Clutch and misc help 5.1 - Forums at Modded Mustangs
post #1 of 30 Old June 3rd, 2012, 07:55 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
With major help from a fellow member, I am picking up a 5.1 forged strocker motor with vortech t trim supercharger.
I've got a stock oem clutch with maybe 3k miles. And I'll need a new clutch but don't know what to get and which will fit. Can anyone suggest me a clutch kit. I'll pick up frpp tob and pb. Will I need upgraded clutch fork too?
Also, I'll need a fuel pump and maybe hats and bap(starting to research sc set ups now)
Daily driver, with some drag strip visits. Told the motor is making ~425. With stock heads and cams. I will have the HP292 cams installed on new motor so I should be around ~450-470..I'm hoping.
Reason for another motor:
Cam followers exploded
Bent trigger wheel(I accidentally put on backwards)
2013 GT
2016 F150
Cabikejumper is offline
post #2 of 30 Old June 3rd, 2012, 08:03 PM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Sweet deal, I would go with a 03/04 Cobra OEM clutch.
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is offline
post #3 of 30 Old June 3rd, 2012, 08:10 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
I read a 03/04 clutch won't fit on a t45?
2013 GT
2016 F150
post #4 of 30 Old June 3rd, 2012, 08:19 PM
iTrader: 27 reviews
It should. They both have an 8 bolt flywheel (or 6 I forget) you could be right. Or a king cobra clutch would be good.
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #5 of 30 Old June 3rd, 2012, 09:01 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
Would this work?
Exedy Mach 500 Stage 3 Clutch (86-Mid 01 GT; 93-98 Cobra) 7950 - Free Shipping!
I plan on getting up to 500 hp in a few months after I get different heads
What's the hp rating on stock flywheel?
2013 GT
2016 F150
post #6 of 30 Old June 3rd, 2012, 09:05 PM
iTrader: 27 reviews
Im not sure if there is a HP rating on the stock flywheel?? Ive never heard of that to be honest.
Im not sure about the Exedy clutchs. Never really read about them. If your looking for 500+rwhp, I would look into a Centerforce Dual friction, or Ram Powergrip...
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #7 of 30 Old June 3rd, 2012, 09:08 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
Would you be able to point me in the right direction regarding a supporting fuel system/pump
2013 GT
2016 F150
post #8 of 30 Old June 3rd, 2012, 09:12 PM
I Have A FLATULENT Butthole.
(Kohrs93)'s Avatar
Nice setup! When my clutch take a shit I'm going with centerforce dual friction, I've heard nothing but good about it.
With that setup you might want to think about getting a beater dd!
Black Stang Crew #Coorslight
BONER CREW EMPLOYEE #3 - RECEIVING DEPARTMENT
[CUMYUM!]
i like pee pees i guess too
(Kohrs93) is offline
post #9 of 30 Old June 3rd, 2012, 09:14 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
I've got a company truck.
2013 GT
2016 F150
post #10 of 30 Old June 3rd, 2012, 09:20 PM
Disturbin' The Peace
4.6DreameR's Avatar
iTrader: 10 reviews
The division x 340lph pump I think would work. Maybe a BAP on top of that if you dont want to go returnless.
2002 Lightning
2003 Mustang GT-Sold
Originally Posted by L
In the 21st century, information is power, to where any human being can learn how to do anything with the touch of a button. With that the most powerful thing a person can do is share ideas and information.
4.6DreameR is offline
post #11 of 30 Old June 3rd, 2012, 09:22 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
When do you know when you'll new a bap?
2013 GT
2016 F150
post #12 of 30 Old June 3rd, 2012, 09:43 PM
iTrader: 27 reviews
Just be careful. The Centerforce DF clutch grabs hard. So if your launching with some bias plys, theres a chance youll snap the input shaft. If I had known this, I would have either upgraded my input shaft when the tranny was out, or I would have gone with an OEM 03/04 Cobra clutch.
If your looking for 500rwhp, 42lb injectors max around 515-525rwhp. So it may be a good idea to roll with some Siemen Deka 60lb injectors. Leaves you with more then enough room to spare.
Fuel pump...all of them are hit or miss. I purposley got a Ford GT supercar pump over the Focus 255lph pump so I wouldnt need a BAP, me and like others maxed it at about 370rwhp. Some make it to 425rwhp with no boost a pump.
