wrapping cold air intake - Page 2 - Forums at Modded Mustangs
post #21 of 29 Old October 13th, 2011, 11:06 AM
King Trashmouth
WickedSnake00's Avatar
Originally Posted by cschoening09 View Post
excellent point lol. i think everyone is overthinking this subject instead of thinking locigally.
I may be overthinking it, but...
You seem to be thinking of the heat transfer through the mode of conduction, which would be more time dependent.
In reality, it is more likely forced convection driven. Basically air driven through a hot pipe, which is transferring heat to the flow.
Q = h A dT where Q is net energy, h is heat transfer coefficient, A is surface area, dT is difference in temperatures.
For forced convection internal flow, h = (k/dh) 0.023 Re^0.8 Pr^0.4
k is thermal conductivity of fluid (air), dh is hydraulic diameter, , Pr is Prandtl number, and Re is Reynolds number.
Re = (pVd/u) where p is density, V is mean velocity, d is diameter, u is viscosity.
So if you wade through all that nonsense, net energy transfer is proportional to velocity. The faster the air moves, the more heat it actually transfers.
WickedSnake00 is offline
post #22 of 29 Old October 13th, 2011, 11:55 AM
blkfordsedan's Avatar
Fluid dynamics......FTW!
-Brian
2004 GT
TR3650, MAC Straight Shot CAI, FRPP 70mm, TFS plenum, catted X-pipe, Pypes Violator polished
304SS cat-back, custom tuned by AM/Bama......
4.10's - coming soon!
blkfordsedan is offline
post #23 of 29 Old October 13th, 2011, 12:59 PM
Proud American
MustangMatt96GT's Avatar
I hate that I understand all that..... Why can't I just be normal?
RIP Travis Billings
1996 Mustang GT - Racecar
1995 Mustang GT - Daily Driver
Special Thanks to:
PoorMan Motorsports Full Parts Supply
MIA Motorsports For any Chassis Related Work or Drag Wings
25.3 SFI Chassis Build
Never Lift Racecars
MustangMatt96GT is offline
post #24 of 29 Old October 13th, 2011, 01:45 PM
King Trashmouth
Because you were stupid and took engineering courses?
Better analogy for the intake;
What cools off your soup faster? Air moving slowly over it, or air moving quickly?
post #25 of 29 Old October 13th, 2011, 06:26 PM
So, without taking the time to do the calculations, if a fixed CFM is flowing through a heated pipe, will a larger pipe produce a larger net transfer of heat due to the increased surface area or a decrease as a result of the reduced velocity......or is it a wash?
-Brian
2004 GT
post #26 of 29 Old October 30th, 2012, 05:21 PM
TheCaptain39's Avatar
if your just wrapping your intake I wouldnt go and spend like 50 bucks on the mishimoto heat wrap, unless of course your already getting it for your exhaust or headers and have some left over. But spending 15 bucks on some reflective heat wrap from Autozone or wherever isnt that bad of an idea.
The air is gonna pick up minimal heat from the tube but its still some. Plus the heat shield getting hot from being in the engine bay all day and will heat up the air some.
I had my K&N intake wrapped and used it to cover my heatshield and cover up any holes between it and the interior of the engine bay. The tube was definitely much cooler wrapped than when it wasnt which will give very minimal gains, but its something
WHAT'S LIFE WITHOUT A LITTLE HORSEPOWER
TheCaptain39 is offline
post #27 of 29 Old October 30th, 2012, 05:40 PM
Resident asshole
A cai doesn't do shit for our cars anyway. The stocker already is a cai. With a more gradual bend.
A the whole heatsoak argument is mute unless the car is parked,and even then there is so much air being sucked through I doubt very much the iat elevates more then a degree or 2.
Stop thinking so much.
Black 2000 gt with a Mach 1 4v. 3.90 gears.Mac long tubes,prochamber,nitrous.
1988 5.0
1982 Capri RS Turbo 1 of 22 built,putting today's tech into yesterday's style.
Shredding Rubber is offline
post #28 of 29 Old July 31st, 2017, 03:13 PM
riverwabbit703's Avatar
Originally Posted by slowgtstang03 View Post
Would wraping intake be worth it? i know it picks up a decent amount of heat the travel threw the engine bay. But is it enough to wrap it.
Okay, okay, I'm a RICER. However, my intake pipe temp from intercooler to throttle body temp has decreased a lot. It's most at luke warm to medium. It is not a overly expensive to wrap it up. Anything to cut down air temp is worth my time.
riverwabbit703 is offline
post #29 of 29 Old August 4th, 2017, 08:53 AM
Froush's Avatar
iTrader: 8 reviews
Are you purposely bringing up threads that have been dead for years?
"Happiness is being blown and stroked at the same time"
V6 => Teksid 302 stroker
Caitlyn Jenner swapped
My Build Thread click link
https://www.moddedmustangs.com/forums...shs-build.html
Froush is offline
