More probelms with cams - Forums at Modded Mustangs
post #1 of 275 Old May 16th, 2012, 08:56 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
I finally got a chance to Load the custom tune for the HP292's
There is no throttle response. Massive back fires and zero power. Regret ever trying to add cams to this car. Has 1/4 tank of 87 and 3/4 of 93 on a 93 tune.
http://i296.photobucket.com/albums/m...r/bda9f35f.mp4
http://i296.photobucket.com/albums/m...r/70916cda.mp4
Any idea on what to check or do? There are no check engine lights.
Mods:
Hp292, flowtech lt, flowtech o/r x, lm1 Mac cai, 4.10's.
Fuck.
2013 GT
2016 F150
Cabikejumper is offline
post #2 of 275 Old May 16th, 2012, 09:01 PM
cschoening09's Avatar
iTrader: 10 reviews
Sounds like its missing...probly in the tune as bad as it sounds
Did it start runnibg like that after the tune?
2014 A6 GT Sterling Gray. SR performance lowering springs, J&M adj. panhard and Stainless power longtubes - o/r x awaiting tuner and install.
cschoening09 is offline
post #3 of 275 Old May 16th, 2012, 09:04 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
Pulled plug number 1 today ad smelt like fresh fuel. Had a code pop up yesterday for miss on cyl 1. Cleared code and hasn't came back today
2013 GT
2016 F150
post #4 of 275 Old May 16th, 2012, 09:05 PM
limited's Avatar
sounds like the issue some people have when a cam is 180 out. I never expierenced that issue thou
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #5 of 275 Old May 16th, 2012, 09:07 PM
iTrader: 10 reviews
I thought i knew shit. But this is ver my head haha. Obviously. Its not burning. The fuel on that cylinder. Maybe timing is too advanced or retarded? Too much fuel chokeing the engine out
post #6 of 275 Old May 16th, 2012, 09:07 PM
might want to tell your tuner to check his tune. I would put it back to stock tune. Im wondering about the mixing of gas also. 87 + 93 on a 93 only tune. Put some octane booster in the gas tank.
jwhezzy2003 is offline
post #7 of 275 Old May 16th, 2012, 09:09 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
How can it be 180 out if the timing marks were all lined up correctly according to the manual.
I emailed the tuner(email tune) and waiting for his response.
Stock tune:
Idles rough, Ran rough, rich, no power
New tune:
Idles smoother, no power, backfires, rich.
2013 GT
2016 F150
post #8 of 275 Old May 16th, 2012, 09:10 PM
iTrader: 10 reviews
I wouldnt think his fuel tank mixture would make it run like that. Did you get your maf sensor and temp sensor and all the shit plugged back in where it was?
post #9 of 275 Old May 16th, 2012, 09:13 PM
iTrader: 10 reviews
Im not the brightest when it come to diagnostics ..but you had a noise on pass side correct? What if a follower fell out and that cyl1 exh valve isnt opening ...idk i think that makes. Sense
post #10 of 275 Old May 16th, 2012, 09:15 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
Everything is plugged in. Still has a slight tick on pass side. It's not consistent neither. Im going to pull plugs now..
2013 GT
2016 F150
post #11 of 275 Old May 16th, 2012, 09:18 PM
iTrader: 10 reviews
I doubt its 180 out with those cams...maybe slipped a tooth?
post #12 of 275 Old May 16th, 2012, 09:18 PM
MM's Slowest Member :(
02NightRider's Avatar
Damn, I'm sorry to hear all this trouble. Best of luck to you man.
02NightRider is offline
post #13 of 275 Old May 16th, 2012, 09:23 PM
limited's Avatar
backfire = valve open while mixture still burning. cams on correct side? how sure are you of marks lining up(even if they were the correct marks you used). hopefuly it is something simple but sounds like cam timing(ign and cam timing not on same page
limited is offline
post #14 of 275 Old May 16th, 2012, 09:49 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
Codes without CEL on.
Driver side plugs are all good.
Cyl one plug is black/dry. With heavy fuel smell
(Comparing to driver side)
Cyl 2-4 plugs are wet.
Little to no fuel smell
2013 GT
2016 F150
post #15 of 275 Old May 16th, 2012, 09:50 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
I spent 7 hours getting timing marks correct. I'm 100% they did not slip teeth and timing marks are lined correctly.
If valve is sticking, what do I do to fix
2013 GT
2016 F150
post #16 of 275 Old May 16th, 2012, 10:15 PM
I'm, Ron Burgundy?
Gerbig's Avatar
iTrader: 10 reviews
I hate to say it man, but it sounds like you're 180 out. I was even after I lined my timing marks up. Did you degree the cams?
2009 Civic LX
2006 Chevrolet Silverado LWB
2003 V6
Gerbig is offline
post #17 of 275 Old May 16th, 2012, 10:23 PM
MM elder
casper gt's Avatar
I haven't been following your install very closely but my question is has the car ever ran right since the install?
what I'm getting at is do you have a tune problem or a car problem.
MM BRACKET RACING CREW CO-FOUNDER
2012 300a GT A6......10.78 @ 124.........sold
2014 301a GT A6.............12.73 @ 112........d/r only
casper gt is offline
post #18 of 275 Old May 16th, 2012, 10:27 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
can you even degreed Cams with pressed on gears? They were not degreed.
I install the cams 2-3 weeks ago and just got the tune on it today. It has it ran right since the install. I have let it idle a maybe 25 minutes total without a tune.
2013 GT
2016 F150
post #19 of 275 Old May 16th, 2012, 10:31 PM
Bringing Yellow Back
zinc-vert02's Avatar
Send a message via MSN to zinc-vert02
im going to say there out of sync
Stock long block 2v, stock trans, 100 shot of go fast gas. 315hp and 430 trq on spray
zinc-vert02 is offline
post #20 of 275 Old May 16th, 2012, 10:33 PM
MM elder
casper gt's Avatar
I think we got confused, I was asking if the missing, spark plug problems, etc have been there since day one or did they just show up with the tune.
technically yes you could degree your cams with these, Trick Flow ADJUSTABLE Crank Gear 4.6 and 5.4
most folks with windsors swap to bolt on gears when the do cams though.
LinkBack to this Thread: https://www.moddedmustangs.com/forums/96-04/262862-more-probelms-cams.html
More probelms with cams This thread Refback May 24th, 2012 10:44 AM