The Division X Stryker pump, from what my tuner said requires 13.5v. But at WOT, the alternator shuts off...so theres a chance you can max it sooner.
Since your going to most likley be making more then 500rwhp, I would get a used Cobra hat with twin pumps. That will make it to about 440-450rwhp no boost a pump and about 600rwhp with a BAP.
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #13 of 30 Old June 3rd, 2012, 09:50 PM Thread Starter
MM's V6 Hater
iTrader: 31 reviews
^^ good info. I'll keep reading on all this since I'm clueless in this department.
2013 GT
2016 F150
post #14 of 30 Old June 3rd, 2012, 10:09 PM
Head Unicorn
bulloch27's Avatar
03/04 Cobra clutch is identical in size to the 3650 clutch.... 11". We all know that I preach the Cobra clutch but to make it work in your setup you're gonna need to go from your 10.5" flywheel to an 11" flywheel to fit that clutch. You can run a 10.5" clutch on an 11" wheel, but not an 11" clutch on a 10.5" wheel. I don't know for sure(because I haven't tried it personally)... but I would assume the T45 bell will hold the 11" wheel if you wanna switch to the Cobra setup. If not, you're gonna need to stick with a 10.5" clutch to match your T45 style flywheel.
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX
Unicorn Club Founding Member
bulloch27 is offline
post #15 of 30 Old June 3rd, 2012, 10:16 PM
Send a message via AIM to bottled2v
you're going to exceed the limits of the cobra clutch imo, my buddy has a cobra, clutch got replaced with oem 10k miles before he bought it and the car was stock, now he put 5k miles on it and within the last 1k miles put an exhaust, intake, pulley, and tune and the clutch is starting to slip, he's at rougly 450whp. I dont think it would last long at 500ish hp.
IMO go with a mcleod clutch. doesn't have to be a dual setup, i've heard great things about their new street pro clutches.
as far as fuel, imo go with a single stryker 340 or one of the aeromotive stealth's. that should be sufficient for the first round of mods atleast, then they'll be able to tell you once it's tuned how the duty cycle is and if it'll make it for more or if you'll need a bap.
'03 cobra- KB 2.8 mammoth, midpipe/catback, supporting mods, rxt twin disc, sra w/ 3.73's, E85
722/628 sae
bottled2v is offline
post #16 of 30 Old June 3rd, 2012, 10:34 PM
cschoening09's Avatar
iTrader: 10 reviews
As bad of luck you had with those cams and all, I just wanna say......You lucky fucker! I wish I could score a deal to be stroked and blown, hell, I'll even go spin my cams 180 out and run it down the track if that's what it takes
2014 A6 GT Sterling Gray. SR performance lowering springs, J&M adj. panhard and Stainless power longtubes - o/r x awaiting tuner and install.
cschoening09 is offline
post #17 of 30 Old June 3rd, 2012, 10:41 PM
Head Unicorn
bulloch27's Avatar
That sounds like driver error to me. Even a terribly weak clutch should last longer than that. I run a stock Cobra pressure plate with a Centerforce D/F disc and carry both front tires without issues. Anyone wearing a clutch out that quickly i suffering from poor clutch adjustment or poor driving 90% of the time unless it's a track only car like mine that may see 1000 miles a year.
post #18 of 30 Old June 3rd, 2012, 10:51 PM
Baker Jr.
iTrader: 5 reviews
Send a message via AIM to bandity2k00
Get that thing together and leave it...no more internal motor work for you sir...lol...did you get the motor cheap or something? or someone gave you it?
RagTop GT -D1SC 24LBS BOOST, MMR 900, STAGE 2 HEADS, HP292 CAMS, EDDY INTAKE WITH 6061 PLENUM, BUILT C4 AUTO, 3800 STALL, WITH TRANS BRAKE, MOSER REAR.
bandity2k00 is offline
post #19 of 30 Old June 3rd, 2012, 10:51 PM
Baker Jr.
iTrader: 5 reviews
centerforce dfx if they make one for t5..there the best clutches
post #20 of 30 Old June 3rd, 2012, 10:53 PM
Baker Jr.
iTrader: 5 reviews
And take everything out that engine bay and clean it and make it spotless. i painted every bolt and everything when i did my motor swap..cant imagine back when mine was like that..Mine i can eat off and its just natural now..almost all stangs look like yours cause no one re does em or cleans over the years..cant imagine buying one like that..if i ever sold my car id want a extra 3k for my car just cause of the engine bay detail now
