studs on the axle fit perfectly into te recesses in the wheels.
I am raising the car a bit because it's too low for the street. I have adjustable LCAs so I just have to play around with them until I get the right height. Raising should also make the diff girdle not hit.
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
post #57 of 57 Old September 23rd, 2011, 02:23 PM Thread Starter
Goose!'s Avatar
Ok i got the spacers on, no rubbing
raised it up a bit
and ive driven it around for a few miles
however, every so often it makes a noise simmilar to if you drove over some debris on the road and kicked it up under the car.
It does not make this noise with the brakes applied.
Im not really sure what it could be.
2000 V6 - Turbo
2005 Tahoe LT - DD
1995 GT - SOLD
Goose! is offline
