99-04 GT engine block - Forums at Modded Mustangs
post #1 of 20 Old July 4th, 2007, 12:48 PM Thread Starter
what kind is it
and is it alluminum or cast iron
Hourofpain wrote:
girls always think its cute when we try to do stuff that we cant do
good idea.. nba.. next time you have a date, take her to a garage and let her watch you work on a car
00GT is offline
post #2 of 20 Old July 4th, 2007, 12:59 PM
Resident Bubblehead
00vabchgt's Avatar
iron
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
00vabchgt is offline
post #3 of 20 Old July 4th, 2007, 03:59 PM
Garhfer's Avatar
Send a message via AIM to Garhfer
It's aluminum, only the 03-04 cobra blocks are cast-iron
2004 GT Boosted by Vortech
Garhfer is offline
post #4 of 20 Old July 4th, 2007, 04:21 PM
GT's have an iron block with aluminum heads. 03-04 cobra's are the only 4v cobras to have an iron block.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
DrHolliday is offline
post #5 of 20 Old July 4th, 2007, 04:23 PM
HMUSN's Avatar
iTrader: 11 reviews
+1
HMUSN is offline
post #6 of 20 Old July 4th, 2007, 06:48 PM
Proud American
MustangMatt96GT's Avatar
Yeah the GTs are all aluminum!
RIP Travis Billings
1996 Mustang GT - Racecar
1995 Mustang GT - Daily Driver
Special Thanks to:
PoorMan Motorsports Full Parts Supply
MIA Motorsports For any Chassis Related Work or Drag Wings
25.3 SFI Chassis Build
Never Lift Racecars
MustangMatt96GT is offline
post #7 of 20 Old July 4th, 2007, 07:50 PM
MM's Mad Scientist
acmillr's Avatar
No they're not. This question comes up all the time and I don't understand why. The GT's ALL came with an iron block. The 03-04 Cobra came with an iron block as well. The iron block will handle more power than the aluminum block. I have personally seen an aluminum block that was twisted from having too much power put through it (about 1300 HP).
acmillr is offline
post #8 of 20 Old July 4th, 2007, 09:54 PM
Garhfer's Avatar
Why does a Mach 1 have an aluminum block when a GT has an iron block if it's so much weaker? Wouldn't you put better quality parts in a more expensive car?
Garhfer is offline
post #9 of 20 Old July 4th, 2007, 10:13 PM
04GTAMPA's Avatar
It looks like Ford had some problems deciding what to use on what. Check this out and find your answer...
http://en.wikipedia.org/wiki/Ford_Modular_engine
Slow, really slow Cobra. Wanna see?
MM Cobra Club Member #81
"TAMPA BAY AREA CREW"
04GTAMPA is offline
post #10 of 20 Old July 4th, 2007, 10:19 PM
04GTAMPA's Avatar
http://en.wikipedia.org/wiki/Ford_Mustang
Very good info...
04GTAMPA is offline
post #11 of 20 Old July 4th, 2007, 10:31 PM
Proud American
WOW I feel stupid! Must have been tired from work cuz I definitely knew that! My bad
EDIT!! All GT blocks are Cast Iron!!
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
post #12 of 20 Old July 4th, 2007, 10:31 PM
MM's Mad Scientist
acmillr's Avatar
Ford did that to save weight. In most cars, you will never push more power than the aluminum block can handle. I think it is obvious that Ford engineers know the iron block is stronger- look a what the 03-04 Cobra has.
acmillr is offline
post #13 of 20 Old July 4th, 2007, 11:11 PM
+1 The only reason for an aluminum block is to save on weight. It helps save on fuel if your moving less weight around.
Mustangless atm
post #14 of 20 Old July 5th, 2007, 10:03 AM
Garhfer's Avatar
The newer GT's are all aluminum. (2005+)
Garhfer is offline
post #15 of 20 Old July 5th, 2007, 10:34 AM
MM's Mad Scientist
acmillr's Avatar
Oddly enough, that information is accurate.
acmillr is offline
post #16 of 20 Old July 10th, 2007, 06:14 PM
96 to 98 cobra and lincoln mark 8 have the strongest blocks. they are called teksid blocks made in italy.
helos is offline
post #17 of 20 Old July 10th, 2007, 07:56 PM
MM's Mad Scientist
acmillr's Avatar
100% false statement..........
acmillr is offline
post #18 of 20 Old July 10th, 2007, 07:57 PM
coffinator6's Avatar
my 01 has an iron block. all gt blocks are iron unless the block has been upgraded by the previous owner.
coffinator6 is offline
post #19 of 20 Old July 10th, 2007, 08:41 PM
MM's Mad Scientist
acmillr's Avatar
There is no upgrade for the iron block if you are talking about power handling capability.
Why is this so hard to understand??????????????????????
acmillr is offline
post #20 of 20 Old July 10th, 2007, 08:42 PM
04GTAMPA's Avatar
Damn man. Can't understand man!
04GTAMPA is offline
