I don't know about Vortech or Novi but a common problem shredding belts with a ProCharger is that it damages the seal causing it to leak. Luckily, that seal is only $10 and not hard to change.
I really wish I had found the solution sooner. Either a bad tensioner or a shredded belt cracked my timing chain cover. It was leaking so I had to have it replaced.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370.
Ret. USAF 1969-1973,1980-1996: Vietnam veteran. Aircraft maintenance. R & D, ICBM Operations.
Also own: 1997 Harley FXDWG, 1998 F-150, and 2002 Corvette LS1
