What would you guess would happen by adding a supercharger? - Forums at Modded Mustangs
post #1 of 7 Old March 25th, 2013, 03:54 PM Thread Starter
Mississippi roolz
socialist's Avatar
If you've come across my other threads, you'll know that my Mach 1 is already built N/A. According to the previous owners dyno graph, the car was making 411 RWHP on Race Gas back in 2008. It should still be at that power level now. Off the top of my head, this is the work done to it:
Fully forged 5.0 stroker - 10:1 compression ratio
Manley Flat Top Pistons
Ported Long Runner Intake
Intake Spacer
Comp Cam 106200 XE270AH-114 Cams - along with supporting springs, etc
MMR Stage 3 Heads
ATI Super Damper
39 lb injectors
Spec Stage 2+ clutch
Terminator fuel tank and dual cobra pumps
Meziere Electric Water Pump
MMR 7 QT Oil Pan
MAC LT headers
Lethal Performance Catted x-pipe
Steeda Catback
90mm MAF
JLT CAI
Will have 4.10 gears shortly
I believe he said it was pushing a little above 390 RWHP on 93 octane. If I were to add a centrifugal supercharger to this setup, what sort of tq/hp levels would I expect?
I love that its pushing this much power N/A and if I EVER did a supercharger it would be in the far, far future...but sometimes I just like to daydream and I'm curious as to what would happen if I did it according to you guys that have the actual knowledge to predict such a thing.
Thanks!
Edit: added a few things that I remembered to the mod list
A young man was following Him, wearing nothing but a linen sheet over his naked body; and they seized him. But he pulled free of the linen sheet and escaped naked. (Mark 14:51-52)
socialist is offline
post #2 of 7 Old March 25th, 2013, 04:03 PM
I like boobs!!!
NickPohlAandP's Avatar
It would all depend on how much boost you run. One thing you would also want to keep in mind, with your compression ratio you would definitely want to go intercooled and use water/meth injection for safety.
'00 V6 being gutted for real fun! Fixing where I went wrong with my last 2000
'04 V6 for my stepson
'27 Ford T Sedan, sold
'12 GT, Roush Exh, Steeda 101mm CAI, SCT Tune, MGW, 388 WHP 375 WTQ, Sold
'00 GT Vert, Built, Sold
NickPohlAandP is offline
post #3 of 7 Old March 25th, 2013, 04:08 PM Thread Starter
Mississippi roolz
socialist's Avatar
Yeah, I would assume an intercooler in any case for this.
post #4 of 7 Old March 25th, 2013, 04:26 PM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
I would bring it to a tuner now. See what it puts down on the Dyno to make sure.
If you put a blower on it at 10psi, I would think you would be mid 500's
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is offline
post #5 of 7 Old March 25th, 2013, 04:32 PM Thread Starter
Mississippi roolz
socialist's Avatar
Cool.
I plan on taking it to a tuner soon. I gotta install the 4.10s and then get a 4-wheel alignment before I can do that though.
post #6 of 7 Old March 25th, 2013, 05:06 PM
Wiser by the Minute
aluv4speed's Avatar
I would run 3:73 not 4:10. You will hold in boost longer. I had 4:10 in my last one and like my 3:73 better now.
I think you will make 550 & 580 tq at least with a good blower setup and the right fuel.
Must do an intercooler and ensure that if the blower will be at 10psi on a stock block with X pulley you will need to pulley that lower since you have much more flow and an intercooler if you catch my drift. You may also want to do a blower grind cam.
nice stuff man!
" Drive Fast - Take Risks "
On3 2nd gen kit, 78/68 Benita, E85, - 628/654 16psi | 677/695 18psi {Just swapped in the Edelbrock, 6061 plenum, 75mm tb, & 4" intercooler} Need new tune.
aluv4speed is offline
post #7 of 7 Old March 25th, 2013, 07:42 PM
blownstang's Avatar
With 10psi i think you'd be 550 easy.
2004 DSG Mustang Mach 1 4r75w - 508/436 on E85. 460/396 on 93. Intercooled Vortech V1 S trim, Circle D 4c converter, BCA valve body, VRS o/r x pipe. 11.37 @ 120.8 mph 1.63 60'
blownstang is offline
