blue smoke - Forums at Modded Mustangs
post #1 of 32 Old March 1st, 2012, 05:12 PM Thread Starter
2002 Mustang Gt
RubyRed5.OH's Avatar
blue smoke
Ok I have a 2002 mustang gt and I have bluish smoke coming from the exhaust when I rev it just a bit but when I open the hood and rev it I see the same type of smoke from under the area of the driver side valve cover. Cant really tell where its comming from. Be straight with me, What could it be? im thinking its something to do with the head. bent valve? it starts up just fine but that bluish white smoke.
4.6 Al Block swap from 05 Mountaineer w/Mac Lts. O/R X & Maganpacks
RubyRed5.OH is offline
post #2 of 32 Old March 1st, 2012, 06:11 PM Thread Starter
2002 Mustang Gt
should i start looking for a another engine?
post #3 of 32 Old March 1st, 2012, 06:21 PM
02GreyGhost's Avatar
Could be a stuck valve....is there any valve tick? How old is the fuel in your 02?
2006 GT (Stock)
02GreyGhost is offline
post #4 of 32 Old March 1st, 2012, 06:25 PM Thread Starter
2002 Mustang Gt
filled up on this last monday.
post #5 of 32 Old March 1st, 2012, 06:27 PM
hmmmm....do you hear any valve tick under the hood, near the valve covers? does the smoke go away after she is warm?
2006 GT (Stock)
post #6 of 32 Old March 1st, 2012, 06:27 PM Thread Starter
2002 Mustang Gt
i do hear some ticking sounds in the engine bay.
post #7 of 32 Old March 1st, 2012, 06:28 PM
try some motor honey or lucas from autozone man. I suggest motor honey the most though. I had this problem with my Red 02 years ago I used that motor honey and problem never came back. Do you have power all through the powerban? I guess im asking if you can make the valves float.
2006 GT (Stock)
post #8 of 32 Old March 1st, 2012, 06:31 PM Thread Starter
2002 Mustang Gt
the smoke does not stop after the car warms up. smoke usally appears after i rev it a little or after i accerlerate. recently installed an o/r x pipe and cat back and i thought it was like the coating wearing off but smoke from inside the engine bay? and yes the ticking does sounds like its near the valve cover
post #9 of 32 Old March 1st, 2012, 06:34 PM Thread Starter
2002 Mustang Gt
yeah i do have power throughout the power banf. it does not seem to lose any power im going to put a scanner to see if i have any codes in a bit.
post #10 of 32 Old March 1st, 2012, 06:41 PM
ya man if you have no codes and have power you might just need an oil change LOL that can cause it or just the simple fact of running alittle rich with that o/r x. give it some time and add some motor honey that tick will go buh bye as soon as it cycles through. GL man!
2006 GT (Stock)
post #11 of 32 Old March 1st, 2012, 06:53 PM Thread Starter
2002 Mustang Gt
ive only gone through 2160 miles since last oil change. ive had to add 1 &1/4 qrts of oil; bc of a leak of the valve covers and of the main seal. but having the same type of smoke coming from the exhaust but in the engine bay? kind of wierd though.
post #12 of 32 Old March 1st, 2012, 08:08 PM
iTrader: 9 reviews
Rings/valve guides.. motor honey? are you serious...lmao
ktm300hater is offline
post #13 of 32 Old March 1st, 2012, 08:19 PM
Yes I am serious. It is a really good additive for noisy valves. Do some research man.
Formulated to improve oil viscosity and performance to protect engines under extreme conditions and extend oil life. Compatible with virtually all engine oils, including synthetics.
2006 GT (Stock)
post #14 of 32 Old March 1st, 2012, 08:20 PM
I have used it multiple times and it has removed all tick and noise permanently. All my Term buddies swear by it.
2006 GT (Stock)
post #15 of 32 Old March 1st, 2012, 08:21 PM
CrazyHorse1981's Avatar
The smoke under the hood is probably going to be burn off from a leaking valve cover, the exhaust smoke could be from a burnt, stuck, or floating valve. Worst case could be oil blow by in the cyl from worn rings. If there are no codes, that still doesnt mean that youre in the clear, that just means its not picking up when you scan, i.e. not causing a misfire etc. How many miles does the motor have, and how hard do you push it? I would do a cyl comp test and I would get some new valve cover gaskets, while youre in the valve covers check the spring tensions for each spring and put new valve seals in there since youve got all that apart anyway. But I dont think this is going to be a miracle can fix, this could be several different things, start small and go big. Or , take it to a shop that knows what its doing and have them take a look. Good luck, hope this can be of help.
" Buy the ticket , take the ride......" Hunter S Thompson
CrazyHorse1981 is offline
post #16 of 32 Old March 1st, 2012, 08:25 PM
+1 Thanks for the input CrazyHorse Well said Sir + REP
2006 GT (Stock)
post #17 of 32 Old March 1st, 2012, 08:25 PM
I do agree with ya that shit does smooth out ticks, I just hope dude doesnt have a bigger issue.
post #18 of 32 Old March 1st, 2012, 10:25 PM Thread Starter
2002 Mustang Gt
engine has 200000 miles on it. oil changes every 3000 miles since 75000 miles. mainly highway miles though. the smoke appears everytime almost everytime i rev the engine. that is why i am nervous about this. worst/best case senerio, ill just do a motor swap instead the tranny swap i was going to do. mabye even swap in a 4.6 DOHC. not going to lie , i have done some pulls on the car and have pushed it to my limits but never over the top. never been near redline and i always back off once i get to 125-130.
thanks everyone for your inout. still havent checked the codes bc not home yet but ill keep yall posted. some mentioned this to me but i found it hard to believe, could it be the pcv valve? like yall said, start small then go big.
post #19 of 32 Old March 1st, 2012, 10:33 PM
valve seals or rings
Procharged 2000 5 Speed BAB GT, built motor, blower cams, 10 lbs, lee blankenship tune 430/405
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
mustanginky is offline
post #20 of 32 Old March 1st, 2012, 11:01 PM
US Air Force (retired)
Eagle2000GT's Avatar
Smoke in the engine bay is a leak. Out the tail pipes sounds like valve seals. (perhaps rings but my vote is valve seals).
P.S. I'm not a believe in gunking up the motor with oil additives.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
Ret. USAF 1969-1973,1980-1996: Vietnam veteran. Aircraft maintenance. R & D, ICBM Operations.
Also own: 1997 Harley FXDWG, 1998 F-150, and 2002 Corvette LS1
Eagle2000GT is offline
